Old Jul 16, 2012, 05:21 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Perfect Phil. Most of mine have a more vertical loop like yours shows. I didn't do a good job of photographing it.
2.5oz... OMG.
tom43004 is offline Find More Posts by tom43004
Old Jul 16, 2012, 05:23 PM
RetoF3X is offline
Find More Posts by RetoF3X
F3B and F3K
RetoF3X's Avatar
United States, TX, Dallas
Joined Mar 2009
Phil, why such a large cutout under the wing saddle? I normally try to minimize such cut outs (for wing connectors and such) and keep the fuselage as an integral tubular structure as good as it gets..
The ballast handle is nicely shaped and I like the double functionality (handle plus lock against the canopy).
Best,
Reto
RetoF3X is offline Find More Posts by RetoF3X
Old Jul 16, 2012, 06:05 PM
bwill6 is online now
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
Do you not use a ballast tube to keep the weight from bumping your control strings? I don't see anything like that in the pics.
bwill6 is online now Find More Posts by bwill6
Old Jul 16, 2012, 06:35 PM
Phil Barnes is online now
Find More Posts by Phil Barnes
Germantown, Maryland
Joined Apr 2004
I don't use strings. I use pushrods in teflon tubes. Strings are for girls and tampons.
I have a large cutout in the wing saddle area so that I can lay the underwing connector flat as a five pin wide connector. It made me cringe the first time I did it but I didn't want to change my standard wiring harness connector. I've subjected my Fr3aKs to lots of abuse, including Gavin launches and it has not been a problem.
Phil Barnes is online now Find More Posts by Phil Barnes
Old Jul 16, 2012, 07:52 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Thanks guys, just what I needed.
Gary
GaryO is offline Find More Posts by GaryO
Old Jul 16, 2012, 08:28 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
I use strings primarily because I'm lazy and I run the servo output horns on the throwing peg side of the fuse. When launch forces cause the ballast to push against the fuse side, it's opposite the strings.
I guess I launch like a girl then?
Old Jul 20, 2012, 05:44 PM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
I've gotten back in touch with the Fr3aK today. What had happened is that when I repaired the boom I had a little laminating resin on the wing saddle at the rear and I had smoothed it so well with the wrap that I didn't notice it there. It was holding the TE up a little. It flies sooo much better now. I did manage to hit an out of bounds flag with the stab and it cracked and the rudder came loose but those are easy to fix.
I also had a guy tape one of my launches last week and that was very enlightening too. I had begun to throw with too much up and I was hooking the launches too. I guess I was trying too hard. I simply relaxed a little and lowered my release trajectory and viola.... The launch went higher and with less effort. I guess we just need to remind ourselves of those things every so often.
Anyway, the Fr3aK should be good to go for the Nats.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Jul 21, 2012, 02:13 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Latest Project
Pictures from the shop last night. You could make a case that these look better BEFORE waxing and mold release than my old molds looked when I was pulling parts.
Skunkworks back online
I'm calling this the "Fr3aK TS" for now. With a little luck I'll have a wing from this mold set in the air for the NATs in eight days. Two piece molds mean no joiner wrap or process.
Old Jul 21, 2012, 02:30 PM
G_T is online now
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
Tom, those molds look really sweet!
Gerald
G_T is online now Find More Posts by G_T
Old Jul 21, 2012, 02:35 PM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
Looks kickass, Tom. Is that a can of elbow grease I see on the bench in the background?
MattN is offline Find More Posts by MattN
Old Jul 21, 2012, 02:38 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Nice. Yeah, I still have to use some lube on the stem of my fuse bladders or they won't fit.
No comments from the peanut gallery, please
Old Jul 21, 2012, 02:54 PM
G_T is online now
G_T
G_T
Joined Apr 2009
Try a drop of liquid hand soap instead.
Gerald
Old Jul 21, 2012, 09:24 PM
Gavin Trussell is offline
Find More Posts by Gavin Trussell
Team Horizon Pilot :)
O H I O
Joined Jul 2007
Sweet
Gavin Trussell is offline Find More Posts by Gavin Trussell
Old Jul 22, 2012, 08:08 AM
Joined Apr 2004
I just coat the bladder stem with baby powder. Any kind of liquid lube is too messy and I haven't quite figured out Gerald's method yet, maybe it would work well after seeing it done once.
To apply baby powder, just put some in the palm of your hand and pull the stem through a few times. Makes the stem just as slick as a babies behind.
Old Jul 22, 2012, 08:16 AM
I_Can't_Fly is offline
Find More Posts by I_Can't_Fly
But I am learning
I_Can't_Fly's Avatar
USA, MD, Cumberland
Joined Apr 2008
No comment
Brian P.
I_Can't_Fly is offline Find More Posts by I_Can't_Fly
New Product Park Zone's Ultra Micro Pole Cat............ ChuckTseeker Micro Ready-to-Fly 2725 Jun 19, 2015 01:54 PM
Sold Park Zone Chargers (3) 2,3and 4 cell outflying3d Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 30, 2011 09:35 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 12:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Discussion Does HobbyKing make anything like the Park Zone T28? lacofdfireman Electric Warbirds 2 Jun 24, 2011 07:32 AM
