Old Dec 15, 2012, 09:59 PM
JONBOYLEMON is online now
Find More Posts by JONBOYLEMON
Full disclosure, not sponsored
JONBOYLEMON's Avatar
United States, UT, American Fork
Joined May 2002
I dont know, but the puma slipper woman for $30.00 sounds cheap. Last time I checked, a Puma woman was 20k plus shipping!
JONBOYLEMON is online now Find More Posts by JONBOYLEMON
Old Dec 16, 2012, 12:11 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Its a spammer. I reported him so once the mods are back at work he will be gone.
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 16, 2012, 10:22 AM
carlsoti is offline
Find More Posts by carlsoti
hass-alfed and bass-ackwards
carlsoti's Avatar
United States, AZ, Chandler
Joined Jun 2008
Jon, you're doing it wrong. $30 is the "rental price."
Back on topic, I'm looking forward to seeing one of the solid core molded SFs up close and personal.
carlsoti is offline Find More Posts by carlsoti
Old Dec 16, 2012, 10:46 AM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Yeah, you know it's fake. No way you're going to get an AF Tank Woman for $17.
jfinch is offline Find More Posts by jfinch
Old Dec 19, 2012, 11:57 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Changes for the SuperFr3aK
Since I've shipped the first SuperFr3aK I guess I can elaborate on some of the details here.
Tails : same tails you're used to on the Fr3aK with squared tips and super strong at 13-14g per set.
Fuselage : Improved stiffness with AKP (Aft Kick Point) design and kevlar / glass forward section. I am now pre-installing the wing hold down blocks when molding the fuse, as well as shipping the fuselage with holes pre-drilled and tapped. All you have to do is cut a hole to fit your wiring harness connector and bolt on the wing.
Wing : Solid core molded with two layup options currently. The planform is as designed by Gerald Taylor (G_T) with very little modification this time around. The original Fr3aK used his planform but I changed the last few inches toward the tip slightly to ease in manufacturing. This time I stayed very true to Gerald's design including tip shape and the result is a slight improvement in the low speed behavior and a tad bit more dead air time. The standard layup is Textreme spread tow D box and glass over CA safe solid core 70psi foam. Doublers are present over the center section, servo bays, and both tips. Spars are inlaid with 160g/sm unicarbon and servo hatches are molded in with spread tow Textreme covers. Servo wells are routed. wing bolt holes are drilled and countersunk. A conventional throwing blade is provided, as well as pushrod materials and CNC cut control horns for top drive. The LE has inlaid 12k spread tow ribbon carbon for cosmetics and durability. Flapperons are pre-faced as are the trailing edges of the main wing, and Textreme doublers are added where flapperon control horns are mounted. A kevlar strip hinge is molded into the wing, and flapperons are cut and gapped before shipping. Weights on these wings are coming down with every pull, and are currently in the middle 130s, which is the same as the hollow molded Fr3aK wings.
The full carbon option is the same as above but with "Vladimir" biaxial spread tow 45g/sm carbon fabric over the entire wing surface. Textreme doublers are still used underneath the Vladimir carbon skins. Weight is reduced slightly in this layup with no decrease in stiffness.
All wings are painted in the mold with clearcoat on any top surface, along with tip / stripe color and a "Fr3aK" logo. Bottoms are alternating light and dark bars, blue or black with white between. Visibilty is exceptional. Currently custom colors just aren't possible as I'm catching up on backlogged orders.
As these are starting to trickle out (two shipped already and 3 more shipping before end of December) you should start to see them at flying fields near you. I know at least four of these that will be at the JEM in January
Dan Fitzgerald is making wing bags for the SuperFr3aK that fit like a glove as expected. Those are available from Dan directly (danfitz) or from me. These bags give you sun protection as well as ding resistance to keep your Fr3aKs looking good and cool at the field.
Exciting times. I'll post pics of the current color scheme (simplified) later when I pull the first wing.
tom43004 is offline Find More Posts by tom43004
Old Dec 19, 2012, 12:37 PM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
outstanding feature evolution, Tom. I hope you are planning on a little time for yourself over the holidays...
MattN is offline Find More Posts by MattN
Old Dec 19, 2012, 01:10 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Yep Matt. I pulled a wing last night (carbon) and have materials prepped for three more. I'll drop a wing tonight, pull it tomorrow, drop another Friday, then I'm off 'till Sunday doing Christmas traveling.
Monday I'm back at it since I only have three fuses made currently... and I need to do tails again as well. This is exciting stuff now that I'm making good wings instead of scrap.
Here are pictures of the latest pull, which will be the normal full carbon layup. It's under 125g trimmed and as expected it's far stiffer than necessary. This one will be in a box headed out west in the next couple of days.
Enjoy the pictures. I'm SOO glad this one came out okay considering the materials cost.
Old Dec 19, 2012, 01:16 PM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
I love full carbon
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Joined May 2002
Yummy Tom, cant wait to see the kids at the JEM!
The beefy leading edge would save a guy like me much embarrassment when catching it the first time!
Old Dec 19, 2012, 01:32 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
When I shake loose some funds I'm going to have to get on the list for one. That is a beautiful plane Tom! Your work has come so far these past few years!
Gerald
G_T is offline Find More Posts by G_T
Old Dec 19, 2012, 01:54 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
That carbon wing is SWEET! Tom, your stuff keeps looking better and better. I hope you're quite proud of your work, because you have every right to be. Is your new foam hotwire-able or does it have to be machined?
bwill6 is offline Find More Posts by bwill6
Old Dec 19, 2012, 02:03 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Machined Brandon. It's PVC based.
Thanks for the complements guys.
Old Dec 19, 2012, 02:24 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Those are looking fantastic, Tom.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Dec 19, 2012, 02:31 PM
Techflyer is offline
Find More Posts by Techflyer
United States, FL, Melbourne
Joined Aug 2006
Simply Amazing...
Techflyer is offline Find More Posts by Techflyer
Old Dec 19, 2012, 02:39 PM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
What is the pricing on these, Tom?
New Product Park Zone's Ultra Micro Pole Cat............ ChuckTseeker Micro Ready-to-Fly 2726 May 26, 2016 09:03 PM
Sold Park Zone Chargers (3) 2,3and 4 cell outflying3d Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 30, 2011 09:35 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 12:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Discussion Does HobbyKing make anything like the Park Zone T28? lacofdfireman Electric Warbirds 2 Jun 24, 2011 07:32 AM
