http://www.horizonhobby.com/webapp/w...pe=productgrid And yes, I used one of the two O-rings that came with the Cyclone. |
Gear update
Lance,
I'll post those pictures for you, Something I should say is that I got this idea from Brandon Moon. His video of his gear mod helped me set this plane up. I found a 0.256 inch carbon fiber hollow tube at the hobby shop for the wing spar. Under ten bucks Pictures This is all that was cut out on the rear, opening filled in with some extra foam I had around. Here's the front door, the pea pave unit keeps it from opening all the way up. I took the springs from the stock hinges (little black ones) and added them to the sonic tronic units. The servo for steering, you can slide it forward or back. Cut a hole where the pea pave (camera) fits to access this servo. Then just tack glue the pea pave on so you can get back in there if you need to. To fix a bo bo you can cut out some foam like carving a pumpkin top to get at the bad spot. Then just epoxy it back on after the fix. Here's a spot I cut out to fix the rear gear, glued it right back after the work. RCLander is a good outfit and they are working on lots of landing gear. Metal gear are coming soon, Max and Tim are good people I just ordered a new EDF from them. I hope to shoot some video this weekend of the a10 in the air.
USA, TX, El Paso
Joined Jan 2007
if any one is interested.
http://www.rcgroups.com/forums/showthread.php?t=1567791 ialso have the cyclone 2500kv for sale. TIA Carl |
I'm looking forward to seeing better gear on the market soon! ![]() On take off run, you want to add power nice and smoothly
| Thread Tools | |
| Discussion "Official" BH/LX B-2 Stealth "Spirit" 2x64mm EDF, Build/Mods Thread! | RemE | Foamy EDFs | 1149 | Mar 25, 2013 12:51 PM |
| Build Log Blitz RC / LX 70mm F-35 JSF 3D Build Thread | xplaneguy | Foamy EDFs | 305 | Oct 24, 2012 06:14 AM |
| Build Log J-Power A-10 build, mods, general discussion thread | gunracer | Foamy EDFs | 199 | Jul 29, 2012 12:49 PM |
| Discussion Lx a-10 | 6172crew | Vendor Talk | 3 | Jun 26, 2012 07:22 PM |
| Discussion Ordered a LX F-22 from Toy Sonics.com Build thread | valleypatroll | Foamy EDFs | 16 | Apr 19, 2011 02:12 PM |
