Old Aug 24, 2012, 04:49 AM
prondel is offline
Find More Posts by prondel
prondel's Avatar
France
Joined Aug 2003
I think there is something wrong in my spreasheet regarding the variation of CoG
initially the formula I used was:
variation = factor / ballast weight
I was wondering if it should be instead: variation = factor / (ballast weight + plane weight)
comments are welcome ...
Cheers,
Pierre
prondel is offline Find More Posts by prondel
Old Aug 24, 2012, 05:33 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
hi Pierre,
Yes I think you need to combine the weight of the plane plus ballast. I.e total weight of the airframe.
I'll try to have a think of the formula whilst eating lunch. Too much like friday.....
Tom
satinet is offline Find More Posts by satinet
Old Aug 24, 2012, 01:25 PM
Alvaro Silgado is offline
Find More Posts by Alvaro Silgado
Alvaro Silgado's Avatar
Madrid, Spain
Joined Sep 2004
Nice training day! Lot of crossed wind (5-9 m/s), changing from -60º to 45º on its orientation. High temperature and very dense air, perfect for the Precision!
Entrenando con el Pike Precision (6 min 41 sec)
Regards,
Al.
Alvaro Silgado is offline Find More Posts by Alvaro Silgado
Old Aug 26, 2012, 11:22 AM
Ja9 is offline
Ja9
Find More Posts by Ja9
Ja9
Norway, Rogaland, Tjelta
Joined Dec 2004
Finally got to maiden the Precision today. Wind was blowing around14m/s ( around 30mph) so the maiden flight was done with around 1,5kg of ballast.
Still it was very gentle to fly.
Ja9 is offline Find More Posts by Ja9
Old Aug 26, 2012, 09:15 PM
ibuild is offline
Find More Posts by ibuild
closed due to popular demand
Joined Jul 2011
ibuild is offline Find More Posts by ibuild
Old Aug 29, 2012, 06:27 AM
prondel is offline
prondel's Avatar
France
Joined Aug 2003
New and generic spreadsheet
I revisited the formula for the variation of the CoG based on the file ballast_cg_graffiti_xls and I produce a generic spreadsheet for F3X plane, including a fuselage compartiment.
It gives more consistent result now
The spreadsheet highlights in red when the wing load is above 75g/dm2
Cheers,
Pierre
Old Aug 29, 2012, 07:06 AM
FLY N HIGH is offline
Find More Posts by FLY N HIGH
FLY N HIGH's Avatar
The WALL
Joined Dec 2010
Help
Gday,
I flew my Precision today, full ballast in 23knots(not sure m's that is?)Had the plane working hard for 30minutes or so, untill the right aleron servo went dead on me mid flight!,my first throught was flat battery as this was not my first flight of the day.I battled to pick the wing up and get enough control to fly to the landing zone. Landed with no damage.I walk up and had a quick look and yes right side ron was dead. Took RX out, and wiggle with wiring, with no success still not working? 10mins later at the car I removed the wing then put wing back on and now it works ?
Do theses MKS servos over heat?
I have 5 cell battery.
This servo was "jumping" abit form new.
I have a clean wing, no servo holes.
This has rattled me for next comp in 2 weeks.
I came very close to loosing model.
Any thoughts ?
Chad M
FLY N HIGH is offline Find More Posts by FLY N HIGH
Old Aug 29, 2012, 07:26 AM
Ja9 is offline
Ja9
Ja9
Joined Dec 2004
23knots = 11,8m/s
I dont think the MKS servos like a 5cell battery to without any type of regulator.
This is clearly stated on the MKS homepage:
please use 4S Nicd/NiMH or use UBEC @ 4.8V~5.5V
Not sure if this is the problem with your servo.
Old Aug 29, 2012, 10:55 AM
David Olson is online now
Find More Posts by David Olson
MCS / NCSS / SVSS / LSC / SAM
David Olson's Avatar
United States, CA, Santa Rosa
Joined Jun 2010
Chad:
MKS is the only servo that can not handle an unregulated 5 cell pack. All others seem to be able to handle 6 volts just fine. I believe MKS's specs state nothing over 5.8 volts. What seems very misleading is they also publish torque ratings for 6 volts.
If you want to run a 5 cell pack you must run a regulator at least on the MKS servos.
I have been following this thread and is where I discovered this information:
http://www.rcgroups.com/forums/showthread.php?t=1554075
Nice job getting your plane back by the way.
Dave
David Olson is online now Find More Posts by David Olson
Old Aug 29, 2012, 11:40 AM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
I've seen people show up at the field for a maiden and have 6125 servos start failing before they can even get the plane airborne. They absolutely do not survive anything over 4sNi.
I'm surprised it was your aileron though since that servo gets the lowest voltage. Usually it's the fuselage servos that fail first, followed by flaps of course. I'd guess you have non-MKS servos on the tail and little/no flaperon coupling. Your aileron servos may be on borrowed time now -- I don't know of any thermal shutdown safety feature on these servos, I think they usually just work until they fail.
vespa is offline Find More Posts by vespa
Old Aug 29, 2012, 02:57 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Knock on wood, I have had (2) 6125's [Flaps] and (2) 6125H's [fuse] in my 4.0 Xplorer since day one on 2S unregulated LiFe....
I think a lot has to do with the load on the linkages.
I have 2, maybe 3 seasons on the Xplorer, flown almost every weekend for about an hour per session.
R,
Target
target is offline Find More Posts by target
Old Aug 29, 2012, 03:45 PM
vespa is offline
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Wow! Yes of course it's greatly dependent on the loads and friction but still, I hope you have a v-tail!
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Nope.
Cross tail.
Old Aug 30, 2012, 01:18 AM
glderguy is offline
Find More Posts by glderguy
4 wheels move a body; 2 a soul
Saratoga, Ca
Joined Feb 2004
Im not overly happy with one of my new MKS servos in my Precision, it too has "jumped" around from day one. Flap servo, 4.8v. I worry about these servos on the tail surfaces as well.
glderguy is offline Find More Posts by glderguy
Old Aug 31, 2012, 06:25 AM
FLY N HIGH's Avatar
The WALL
Joined Dec 2010
Guys I will be replacing the 5cell down to 4 Plus checking the plugs again.
Heres my Precision at a F3Fcomp, cranking!
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 09:00 PM
New Product Samba Model - Pike Precision F3B/F PDX Slope Pilot Multi Task F3X 11 Apr 08, 2011 12:59 PM
Sold Samba Pike-V F3B/F3F bigslopegrin Aircraft - Sailplanes (FS/W) 3 Jan 17, 2011 10:21 AM
Sold Estrella "DP" F3F / F3B Model Kyle Paulson Aircraft - Sailplanes (FS/W) 0 Mar 15, 2010 10:10 PM
Sold Pike Giant X-Tail F3B/F3F - Damaged PDX Slope Pilot Aircraft - Sailplanes (FS/W) 4 May 18, 2009 01:13 AM
