This thread is privately moderated by Tartago, who may elect to delete unwanted replies.
Old Jul 02, 2011, 07:21 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
FMS F-15 Strike Eagle
Nice EPS plane.
Less than 30 min to assemble. I gave her 2 coats of clear ronseal waterbase varnish to protect the porous paint.
I used a nano-tech 2200 25C 3S for maiden.
The plane took of like it was on rails. The recommended CG was right (amazing ).
Landing was very easy because she floats nicely. I kept the speed around 1/4 throttle and with a very shallow angle.
The third flight I was worried about the plane getting out of the landing strip and I reduced throttle too much. She started jumping and ended on her side, breaking the weakest point that is the fuse behind the cockpit. A little of Gorilla and she's ready again.
Tartago is offline Find More Posts by Tartago
Old Jul 02, 2011, 07:22 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
F-15 Maiden flight video
Thanks to Dino for the shooting.
FMS F-15 Strike Eagle maiden flight (3 min 0 sec)
Old Jul 02, 2011, 07:33 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Crash and repair
EPS is nice and light, but its extremely fragile.
But with Gorilla it can be fixed in minutes. Remember that this glue expands, so clamp/anchor the parts for better results.
Old Jul 23, 2011, 02:30 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Crashed and repaired
Barely noticeable from the air.
Old Jun 02, 2012, 06:43 AM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
Wow nice review!!!
Ive been looking at these FMS F-15 64mm and the other Blitzworks F-15 70mm they are about the same but this one is 300gr lighter.
Witch one would you think will be the better one
chester2240 is offline Find More Posts by chester2240
Old Jun 02, 2012, 06:55 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Originally Posted by chester2240 View Post
Wow nice review!!!
They are quite different. This one you can fly with a cheap 2200 3s battery.
Is smaller, so you can put her in the car trunk easily. Also only 3 channels needed. The other is more scale but you pay a price for it.
Old Jun 02, 2012, 07:22 AM
Joined Jul 2011
Thanks for the reply.
i think ill get this one it looks more simply and your video looks to have better handling and more power.
Ive been wanting to get a F-15 and put canards on it to make into a F-15 /MTD or active,it would be interesting to see how much lift and maneuverability it will gain with the canards.
Old Aug 17, 2012, 02:47 PM
tengarang is online now
Find More Posts by tengarang
Fly Straight Fly High
tengarang's Avatar
United States, CA, San Jose
Joined Aug 2010
Subscribing
Just got the Sky Camo ARF from BanannaHobbies. Too Bad Nitroplanes is out of stock, been a loyal customer with Nitro. I will start my evaluation with Bananna Hobbies, hope all goes well.
Do you guys know what ESC the ARF comes with? The reason I ask is because I bought a F-35 from nitroplanes, the advertisement says 30A esc, but in actuality it is 35 amp esc which allows for 4s with no modification....i wonder if this is the case for the same line 64mm f-15.
tengarang is online now Find More Posts by tengarang
Old Aug 22, 2012, 09:15 PM
Joined Jul 2011
Hmm my guess would be they are the same because they are made by the same company but i could be wrong, its best to take it out and compare the 2 to each other.
Old Aug 23, 2012, 12:00 AM
tengarang's Avatar
Joined Aug 2010
i switched out my order to desert camo, since the grey color is on backorder, lord knows when it will be back in stock.
Im planning on running 4s with 4800kv motor. will require 60 amp esc.
this is the fan I intend on using for both motors
http://www.hobbyking.com/hobbyking/s...dProduct=11163
http://www.hobbyking.com/hobbyking/s...dProduct=10923
http://www.nitroplanes.com/75m95-ducted-2215-4800.html
going to be 4s 1800 mah for starters heard the doppler will be 80 mph...great for this size edf.
Old Aug 23, 2012, 09:23 AM
Joined Jul 2011
I wonder if you can hog out some foam and fit a 70mm edf system?
Old Aug 23, 2012, 11:17 AM
tengarang's Avatar
Joined Aug 2010
That would be kick ass if you could pull that off
Old Aug 27, 2012, 03:05 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Or maybe a Mercury EDF 64mm on 4s. That demon hauls my T-45!
Old Aug 27, 2012, 11:14 AM
tengarang's Avatar
Joined Aug 2010
maidened the stock setup today with a 2200mah 4s. I was hitting the temperature clamp on the stock 35A esc....and would momentarily cutt power during flight....which is why I was proud of myself for putting an external 5A bec with its own 400mah 2s supply...over all it flew great...alittle tail heavy so Ill just scoot the battery forward alittle. brought it back in one piece.
Now Im going to put a hobbyking blue series 70 4A bec in it to avoid the power outtage. Going to put a exceed 4800KV motor with the stock fan..should give enough beef for the heat.
Old Aug 27, 2012, 07:43 PM
Joined Jul 2011
Im not to sure the stock fan can hadle that kinda power.
But it would be nice to find out !!! just make sure its balanced
Sold Brand New F-15 Strike Eagle RTF w/ Brushless Ducted Turbo Fan with Retracks RAM-THIS Aircraft - Electric - Jets (FS/W) 0 Jan 04, 2009 11:50 AM
Video F-15 Strike Eagle gooseman Electric Plane Talk 2 Feb 01, 2008 04:53 PM
Sold EAM F-15 Strike Eagle netmechanic Aircraft - Electric - Jets (FS/W) 3 Jul 14, 2006 09:58 AM
FS Green Air Designs F-15 Strike Eagle charlie hepler Aircraft - Electric - Airplanes (FS/W) 11 Jan 25, 2005 11:26 PM
