Old May 07, 2012, 06:52 PM
I_Can't_Fly is online now
Find More Posts by I_Can't_Fly
But I am learning
I_Can't_Fly's Avatar
USA, MD, Cumberland
Joined Apr 2008
Thanks Rick, that helped answer both questions.
Brian P.
I_Can't_Fly is online now Find More Posts by I_Can't_Fly
Old May 08, 2012, 09:51 AM
Mr. Wiz is offline
Find More Posts by Mr. Wiz
Time for me to Fly...
Mr. Wiz's Avatar
United States, MI, Fenton
Joined Jan 2000
I flew the Fr3aK again this morning. This time it was sunny and there was some nice lift. The #1 thing I'm going to do before the next outing is add some white stripes to the wing bottom. I kept getting disoriented with it because the wing looks the same on top as bottom. I also think a colored fin would help.
After that, I want to try moving the CG rearward a little. I felt like I constantly had to hold in elevator to keep the nose up or trim it so it pulled too hard up on launch. My launches felt different today too. I think I'm going to lose the glove when flying this plane. The blade is comfortable enough without it.
Mostly, it's just a different plane and it's going to take some time to get adjusted to it.
Mr. Wiz is offline Find More Posts by Mr. Wiz
Old May 10, 2012, 10:14 AM
rdjay is offline
Find More Posts by rdjay
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
Tom,
I'm moving some of my gear around and want to use a 320 mah, 2s Hyperion battery in the nose. It fits, but the taper of fuse at the front restricts how far forward and I'd like to get it 1/4" or so further so I can fit in the rest of my gear.
I'm wondering if it would be possible to re-shape the nose slightly. I'm thinking I could make a wood "plug" the size of the battery, warm the end of the fuse in some boiling water and push the plug forward to stretch it out a bit.
Crazy? Stupid? Doable? What do you think?
Thanks, Rick
rdjay is offline Find More Posts by rdjay
Old May 10, 2012, 10:38 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Very likely will split the seam. Kevlar doesn't stretch and there's not a lot of seam overlap up there. Get one of the 350 or 360 Rhino or Zippy packs... they slide WAAAY up in there. If you need a couple I can mail you some.
tom43004 is offline Find More Posts by tom43004
Old May 10, 2012, 10:40 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
Opinion
Warping such a beautiful, well made fuse is crazy talk
What servos are you using? I'll wager that your two servos, the tray and the glue to hold it all probably weighs the same if not a titch more than that battery...
Possible solution : Regulator and receiver in the nose, servos at the front of the canopy opening and the battery behind the servos?
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old May 10, 2012, 10:53 AM
rdjay is offline
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
You guys are right, it was crazy talk.
I've been using the 360's and they fit nicely. I'm trying to get my RX in the nose on top of the battery and the 360's are just a bit to thick. They 320 Hyperions are thinner but wider so they don't go as far forward and get in the way of my PD regulator. I was looking for an easy way without moving my servo tray and/or regulator.
Maybe I'll just squish the end of the battery in my vise, you know put a taper on the end of it....... Just kidding...
RdJay
Old May 10, 2012, 10:56 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
I know I sound like a broken record but the Shread 450 fits in the nose with all kinds of room to spare. I can get a solid 2 hours of flying out of that system but YMMV. I should post a photo of the inside of my pod just to show people. I think I will do that this evening.
Old May 10, 2012, 06:38 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Where do you get the Shread stuff?
davidjensen is offline Find More Posts by davidjensen
Old May 10, 2012, 06:48 PM
jbarnhardt is offline
Find More Posts by jbarnhardt
jbarnhardt's Avatar
United States, WA, Seattle
Joined May 2011
http://www.kennedycomposites.com/batteries.htm#
jbarnhardt is offline Find More Posts by jbarnhardt
Latest blog entry: Latest creation...
Old May 11, 2012, 06:14 AM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Wow. I pay $4 for my LiPos and make my own regulators.
I'm sure they're good stuff but jeesh!
Old May 11, 2012, 07:58 AM
roydor is offline
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
+1
Also, when considering the power available, 2S 350mAh batteries have 1.5 times more power then 450 mAh 1 cell batteries (3.7V*0.45Ah=1.665 Wh Vs. 3.7V*2*0.35Ah=2.59Wh) which translates to grater flying time (even after taking into account the efficiency of the regulators)
roydor is offline Find More Posts by roydor
Old May 11, 2012, 08:00 AM
Jan_B is offline
Find More Posts by Jan_B
Therwil, BL, Switzerland
Joined Nov 2006
Please try to keep the units correct: 3.7 V * 0.45 Ah = 1.665 Wh
(sorry, pet peeve)
Jan_B is offline Find More Posts by Jan_B
Old May 11, 2012, 08:48 AM
roydor is offline
roydor's Avatar
Israel
Joined Nov 2006
I always forget that little "h"
corrected
Old May 11, 2012, 10:00 AM
Mr. Wiz is offline
Mr. Wiz's Avatar
Joined Jan 2000
For what it's worth, they are far more than just a battery and a regulator. I've kind of beat this one to death here but when I see you next time I'll show it to you. I'll just say it's a very convenient system is a tiny package.... and yeah, you pay for the convenience.
Old May 11, 2012, 10:36 AM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
I'm with Tom on this one - but go one further. A cheap one-cell LiPo with no regulator/booster. I like eliminating components connectors, and wires (= potential points of failure).
MattN is offline Find More Posts by MattN
New Product Park Zone's Ultra Micro Pole Cat............ ChuckTseeker Micro Ready-to-Fly 2725 Jun 19, 2015 01:54 PM
Sold Park Zone Chargers (3) 2,3and 4 cell outflying3d Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jun 30, 2011 09:35 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 12:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Discussion Does HobbyKing make anything like the Park Zone T28? lacofdfireman Electric Warbirds 2 Jun 24, 2011 07:32 AM
