Old Mar 13, 2013, 07:11 PM
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by erh7771 View Post
Sorry to hear about that
HK sells white boxed Coronas, I've beat on them good ... they're pretty reliable
+1 on the Corona. I have used Cyclone Power servos in my A-10 and Windrider Boeing 737 with no problems.
bamaguy is offline Find More Posts by bamaguy
Old Mar 15, 2013, 10:01 AM
Joined Aug 2012
I was testing some colors today to determine which I'll be using for my A-10.
If you need colors that match the original ones I found out that these two are really close:
Vallejo Air Color 70.051 Bareley Grey (for the dark paint)
Vallejo Air Color 70.046 Light Bluegrey (for the lighter paint)
I'm not sure yet what I'm gonna use, I've ordered some extra samples for testing.
Is there anyone who can tell me what the maximum voltage is to operate the retracts on? Can the be used with 6V or 5V only? And how much current do the draw?
tank532 is offline Find More Posts by tank532
Old Mar 15, 2013, 05:58 PM
The43rdHammer's Avatar
United Kingdom
Joined May 2010
Tamiya XF-53 and XF-83.
I prefer Vallejo Model Air too, will have to note them
The43rdHammer is offline Find More Posts by The43rdHammer
Old Mar 16, 2013, 01:44 AM
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
Had another look at the OEM retracts. And I am now contemplating replacing them after finding some damaged movement arms. (the one holding the motor and the one at the strut)
Had a quick search done on this thread and the Landers are quite popular but also seems to be quite prone to bending.
Any other suggestions?
fooyukvoon is offline Find More Posts by fooyukvoon
Old Mar 16, 2013, 03:47 AM
United Kingdom
Joined May 2010
E-Flite 25-46 Tricycle or Hobby King DSRs.
I have E-Flites fitted and they're perfect.
Andy
Old Mar 16, 2013, 07:49 AM
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
+1 on the E Fiites no issues to date.
mike2663 is offline Find More Posts by mike2663
Old Mar 17, 2013, 02:35 PM
Comencing countdown Engines On
United States, CA, Corona
Joined Mar 2013
LX comes with seperate BEC?
I was not expecting it to come with its own seperate BEC, and heard about all the problems with running power from the stock ESCs on these so I bought the Castle Creations 10amp to run with it, .
3 questions....
1. Is this ESC worth a Damn? or should i skip it and go with CC10Amp
2. Did yours come stock with an external BEC and that is what has failed in others or is this new because of the built BEC Failures built into the Stock ESC?
3. the Black wire looks clipped, if I want to use it, I should solder this right.
I was going to go with LIFe, but after having some problems with one RC Lander Retract and I think running over 6v, I will avoid and either use a BEC, and either connect to 6s batteries or Connect BEC and Seperate LIFe batt.
Maj. Tom is offline Find More Posts by Maj. Tom
Old Mar 17, 2013, 08:11 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
I cant get the E-Flite retracts, so I've ordered the Lander ones. (Hope this bird lands gentle )
The OEM BEC seems to be fine on mine. Only the RED wire should be disconnected. Looks like you'll have to strip off the yellow heatshrink and figure out where the WHITE & BLACK wires go to on the circuit board if you want to reuse this BEC.
Old Mar 17, 2013, 09:09 PM
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I would just go with the CC 10amp bec.
DamonH is offline Find More Posts by DamonH
Old Mar 17, 2013, 09:27 PM
bamaguy's Avatar
Joined Feb 2009
+1.....I've done that, as well Run it with a 2S1800 Zippy
Old Mar 18, 2013, 08:53 AM
Were all gonna' FLY!
beagleone's Avatar
USA, MA, Saugus
Joined Sep 2008
+2.... Here is what I did. HK 7 amp BEC w/noise reduction set at 5v with 2200 2s lipo for reciever , 600ma NiCad just for lights.
beagleone is offline Find More Posts by beagleone
Old Mar 18, 2013, 01:24 PM
Joined Mar 2013
Thats alot of batteries. I will probably go with just 2. 1 1000mah one for receiver and such and then the 6s. With all those bateries, what size you running for mains. Though I'm betting you went with different than stock fan setup, to push that all that added weight around the sky with any authority.
Old Mar 18, 2013, 01:28 PM
Joined Mar 2013
New Question about Fan Balancing
I read somewhere that everyone should be balancing the stock fans in all ARF EDFs. I've never done this before on any of the smaller EDFs I've flown, and I'm not sure I should start now. Is it completely necessary with this one or can i skip this? And If I need to, where is there a good instructions on how to do this with fan units. I'm very familiar with Prop balancing and have a setup to work with that.
Old Mar 18, 2013, 04:48 PM
Joined Aug 2012
Maj. Tom, if you want to save yourselve all the trouble and may be even your model, you might consider buying some good pre balanced fans. I bought some Wemotecs myselve.
Old Mar 18, 2013, 04:52 PM
Joined Mar 2013
Which ones did you buy, and can I leave the Stock Motor and ESC?
Discussion "Official" BH/LX B-2 Stealth "Spirit" 2x64mm EDF, Build/Mods Thread! RemE Foamy EDFs 1149 Mar 25, 2013 12:51 PM
Build Log Blitz RC / LX 70mm F-35 JSF 3D Build Thread xplaneguy Foamy EDFs 305 Oct 24, 2012 06:14 AM
Build Log J-Power A-10 build, mods, general discussion thread gunracer Foamy EDFs 199 Jul 29, 2012 12:49 PM
Discussion Lx a-10 6172crew Vendor Talk 3 Jun 26, 2012 07:22 PM
Discussion Ordered a LX F-22 from Toy Sonics.com Build thread valleypatroll Foamy EDFs 16 Apr 19, 2011 02:12 PM
