Jul 23, 2011, 09:59 AM
Anaheim, California
Joined Feb 2006
I screwed up, hope somone else doesn't do the same thing, I feel so stupid.
I was so carefull not to let epoxy squeeze out of the seams, so carefull not to dent the foam, so carefull to plan the .46 retracts....just so carefull....but then I discovered my screwup....fatal screw up.
I installed the elevator upside down, rudders on the wrong side. Yep, I assumed that the whole piece mounted on top, not under the fuse. To make matters worse, I used Hysol to glue the rudders on, no way to fix this. Yes, now I know the underside and top side are different colors of camo, but I am slightly color blind and I only noticed it after the glue dried.
I had to order a new kit, hopefully the parts are the same because the rest of the plane is finsihed.
Stupid, Stupid, Stupid
