Old Dec 21, 2012, 12:41 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Originally Posted by tom43004 View Post
Chris,
I just add a 12k spread tow ribbon along the LE in the top and bottom mold before finishing the skins. I'm pretty sure it's significant overkill but I like having it there.
I'll do a "part two" video using the wing to chop apart some household items later. Should be fun.
Maybe you could use it to split some firewood.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Dec 21, 2012, 12:48 PM
rwait is offline
Find More Posts by rwait
SE Michigan
Joined Dec 2007
Having had midairs with hollow molded planes and foam core planes, your video confirms what my in flight crash tests have already told me. This is the reason that I will only buy foam core molded DLGs from now on.
rwait is offline Find More Posts by rwait
Old Dec 21, 2012, 01:10 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Data points are data points and it likely matters more on plane orientation when contact is made as to who comes away with the most damage. John Lovins and I collided at BSoAZ this year. His Concept didn't even have a scratch while my Polaris had a 1 inch gash in the leading edge of the throwing side. I would not have even considered throwing a hollow molded plane with that kind of damage, but a couple pieces of tape over the gash was all I did on the Polaris and went right back out with 100% throws... THAT is what's nice about solid core! And the final repair on the wing was easier than if it was hollow molded.
jfinch is offline Find More Posts by jfinch
Old Dec 21, 2012, 03:23 PM
rwait is offline
SE Michigan
Joined Dec 2007
Probably hit his throwing blade would be my guess. I haven't seen a hollow wing that would come out unscathed in a leading edge to leading edge collision with a Polaris as demonstrated in Tom's video.
Old Dec 21, 2012, 03:35 PM
JONBOYLEMON is offline
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
But will it blend?????
JONBOYLEMON is offline Find More Posts by JONBOYLEMON
Old Dec 21, 2012, 03:44 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Nope, LE to LE. The plane were stuck together
Old Dec 21, 2012, 03:48 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Polaris is solid core but that alone doesn't make it impervious to damage. It's still a very light wing.
Rohacell in the core isn't particularly strong, and if the skins are light and don't have LE reinforcement, they can still slice. I've seen it happen.
Again, the key is that you can tape it up and fly the next round. No delays, no spar damage, no worry about structural failure.
tom43004 is offline Find More Posts by tom43004
Old Dec 21, 2012, 03:54 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
again, the key is that you can tape it up and fly the next round. No delays, no spar damage, no worry about structural failure.
yes!
Old Dec 21, 2012, 03:59 PM
rwait is offline
SE Michigan
Joined Dec 2007
Didn't say impervious to damage, I believe much less damaged would be accurate. I had a similiar experience at the Bruce this year. A midair with a Steig. He had no damge, I had a two inch long cut in my wing. Since the cut was about 1/32" inch wide with no skin buckling, it was pretty clear what part of his plane hit my wing. Having owned a Steig, I am also pretty sure what would have happened to his leading edge in a direct collision. I taped over the cut and flew the rest of the contest that way.
Old Dec 21, 2012, 07:46 PM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
That's EXACTLY where my mind went when I read that! Kinda scary.
Tom,
You mentioned that the rohacell wing had delams clear back to the spar, despite not having any significant LE damage after a few good smacks. Is this type of damage something you've seen before?
carlsoti is offline Find More Posts by carlsoti
Old Dec 21, 2012, 08:00 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Yeah Norm, when you armor a hollow moldie's leading edge like I have in the past, you get compression buckles or wrinkles somewhere aft of the reinforcements when it hits another airframe hard enough. The next strongest part is the spar, so typically you're going to get buckling in the skins at the edges of the spar. Unfortunately you look at the LE where the impact happened and see no damage so you go ahead and throw the airplane and the wing blows up on the ensuing launch. Anybody that saw me fly at the Greensboro NC contest about a year ago got a good laugh out of one such occasion. I launched after hitting myself in the wind and the wing "flapped" as the airplane dove in over the hill. It was funny as hell but cost me an airplane. It got funnier when I pulled it out of the ground and flew it twice more to get short flights with a broken wing. IIRC Gavin was flying my backup at the time.
You're almost better off on hollow molded stuff NOT armoring the LE because you want the damage to be localized to the impact area.
Old Dec 21, 2012, 08:17 PM
rcgeorge is offline
Find More Posts by rcgeorge
usaf3kteam
rcgeorge's Avatar
United States, AZ, Arizona City
Joined Sep 2005
I have seen lots damage to all types of DLG including Polaris. I have been in at least 5 midair's and 3 of them I took damage as did other plane and 2 no damage to me. I had a Twister-2 thrown into my Stobel at the Bruce my Stobel might have been 20' hi when hit with full throw. It totally destroyed the Twister-2 Stobel just had some paint on it no real damage. What does that prove nothing. I have midair with Polaris and and we booth took on damage. Tom your wing looks to be strong but are you going to be at a contest and midair on purpose? I think not. Hope to see you fly at Jem keep up the great work cheers.
rcgeorge is offline Find More Posts by rcgeorge
Old Dec 21, 2012, 09:27 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
Anything can happen in a mid air. I had my first DLG midair this year. We hooked wings and tails at about 50' and slowly spiraled to the ground, no worse for the wear. I had a second one with my Fr3aK and my buddies B3. We met LE to LE while circling in opposite directions. Each plane flew away and we finished our respective flights. In the end, he lost a 3" section of his LE. I had a tiny soft spot that I CAed tight again.
Personally, I like what Tom is doing to make his planes more durable. I plan on adding one of his new planes to my stable and durability is a big factor in my decision.
Old Dec 21, 2012, 10:16 PM
GaryO is offline
Find More Posts by GaryO
Joined Sep 2001
It looks like when I get the new wing I could trim the tops of the fir trees with it, and not have to land in them any more
Gary
GaryO is offline Find More Posts by GaryO
Old Dec 22, 2012, 07:21 AM
BavarianCharles is offline
Find More Posts by BavarianCharles
Follow me to sink!
BavarianCharles's Avatar
85045
Joined Oct 2005
Tom,
the potential for damage to structural members of the wing is why I didn't follow GT's method for armoring the LE when that came up in the Edge thread. The energy transferred to the LE has to go somewhere, and so the safe bet is a crumple zone like the one in your car (Not sure abot half/full ton trucks). I'm thinking about adding a 1mm rod underneath the uni "spar" on my next wing, just to keep the wing from flapping wildly in the event of a major mishap.
Cheers, Charles
BavarianCharles is offline Find More Posts by BavarianCharles
New Product Park Zone's Ultra Micro Pole Cat............ ChuckTseeker Micro Ready-to-Fly 2726 May 26, 2016 09:03 PM
Sold Park Zone Chargers (3) 2,3and 4 cell outflying3d Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 30, 2011 09:35 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 12:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Discussion Does HobbyKing make anything like the Park Zone T28? lacofdfireman Electric Warbirds 2 Jun 24, 2011 07:32 AM
