Old Jul 16, 2012, 07:32 AM
austinhlg is offline
Find More Posts by austinhlg
United States, MD, Baltimore
Joined Feb 2007
Another Obnoxious F3K shirt! My girlfriend will love that! Sing me up espacialy if you are getting them in some equally obnoxious 80's color. Design graphics?
Sam IIRC the pockets are 1/2in deep and 3/4 in wide with 1/8th in bass wood shims clamped over a music wire matress per drela for spacing. They inner edge is 2 and 11/16 in from the root. Forgot to install in the molds on the first pull which made it much more painful. second wings pockets were installed during molding and came out super clean. You flying Sunday?
austinhlg is offline Find More Posts by austinhlg
Old Jul 16, 2012, 08:47 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Originally Posted by tom43004 View Post
Excellent Austin...
T-shirts are being printed and soon will be available for Fr3aK drivers and fans. They're a bit obnoxious but I'm sure you guys wouldn't want it any other way.
Preview please
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Jul 16, 2012, 08:54 AM
ThomasLee is online now
Find More Posts by ThomasLee
Team Hong Kong F3K
ThomasLee's Avatar
Hong Kong
Joined Sep 2010
Can't wait to see it Tom! I love F3K shirts!
ThomasLee is online now Find More Posts by ThomasLee
Latest blog entry: Vibe Assembly Instructions
Old Jul 16, 2012, 09:39 AM
BavarianCharles is online now
Find More Posts by BavarianCharles
Follow me to sink!
BavarianCharles's Avatar
85045
Joined Oct 2005
BSoAZ
It's a bit early, but .... Tom, are you planning to attend this year's Blue Skies Over Arizona, and if so, what (new) design can we expect?
BavarianCharles is online now Find More Posts by BavarianCharles
Old Jul 16, 2012, 10:07 AM
samc99us is online now
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
Thanks Austin. Might try it out on the next wing. Planning on flying Sunday, maybe with a new weapon, maybe not. If you bring your 80's Fr3aK shirt I'll be sure to stand on the opposite side of the field, don't want to be blinded ala disco.
samc99us is online now Find More Posts by samc99us
Old Jul 16, 2012, 10:31 AM
Joined Feb 2007
Come on I'm not that much older than you. Disco was the 70's! The 80's was Neon, Synthesizer, and Hairspray.
We now return you to your regularly scheduled programming.
Old Jul 16, 2012, 10:43 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
Everybody remembers the 80s. Here is a picture of Tom and the guys from Twisted Sister modeling several of Tom's shirt ideas. Personally Tom, I'd go for the blue one but you look good in the pink... I dunno. That's a tough choice.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old Jul 16, 2012, 01:41 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Somewhere in this thread (I think) is a pic of the ballast hold down. I seem to remember a piece of clothes pin? But I haven't been able to find it.
Whatever, I would like to set mine up for ballast, trying to figure out how to anchor it. Suggestions?
Gary
GaryO is offline Find More Posts by GaryO
Old Jul 16, 2012, 02:11 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Sorry, no Tshirt previews. It will be well done, rest assured. It's based on the "Get your Fr3aK on" theme.
Gary, Here are pics of my simple ballast installation. FYI this is 3/4 ounce of lead and with wire and all it's dead on 1oz (29g)
This is the "big" ballast, with the smaller one being half an ounce. I have never felt the need for more, though I know Phil has a 2oz setup.
tom43004 is offline Find More Posts by tom43004
Old Jul 16, 2012, 03:44 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Have you ever had the end slip out of the hole in the wood (during flight)?
jfinch is offline Find More Posts by jfinch
Old Jul 16, 2012, 03:54 PM
isoarthenland is offline
Find More Posts by isoarthenland
Russ Young
isoarthenland's Avatar
United States, UT, South Jordan
Joined Mar 2006
Screw a cut off servo arm adjacent to the wire, then swing it back and forth over the wire to hold it down or release it.
isoarthenland is offline Find More Posts by isoarthenland
Old Jul 16, 2012, 05:00 PM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
the canopy holds the wire into the block. as long as the canopy is well-attached, the wire can't come out of it's hole.
MattN is offline Find More Posts by MattN
Old Jul 16, 2012, 05:04 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
On mine, it's glued to the bottom of the fuse. The canopy doesn't hold it down. I use a .055 wire (same as flapperon) and a .055 drill. It's very snug the first few times you insert it... I've never had one loosen. I believe that the loop in the wire causes the forces on launch and landing to cause binding in the wire.
I've seen others use canopy-restricted systems (Brian P and MattN come to mind) but I've not done one that way.
Old Jul 16, 2012, 05:07 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Thanks. I like that simplicity.
Old Jul 16, 2012, 05:16 PM
Phil Barnes is online now
Find More Posts by Phil Barnes
Germantown, Maryland
Joined Apr 2004
I chose my 2.5oz ballast slug just for Tom. My lightest ballast slug is 1 oz.
The pictures show how the ballast wire is bent such that there is a handle which makes insertion and removal easy without tools. Also the handle portion just fits under the canopy, so the wire cannot lift until the canopy is removed.
There is a bit of 1/4" square balsa glued behind the aft servo. On top of that balsa is a little chip of 1/16" plywood with a hole. The ballast goes nowhere unless it shoves both servos out of the way first.
Phil Barnes is online now Find More Posts by Phil Barnes
New Product Park Zone's Ultra Micro Pole Cat............ ChuckTseeker Micro Ready-to-Fly 2726 May 26, 2016 09:03 PM
Sold Park Zone Chargers (3) 2,3and 4 cell outflying3d Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 30, 2011 09:35 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 12:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Discussion Does HobbyKing make anything like the Park Zone T28? lacofdfireman Electric Warbirds 2 Jun 24, 2011 07:32 AM
