Old Jul 02, 2011, 11:00 PM
seahawk1984 is offline
Find More Posts by seahawk1984
Experienced but not an Expert
seahawk1984's Avatar
United States, WA, Enumclaw
Joined May 2011
Question
Can I use 2 MCPX batteries with my UMX Beast?
I just picked up the battery 'Y' Harness for my UMX Beast, and I noticed that I could hook up 2 of my MCPX 200mah 3.7V E-flight batteries and use those in my UMX Beast. So now my question is, the batteries that I was using for the UMX Beast was the 2s E-flight 180mah batteries, how much more flying time will I get if I use 2 E-flight 200mah 1S Batteries?
A friend of mine said that the 2 200mah batteries would be the equivalent of a 400mah 2S battery. But I'm not completely convinced. If he is correct, that would seem like it would add considerable flight time! I have been getting about 5 to 7 minutes of fly time on the 180mah 2s batteries, so if by adding 2 1s 200mah batteries, and it actually is like a 400mah battery, would that almost DOUBLE my fly time?!
Her is the links to the horizon hobby web page for the batteries that I am talking about if that helps:
MCPX 200mah batteries.... http://www.horizonhobby.com/Products...ID=EFLB2001S25
Batteries I am currently using in my UMX Beast.... http://www.horizonhobby.com/Products...ID=EFLB1802S20
seahawk1984 is offline Find More Posts by seahawk1984
Last edited by seahawk1984; Jul 02, 2011 at 11:05 PM. Reason: Fixed Grammar and added battery links.
Old Jul 03, 2011, 02:36 AM
efflandt is offline
Find More Posts by efflandt
efflandt's Avatar
United States, IL, Elgin
Joined Mar 2011
The UMX Beast uses 2S voltage. So if you got a Y-harness to connect (2) 1S batteries in series (not parallel), (2) 1S 200 mAh batteries would give you a little more time than a 2S 180 mAh battery.
If you had (2) 1S batteries in parallel, then the mAh would be additive, but I don't know if it would have enough voltage to power up and fly.
efflandt is offline Find More Posts by efflandt
Old Jul 03, 2011, 02:57 AM
Joined May 2011
Yes, after reading your reply, I took a closer look at the harness, and it is a series connection. So the voltage is additive, where as the capacity of the batteries would not be. So by putting the two 1s 200mah 3.7v batteries in series, it effectively is a 2s 200mah 7.4 batteries, and would give me about a minute more fly time, compared to the 2s 180mah 7.4v batteies I am currently using.
Thanks for the info
Last edited by seahawk1984; Jul 03, 2011 at 03:00 AM. Reason: fixed spelling error
Sold E-Flite UMX BEAST YarSmythe Aircraft - Electric - Airplanes (FS/W) 1 Jun 29, 2011 04:39 PM
Sold E-Flite UMX BEAST YarSmythe Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jun 29, 2011 12:09 PM
Sold UMX Beast w/extras - $135 *Reduced!* Daren Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jun 26, 2011 12:25 PM
Discussion Can I use 3s Batteries with a 2s system Mitchie Power Systems 9 May 17, 2011 11:49 AM
Sold UMX Beast Electronics, 5 Props, 3 batteries, and charger w/ AC adapter jmrust Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Feb 08, 2011 08:42 AM
