Old Jul 01, 2011, 09:23 PM
john_53_70 is offline
Find More Posts by john_53_70
john_53_70's Avatar
south alabama
Joined Dec 2010
Help!
How do I cover a epo plane in fiberglass
How do I cover a epo plane in fiberglass I don't mind adding a little weight, but what kind of fiberglass and epox do I use, and where is the best place to get the stuff to do it
john_53_70 is offline Find More Posts by john_53_70
Old Jul 01, 2011, 09:29 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
First question is why are you doing this? What is the outcome you expect by covering the foam with glass?
Rigid?
smooth?
better paint surface?
Why?
That will help determine what you need.
aeajr is offline Find More Posts by aeajr
Old Jul 01, 2011, 10:20 PM
john_53_70's Avatar
south alabama
Joined Dec 2010
well I have a epo plane I crashed and its not to bad the idea is to fiberglass it paint it and then fly it thats option one secound on is to make it a pluge for a mold i kinda like the secound idea the best, so make a good smooth surface
Old Jul 02, 2011, 04:11 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I am not a master of glassing EPO foam, but I would use 3/4 ounce fiberglass cloth and finsihing epoxy to do the job if you plan to fly it. That will keep the weight down.
Finishing epoxy. Made for glassing and smooth finish rather than as a strong adheasive.
http://www3.towerhobbies.com/cgi-bin...?&I=LXK304&P=7
If you don't plan to fly it, then use 2 oz cloth to make it more rigid for use as a plug. Weight won't be a factor here.
Old Jul 11, 2011, 04:42 PM
robbthepilot is offline
Find More Posts by robbthepilot
Victoria B.C. Canada
Joined Aug 2007
Use water based poly urathane and 1/2 to 3/4oz cloth. paint on ploy. lay on cloth, paint on more poly to saturate and smooth out. Water will evaporate and you will ave a nice strong finish. I do all my foamies this way.
robbthepilot is offline Find More Posts by robbthepilot
Old Jul 11, 2011, 05:45 PM
MS_in_NY is offline
Find More Posts by MS_in_NY
MS_in_NY's Avatar
Joined Oct 2009
I get my glass here...
http://www.thayercraft.com/index.htm
...and epoxy resin here...
http://www.clcboats.com/index.php
I've had good luck with the MAS resin and slow hardener. Very thin, long pot life, applies easily with a brush or foam trim roller. The foam roller works better than a brush for wetting out cloth to a consistant saturation and minimizes the need to blot up excess resin.
.......Mike
MS_in_NY is offline Find More Posts by MS_in_NY
Old Jul 11, 2011, 09:59 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Since the underlying structure is flexible foam you may need something thicker than 3/4 oz cloth or it may tend to crack. You may need 2 or three layers of 3/4, probably set on a bias. Not sure how it will hold up with that flexy under structure.
Discussion How do I cover a epo plane in fiberglass john_53_70 Composites Fabrication 2 Jul 05, 2011 09:41 PM
Discussion How do I cover a balsa sheeted plane u2builder Scale Fuel Planes 5 Mar 14, 2011 04:01 PM
Question How do you cover a balsa sheeted fuselage with compound curves with fiberglass? Bolt55 Scale Sailplanes 5 Aug 09, 2010 06:17 PM
Question How do I fiberglass a foam plane? taekwondo Electric Warbirds 13 May 10, 2006 08:37 AM
Discussion How do I fiberglass a foam plane? taekwondo Foamies (Kits) 11 Jan 16, 2006 03:28 PM
