Old Jul 15, 2011, 09:21 PM
mainjet is offline
Find More Posts by mainjet
mainjet's Avatar
springfield, missouri
Originally Posted by SCALEFAN View Post
I just got the A-10 from Banana and it came perfect. To avoid some of the problems that others have posted, I emailed them first to make sure they had one in stock.
First thing I did was to follow their instructions and test the electronics. The only electronics that came with the airframe kit were the retracts. So, I tested one....bad move, burned it up, didn't know about the adapter and plugged it direct into the RX. Going to use E-Flite .46 retracts instead.
I noticed that one of you guys used the 46 retracts, made a plywood plate for mounting. I was planning the same thing, but intended on making a flat plate and keeping the retracts deep with the plane closer to the ground.
Mine will be tentatively powered by the Stock EDF units that were supplied, with motors taken from crashed Nitroplanes Meteors, running on 4S. What do ya think?
Al
like Mike said, I also had an issue with mounting the nose EF 46 retract deep enough. I actually had to glue a back plate in the battery department so I would have something solid to mount too.
mainjet is offline Find More Posts by mainjet
Old Jul 16, 2011, 06:12 AM
BpwrJet is offline
Find More Posts by BpwrJet
my brother's keeper
BpwrJet's Avatar
Joined Dec 2006
Originally Posted by mike2663 View Post
I didn't need any.
Mike, you were bang on - maidened the bird today, just needed more up elevator in general, but once trimmed, the flaps worked perfectly.
I had the CG right on 85.
Thanks again for the expert advice, made for a good flight.
Chris
BpwrJet is offline Find More Posts by BpwrJet
Old Jul 16, 2011, 07:00 AM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Sweet another hog in the air. Expert, no just someone who enjoys the hobby for what it is. If we can help one guy though a issue with this to get it to fly as it should then it's worth it. Flies great doesn't it? I would just like to thank you guys for posting great info without the BS. I hope this will begin a trend here in the EDF forums. I'm thinking of picking up another airframe to try another set up. I have too many irons in the fire right now though.
mike2663 is online now Find More Posts by mike2663
Old Jul 16, 2011, 09:36 AM
beagleone is offline
Find More Posts by beagleone
Were all gonna' FLY!
beagleone's Avatar
USA, MA, Saugus
Joined Sep 2008
Do you guys think I made a right choice by getting 60 amp esc's? I know the stock ones are 50 amp but from what I've read they are not big enough with 6s. I should be out flying my T-28 and Frenzy 50 today, it is absolutly beautiful out, bright blue sky, 80 deg. going to 90, NO humidity, NO wind. BUT I have a new gas stove being delivered today any time between 8:00 am and 4:00 pm...... I guess that narrows it down.
beagleone is offline Find More Posts by beagleone
Old Jul 16, 2011, 09:49 AM
brandonmoon is online now
Find More Posts by brandonmoon
Fly & Have Fun..Enjoy the Ride
brandonmoon's Avatar
United States, AZ, Gilbert
Joined Mar 2009
Your ESC choice greatly depends on your choice of motors...and thier amp pull.
the stock LX 2100kv motors are fine with the included 50A ESC's...60A Esc will just give you more head room.
If you choose to use more powerful Motors....then you will need to know what thier rated amp/Current pull is? and with that you decide what would be the ESC's you will need?
brandonmoon is online now Find More Posts by brandonmoon
Old Jul 17, 2011, 01:31 AM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
I'm going to try the stock gear one more time..... Just because they came with the kit. DOH DOH..maybe. But I also have my RC Landers from my crashed A-10 to fall back on... It seems funny that I've flown my SU-47 countless times on the stock gear. It held up fine. They are almost if not the same gear.
DaveBC is offline Find More Posts by DaveBC
Old Jul 17, 2011, 02:20 PM
parkrc is offline
Find More Posts by parkrc
Joined Apr 2010
HI
My A-10 is build and ready for maiden ,everything is stock.
Do you guys have any tips like how much throws on the ailerons and elevator as well as using expo and how much flaps do you use.
One thing I noticed is when the the landing gear is retracted and you use aielerons ,there is a beeping sound from the controller.Is this normal ?
Has anyone taken off and landed on grass?
Any tips on a succesfull maiden will be apreciated.
parkrc is offline Find More Posts by parkrc
Old Jul 17, 2011, 02:54 PM
Oreo is offline
Find More Posts by Oreo
Gliding like a rock!
Oreo's Avatar
Baltimore, MD
Joined Apr 2007
Don't land on grass with the OE gear.
Oreo is offline Find More Posts by Oreo
Old Jul 17, 2011, 03:23 PM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Lots of throw and plenty of expo. The grass will be a issue with those retracts.
Old Jul 18, 2011, 12:18 AM
parkrc is offline
Joined Apr 2010
I will have to look then on upgrading the retracts.
Old Jul 18, 2011, 06:51 AM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Just a shame to tear up a nice airframe like that over the retracts. If you fly off pavement them you'll get some life out of them ( if you can nail every landing) but eventually they will fail.
Old Jul 18, 2011, 07:20 AM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Well went to maiden but mine never got off the ground. I didn't put less throw or DR for my nose gear. Thinking that ground handling was very solid. It was really great actually. But our run way has a big pot hole that was patched up, but it wasn't enough for my Hog. It ran off the grass and popped out one of my mains. I broke off my gun! What is a Hog with out the gatling gun! Thats was pretty much all the damages everything else is fine. It just suck that my Hog is not a virgin any more and the worse part is she never got off the ground yet!
jet-ster is offline Find More Posts by jet-ster
Old Jul 18, 2011, 07:29 AM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
I hate it when that happens. Glad there was no major damage. Did the retract survive?
Old Jul 18, 2011, 09:15 AM
geker is offline
Find More Posts by geker
Joined Jun 2010
ordered my a10 will be here wednesday kit version. i am going to order the stock motors to use and some 80 amp esc's what servos are you guys using and sounds like i better change landing gear too cause i do need to fly off grass any ideas thanks dave
geker is offline Find More Posts by geker
Discussion "Official" BH/LX B-2 Stealth "Spirit" 2x64mm EDF, Build/Mods Thread! RemE Foamy EDFs 1527 Today 10:15 PM
Build Log Blitz RC / LX 70mm F-35 JSF 3D Build Thread xplaneguy Foamy EDFs 312 Jan 10, 2015 01:35 PM
Build Log J-Power A-10 build, mods, general discussion thread gunracer Foamy EDFs 199 Jul 29, 2012 12:49 PM
Discussion Lx a-10 6172crew Vendor Talk 3 Jun 26, 2012 07:22 PM
Discussion Ordered a LX F-22 from Toy Sonics.com Build thread valleypatroll Foamy EDFs 16 Apr 19, 2011 02:12 PM
