I'm just reading the instructions so you must forgive me. The instructions plainly state a programing card must be used to switch to Li-Po, but Horizon Hobbies ad says it comes pre-programmed. So I guess it's ready for Lipo, but it's not really clear.
I tried to explain that the Traxxas servos on my ProBoat Thundercat have been fully submerged too many times to remember. I mean underwater in a pond at least for more than 20 minutes at a time. I would have to say more than seven times. You may not be convinced but that type of reliability is good enough for me. I understand it may not be convincing for most people, but it really made things easier for me. I will not lie to you, some have been known to leak in other boats in our club, but it remains a rare event. The Waterproof reciever boxes work just fine. A Traxxas 2075 servo has has 125oz of torque. We sometimes use them just for that reason. http://traxxas.com/products/parts/servos/2075 |
The radio box is not waterproof!!
The Stiletto was "not" programmed for Lipo out of the box. My local hobby shop programmed it for me.
The Stiletto snapped out of the water when I hit the throttle like a jack rabbit. It was hauling at least 27 to 32 mph on 4s with 5000 35c. It will prabably do better if I knew what I was doing. The variable steering was not set, so I turned too hard and it flipped. This little sucker hauls! The "waterproof" radio box filled up with water as expected. Was it he rubber boots for the cables? Was it the antenna hole? Was it the rubber boot for the servo wires? Was it the power switch, or was it the tape? Who knows, but this radio box has 5 different holes in it with boots or seals and it's unlikley that it will ever work. I have some work to do. |
How do you know it wasn't programmed for lipo? The only difference is the LVC setting, and unless you ran a pack completely flat there's no way to notice that.
I dunno why yours leaked so badly, but I've witnessed a stiletto with the stock radio box setup sit upside down for a good 10 minutes and it was dry inside. A couple drops of water in the battery area, but none with the RX/servo. |
If it were me i'd probably just put a touch of silicon in the seal for the cabling etc, that should stop any leaks and if's it for a moving part such as steering cable from servo i'm assuming this also has a boot over it, i'd put marine grade grease in there, usually white in colour and extremely water resisitant.
Mod Time
I have had some time to catch up on making the Stiletto a little more water resistant.
I decided to move the reciever to a waterproof case and give it better access. The ProBoat servo was removed and replaced with a waterproof 2075 Traxxas servo. This will make the radio box obsolete. I left the cover in place for the antenna and power switch. I cut the corner for draining. This worked well for the Thundercat, so I shouldn't have anymore problems. The members of my club and I remain mystified by the Stiletto's awkward setup arrangement. Everybody seems to agree the servo should be in the rear with solid linkages and the ESC near the front. The batteries should have an area of their own. The cable system seems reliable, but dubious. I think this boat needs a serious redesign to become a big seller. Removing the steering cables to insert the batteries is annoying to say the least. This is well built boat with some real performance. The quality is there and the boat hauls butt. Sadly, it gets a D- on the setup arrangement. This boat may be too complicated for first time users wanting the thrill of high speed. A good engineering effort to make this boat user-freindly and waterproof would make it a true legend. |
^^ Every tunnel I've ever seen has the radio box up at the front, even older nitro ones. Do the guys in your club have any tunnel experience?
How are you going to waterproof the ESC if you do away with the radio box? The stock servo would withstand some water (might need to be dried and lubed every so often), and the receiver is water resistant as well (conformal coating on the circuit board). The ESC isn't very water resistant from what I know. As for removing the steering cables to get the battery in, I've never seen anyone have to do that, even with a single 4s5000mah pack? Just a bit of a side note, I don't think anyone is marketing the Stiletto as a beginner or first timer boat... even Horizon lists it as race ready. Here's a thread on one of the hottest tunnels this summer, the radio packing is very similar. The only difference is that everything is in one big radio box: http://forums.offshoreelectrics.com/...e-tunnel/page4 |
Yes, I have to remove at least one steering cable to remove the battery cover. The wire cables are actually rubbing over the plastic battery cover. Look at the pictures, the cables are tightly bound over the clear battery cover. The cover will not lift off with cables in the way. If the top of the battery box was lower, it would actually work. The guys in my club have experience with tunnels and tons of other boats. Theres been plenty of advancements in rc boats, it doesn't mean anything has to stay the same. Race ready! That means experienced boaters only? No impulse buy? So this boat is for advanced users only? You mean to tell me this boat is for a niche market only? OH MY!! OK, this boat is only for guys who really know what they're doing. I have racers in their 70's at our club that have been doing this since the 50's. They were the ones who showed me how to ditch the radio box and use Traxxas waterproof parts. Do you even own a Stiletto? |
I don't own one, but I've seen enough run that I know they work out of the box.
IMO, it's all a waste of time and effort to ditch the radio box, but it's your boat and you're enjoying it so that's all that matters. You didn't answer about the ESC though, you'll want to have that somewhere sealed. If you run it out in the open it'll fry on the first run. |
| Thread Tools | |
| For Sale Pro Boat mini-V like new | Cable Guy | Boats (FS/W) | 0 | Jun 28, 2011 12:12 AM |
| Help! Pro-Boat MiniV servo problem...4wire servo replace with 3 wire? | Jagzilla | Racing Boats - Electric | 4 | Jun 27, 2011 09:48 PM |
| Sold New Pro Boat 1800kv motor and Pro boat 60amp esc | tunnelvision | Boats (FS/W) | 2 | May 17, 2011 03:30 PM |
| For Sale Pro Boat Stiletto | heli123 | Boats (FS/W) | 6 | Jan 11, 2011 08:47 PM |
| Sold Pro Boat Stiletto (new / modded) | Diegoboy | Boats (FS/W) | 6 | Dec 07, 2010 09:46 AM |
