Old Jul 03, 2011, 07:28 PM
sonny1 is offline
Find More Posts by sonny1
Kool Kats Fly RC!! AMA 30462
sonny1's Avatar
United States, CA, Baywood-Los Osos
Joined Feb 2009
Alert
California to ban toluene and xylene; how do we thin Goop now?
I'm getting ready to start my first foamie plank using the thinned Goop covering method, and had a talk with the pretty paint lady at the local hardware store, and bought their very last quart of toluene to use as Goop thinner on a foam NCFM M60 I'll be starting soon. She said California is banning the use of both toluene and xylene, and that they will no longer be able to stock those solvents; something I wasn't aware of, (they were already sold out of xylene). The replacement for those solvents contain small amounts of those chemicals, but won't be the same. If so, what can we use to thin Goop? Will the replacement solvents work on Goop? Any suggestions or advice would be welcome. Good air,
Sonny
sonny1 is offline Find More Posts by sonny1
Old Jul 03, 2011, 07:30 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
The bypass is to get a source outside of CA to ground ship it to you. Or go to AZ or something and buy some.
Xpress.. is online now Find More Posts by Xpress..
Old Jul 03, 2011, 07:34 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
They had a couple of gallon cans left of toluene, maybe I should go down and grab those and put them on Ebay, (or just keep them for future projects). I'll start searching online for an out-of-state source, thanks for the suggestion.
Sonny
Old Jul 03, 2011, 07:42 PM
Mr. Combat Certain is online now
Find More Posts by Mr. Combat Certain
EPP Extrordinare
Mr. Combat Certain's Avatar
United States, CA, San Clemente
Joined Feb 2008
I have some of the replacement solvent, as far as I can tell it works the same...
Mr. Combat Certain is online now Find More Posts by Mr. Combat Certain
Old Jul 03, 2011, 08:00 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Thanks, good to know. What started the whole thing was a slope outing where I was flying a foam wing constructed with strapping tape and covered with colored packing tape. The site was basically a rock pile, and due to the high winds my plane suffered badly when landing on those rocks. One of my club mates showed up with a Moth covered with Goop, and his plane just bounced off the rocks like a rubber ball with no visible damage. I decided I needed to explore the Goop method on my next build so I wouldn't break my plane every time I landed. Thanks for the info!
Sonny
Old Jul 10, 2011, 06:47 PM
crazyracer is offline
Find More Posts by crazyracer
crazyracer's Avatar
United States, CA, San Diego
Joined Oct 2010
I think I remember that day Sonny, that goop can take a beating!
I am beginning a Moth soon, we'll have to fly our NCF machines when I return in the fall.
What is the name of the 'replacement' solvent to look for?
crazyracer is offline Find More Posts by crazyracer
Old Jul 10, 2011, 08:23 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Yes, you were there that day. I should have the M60 finished by then, and next time I go to the hardware store I'll get the name of the replacement thinner. I remember it says "contains toluene" on the label, but not exactly what it's called. I was also wanting to look into "New Stuff" laminating film. but not sure where to get that other than Office Depot; ever heard of it?
Sonny
Old Jul 10, 2011, 09:29 PM
codezilla is offline
Find More Posts by codezilla
codezilla's Avatar
Chino Hills, CA
Joined Feb 2003
Sonny
You can get the new stuff here:
http://www.laminatorwarehouse.com/la..._film.shtml#72
Minimum order is 2 rolls, but you won't have trouble selling a roll here on rcg at your cost including shipping. You can probably sell by yards and make some money too.
Adrian
codezilla is offline Find More Posts by codezilla
Old Jul 10, 2011, 09:36 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Adrian
Thanks Adrian, I had found that website, but wasn't sure which laminate to use; now I do! Before the M60 I have a blue foam Floyd semi-kit which I want to bash into a 48" plank, and apparently Goop melts blue foam so I was advised to use "New Stuff" on it instead. If it works as good as people says it does I may use it on the M60 instead of Goop.
Sonny
Old Jul 10, 2011, 09:42 PM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
New Stuff definitely works as good as people say. I am a convert. We are using the 1.7mil and 3mil stuff on our ultralightweight aerobat builds and it is great!
Steve
surfimp is offline Find More Posts by surfimp
Old Jul 10, 2011, 09:45 PM
madstick cliff is offline
Find More Posts by madstick cliff
madstick cliff's Avatar
Santa Maria ca
Joined Nov 2004
That's the stuff! There is a whole thread dedicated to "new stuff" here on the slope forum. I got some here in the classifieds the other day. Go ahead and put goop on the m60, it will help a lot in the bounce effect.
Cliff
madstick cliff is offline Find More Posts by madstick cliff
Old Jul 10, 2011, 09:51 PM
codezilla's Avatar
Chino Hills, CA
Joined Feb 2003
Sonny
I've never used the film on the blue foam. I don't know what the melting point of the blue foam is, but it's definitely lower than epp so you may want to test on a scrap to get the right temperature.
New stuff has its pros and cons. It's durable, cheap and easy to use, but it doesn't conform to the curves that well because it doesn't shrink much. You can also goop over the new stuff too.
Adrian
Old Jul 10, 2011, 09:53 PM
codezilla's Avatar
Chino Hills, CA
Joined Feb 2003
Steve
I've only built medium to heavy planes so only used 5 and 10, but regardless, it works great!!!
Adrian
Old Jul 10, 2011, 10:13 PM
sonny1 is offline
sonny1's Avatar
Joined Feb 2009
Adrian
Blue foam takes low heat from an iron well, and I've used packing tape and Ultracote over it with good results, (I keep the iron on low, around 200 degrees). I think I might go to the local Office Depot and get a small amount of "New Stuff" off their big roll to try before I order 2 rolls to make sure I want to go ahead and use it. I have a bunch of scrap around from various builds, so I have material to experiment with.
Sonny
Old Jul 11, 2011, 12:18 AM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
Remember that not all laminating film is the same. My comments pertain specifically and exclusively to the Premium Clear Gloss CP film here: http://www.laminatorwarehouse.com/la..._film.shtml#72
Adrian is right, it does not go around corners the same as Ultracote and is nowhere near as stretchy as Solartex. But, it is light, it is incredibly stiff, and it is very pleasant to work with. Plus it's very inexpensive, to boot! I have pretty terrible finishing skills and no matter what I cover with, there will be imperfections. I get about as good a result with the laminating film as I do with anything else, or maybe the clear just hides the wrinkles and edges better.
I do find the edges will pull up, I believe thinned Goop on top of the New Stuff in "high traffic" areas will help with that. I'm trying to eliminate Goop and other solvents from my build inventory, so I may try sealing the edges with white Gorilla Glue and see how that goes. Or I may just put some electrical tape on - that works good for abrasion resistance.
Steve
Discussion Goop Thinning, toluene vs xylene mjswider Hand Launch 19 Dec 12, 2014 02:24 PM
Discussion How do we push this? stevenmurrell Life, The Universe, and Politics 18 Apr 29, 2011 10:02 AM
Question Toluene or Xylene to thin GOOP? Utahrd Slope 37 May 31, 2010 04:33 PM
Question Thinning Goop, toluene vs xylene mjswider Slope 5 Jan 02, 2007 03:41 PM
Question How thin Goop for covering EPP wing? 4444 Slope 4 Oct 08, 2006 10:32 PM
