| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Guest
Posts: n/a
Flypress handle??
A friend of mine has just aquired a reasonable flypress with a bodged
handle made from what looks like a recycled pickaxe handle. Really a new one is needed. The real handle needs to fit a tapered hexagon about 1 inch across and have the usual flypress balls etc. Does anyone know where we'd find one? ta Charles |
#2 |
Guest
Posts: n/a
Re: Flypress handle??
On Sat, 30 Aug 2003 16:28:23 +0000 (UTC), Charles Ping
<wells_hall@yahoo.co.uk> wrote: >A friend of mine has just aquired a reasonable flypress with a bodged >handle made from what looks like a recycled pickaxe handle. Really a >new one is needed. > >The real handle needs to fit a tapered hexagon about 1 inch across and >have the usual flypress balls etc. Does anyone know where we'd find >one? > >ta > > >Charles Hexagon or Octagon? All the ones I have seen are 8 sided -- Regards, John Stevenson Nottingham, England. |
#3 |
Guest
Posts: n/a
>have the usual flypress balls etc. Does anyone know where we'd find >one? Charles, You also find these in the print trade - as an alternative place to look. Mike -- Mike Whittome |
#4 |
Guest
Posts: n/a
>> >>Charles > >Hexagon or Octagon? >All the ones I have seen are 8 sided Does tha mean you're swamped with hexagon versions? I'll check and report back. And Mike, last time I visited our printers it was all CTP! c |
#5 |
Guest
Posts: n/a
I've checked and it's hexagon alright.
It tapers from 3/4" at the top to 1 1/4" over 3 inches. Suppose we'll have to make one - which would be easier with a shaper! Charles |
#6 |
Guest
Posts: n/a
On Sun, 31 Aug 2003 16:27:11 +0000 (UTC), Charles Ping
<wells_hall@yahoo.co.uk> wrote: >I've checked and it's hexagon alright. >It tapers from 3/4" at the top to 1 1/4" over 3 inches. >Suppose we'll have to make one - which would be easier with a shaper! > >Charles > > > Nope, Cut 6 pieces of steel from a 3/8" thick bar to match the shape of one side. clamp two adjacent ones together on the original screw top and tack weld. Repeat until you have done all 6. Remove from job weld up and then drop a piece of thickish tube over and weld the bloody lot up solid. Weld two bars on for arms that's it job done. -- Regards, John Stevenson Nottingham, England. |
#7 |
Guest
Posts: n/a
On Sun, 31 Aug 2003 16:27:11 +0000 (UTC), Charles Ping <wells_hall@yahoo.co.uk>
wrote: >I've checked and it's hexagon alright. >It tapers from 3/4" at the top to 1 1/4" over 3 inches. >Suppose we'll have to make one - which would be easier with a shaper! > >Charles > > > Might be worth a trip to your local scrap metal yard (NOT a car breakers!) to see what they have. The one I go to 'had' some flypresses a while back in the junk pile, but I haven't been for a few weeks and they may have gone by now. I have one myself complete with handle and balls so wasn't interested for myself. Peter -- Peter & Rita Forbes diesel@easynet.co.uk Engine pages for preservation info: http://www.oldengine.org/members/diesel http://www.oldengine.org/members/blkstone |
#8 |
Guest
Posts: n/a
>And Mike, last time I visited our printers it was all CTP! > Yes Charles, But what did they do with the old kit?! ![]() Have you looked in their shed out the back? Mike -- Mike Whittome |
#9 |
Guest
Posts: n/a
> >Might be worth a trip to your local scrap metal yard (NOT a car breakers!) to >see what they have. The one I go to 'had' some flypresses a while back in the >junk pile, but I haven't been for a few weeks and they may have gone by now. > >I have one myself complete with handle and balls so wasn't interested for >myself. > >Peter As usual John's idea sems sound. I might even start with 1/2 inch strip and mill the slope on it so that it's parallel when welded up - that would make it tougher. Sadly Peter's idea of visiting a proper scrapyard is scuppered by the lack of them in thsi part of the world. There must be a decent one in Colchester with it's industrial past so if anyone know of one please shout! |
#10 |
Guest
Posts: n/a
.........as I was saying before technologly cut me off mid typing!
Mike's observation of printers may be valid but again, the only ones I know can print magazines and newspaper by the million but tend not to have redundant kit. However the litho plates do provide a ready source of thin aluminium! Thanks to all Charles |
#11 |
Guest
Posts: n/a
Try doe's they sometimes have machinery they where braking some CNC mills a
wile back good luck Andrew "Charles Ping" <wells_hall@yahoo.co.uk> wrote in message news:vfq4lv0raf9pj727dip0ftqqa2sks4e3uc@4ax.com... > > > > >Might be worth a trip to your local scrap metal yard (NOT a car breakers!) to > >see what they have. The one I go to 'had' some flypresses a while back in the > >junk pile, but I haven't been for a few weeks and they may have gone by now. > > > >I have one myself complete with handle and balls so wasn't interested for > >myself. > > > >Peter > > As usual John's idea sems sound. I might even start with 1/2 inch > strip and mill the slope on it so that it's parallel when welded up - > that would make it tougher. > > Sadly Peter's idea of visiting a proper scrapyard is scuppered by the > lack of them in thsi part of the world. There must be a decent one in > Colchester with it's industrial past so if anyone know of one please > shout! > > > |
