San Marcos, CA
Joined Aug 2009
Another good improvement:
Change the wheels. The following wheels fit perfectly and landings are very smooth and you get also some suspension (probably good for the retracts): Dubro 225R http://www3.towerhobbies.com/cgi-bin...225R&search=Go Dubro 275R http://www3.towerhobbies.com/cgi-bin...275R&search=Go One Note: The standard inner diameter is 3mm. You need to take a 5/32 drill and drill it to 4mm in order to fit on the stock retracts. Also those wheels a bit heavier than the stock. |
T-28 Landing Gear Mod
I've order the following Struts:
http://www.sonicelectric.com/Merchan...de=ERS-Strut-F As soon as they arrive, I replace the stock struts with these. The only things I'll use from the stock gear are the metal rods. I'll shorten the rods to the right length and mount the new struts. I'll report here again - incl. step by step pictures greetz jam |
FMS Giant T-28 Strut Mod
As I told before, here is the Building Report.
Steps for the wing struts 1. Remove the cover of the orig. struts and wheels. 2. Remove the plastic-blindness by the metal-rods with a Dremel. Be carefull, that you don't demage the metal rods with the Dremel. 3. Shorten the metal-rods and push the new struts over the metal rods. Check, that the struts have the correct height, and consider that the two maggot-screws grasp. It doesn't matter, that the drilling of the new struts are 5mm and the metal-rods have only 4mm outer-diameter, therefore it holds as long the maggot-screws are solid fastened and secured with screw locking varnish. 4. Install the wheel, also check that the whole leg get in properly (because of the length). I had to cut a little foam out. 5. The most difficult now is to reconnect the Strut Cover (the long slice) to the new strut, since no mounting for the linkage is given on the new struts. I use a cable-binder (large) and connect it to the new strut. After that, I pre - drilled a 1mm bore in the "head" of the cable-binder and tighten in the screw for the ball head. Secure the screw with super glue (respect not the ball-head sticks together) 6. Reinstall and align the strut cover, so that nothing sticks and the cover also closes right. Steps for the nose wheel 1. Execute step 1 to 3 from above. 2. Remove the linkage of the baydoors, and the baydoors itself. 3. Remove the steering linkage (solve maggot-screw first) and the adjusting ring underneath. This adjusting ring is no longer needed. 4. Mount the steering linkage exact to the same place, as the adjusting ring was placed. Take care, that nothing sticks, otherwise the nose wheel doesn't gets back in the bay properly. Therefore, I have to bend the steering rod a little bit to avoid sticking at the mechanics/electronics housing. 5. Reinstall and align the baydoors and hang up the linkage. Because of bad weather, I couldn't make test landings. But on ground testing, the suspension struts makes a very good impression and even works perfect. The Wheel Covers are actualy not install, cause I must find a solution for how to fix it on the struts. Summary: A modification, which is worthwhile. I hope this report, will be useful. Oli A few picrtures: Detailed view Front steering Strut ![]() By thehelicrazy at 2011-10-06 Wing Strut ![]() By thehelicrazy at 2011-10-06 Front steering strut ![]() By thehelicrazy at 2011-10-06 Detailed view of strut cover mounting ![]() By thehelicrazy at 2011-10-06 Wing strut cover closed: ![]() By thehelicrazy at 2011-10-06 |
San Marcos, CA
Joined Aug 2009
I did the same mod and it actually is a perfect location for the hole. No aerodynamic differences and the ESC stay's cooler. Also it looks very scale since it uses the intake on the cowl that is designed for it.
The cowl itself is heavy plastic and secured with three screws. The air is already streaming into the intake of the cowl regardless - but with this mod it actually has meaning :-) |
| Thread Tools | |
| Video FMS / Airfield 1400mm Trojan T-28 maiden flight | Anda Inc. | Electric Plane Talk | 0 | Jun 05, 2011 01:40 PM |
| Sold FMS 1400mm T-28 PNP w/electric retracts, gear doors, lights(local pickup only, SoCal) | T-CAT | Aircraft - Electric - Airplanes (FS/W) | 11 | May 08, 2011 10:53 AM |
| Discussion FMS Giant T-28 1420mm | FarmFlyer2 | Electric Warbirds | 0 | Apr 24, 2011 10:22 PM |
| Download New ParkZone Micro T-28 Trojan for CV, FMS, RCDP | ggunners | Simulators | 2 | Mar 26, 2011 09:10 AM |
