Old Jun 30, 2011, 04:11 PM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Best HK charger for my purposes (3s lipos + TX ?
Hi all
Currently I am using the simple lipo charger that came with my ESKY heli to charge all my lipos, and it works great, balances almost perfect everytime. I'm not in a hurry, so slow charge is just fine. I was using a second one, but it started to unbalance wildly after a fem months:
http://www.hobbyking.com/hobbyking/s...idProduct=7637
Before that I was using this B6 charger, but 2nd use the display fizzed out, making it useless:
http://www.hobbyking.com/hobbyking/s...idProduct=5548
These 2 above chargers, I was using a modified 12v PC PSU for power, as I couldnt find a suitable wall plug. It worked OK, but I am wondering if it may have caused the early demise of the chargers. The ESKY charger uses its own proper wall jack.
Also, I just bought the LSD NIHMs for my Futaba FF8 TX:
http://www.hobbyking.com/hobbyking/s...dproduct=10456
My Futaba has no wall charger, so I have nothing when the charge runs out.
Can you recommend a charger that will allow me to charge more lipos and my TX?
I'm not in a hurry, and I prefer cheap. Also, I currently live in Japan, so shipping is more expensive. Thanks for any help.
EDIT: I just noticed I have several wall plugs that give 12v 1a output. I plugged these into my 2 cheapy chargers and they seem to be working. Thought Id check if its safe just in case. Thanks. The original ESKY plug/charger is here:
http://www.heli-fever.com/product_in...86vgi0aikfrc50
That plug calls for 12v 1.5 amp input. The HK charger had no specs other than 12v input. Is it OK to use my 12v 1a plugs for these 2 chargers?
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Jun 30, 2011, 05:59 PM
RedStarArmy is offline
Find More Posts by RedStarArmy
RedStarArmy's Avatar
United States, NJ, Middlesex
Joined Feb 2008
Should be fine as long as polarity is the same. You can also go to ebay or whatever Japan uses, and get an old 12v 5amp laptop power supply. I picked one up for $10 shipped and it has worked great on 5amp chargers.
RedStarArmy is offline Find More Posts by RedStarArmy
Old Jun 30, 2011, 07:30 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
There are quite a few decent chargers at hobbyking but can you tell us more about the capacity of the packs.
lipoflyer is offline Find More Posts by lipoflyer
Old Jun 30, 2011, 07:39 PM
Expat
Japan
Joined Apr 2010
Good call on the laptop plug. Ill check it out.
The cheapy HK charger sucks. It always left the cells unbalanced, and now it leaves them WAY out. Just tried it using several power sources. The charged 1000mah 3s reades:
4.06
4.07
3.73
And the charger gets really hot.
I'm looking to cvharge a range of 3s lipos from 300-2200 mah. The TX batteries are NIHMs in the link using the Futaba servo plug or preferably the TX's side jack.
Old Jul 03, 2011, 02:48 AM
lipoflyer's Avatar
Australia
Joined Nov 2010
4.06
4.07
3.73
what are you using to read these values?
Old Jul 04, 2011, 09:00 AM
Expat
Japan
Joined Apr 2010
I'm using one of these
http://www.hobbyking.com/hobbyking/s...idProduct=6589
Is it worth taking another chance on one of these? I could try to find an old 12v 5a laptop plug as mentioned.
http://www.hobbyking.com/hobbyking/s...idproduct=5548
this appears to be good? But out of stock forever I guess:
http://www.hobbyking.com/hobbyking/s...idProduct=7028
Old Jul 04, 2011, 06:26 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
I am sure my mate had an IMAX and wasn't too happy with the balancing.
Accucel-6 that i've got seems to be pretty decent and at a good price.
Old Jul 05, 2011, 02:32 AM
Expat
Japan
Joined Apr 2010
The hk site says accucells backorder AND instock within a couple of days. Should I prepay for one, or is it a trick?
Old Jul 05, 2011, 02:46 AM
RedLine19k is offline
Find More Posts by RedLine19k
United States, OH, Youngstown
Joined Nov 2004
[QUOTE=TheNiceGuy;18669651]I'm using one of these
Might want to double check with a reliable voltmeter. I had one of those HK testers and it was so far off I stopped using it immediately.
I have 3 of the Accucell 6s and they work great! The AUS warehouse has them in stock, but they are more expensive :/ If you aren't in a hurry and it's all you need, you could pre-order one and take your chances waiting.
The laptop power supply works great also, as long as you stay under max amps. Good luck.
RedLine19k is offline Find More Posts by RedLine19k
Old Jul 06, 2011, 11:31 PM
Expat
Japan
Joined Apr 2010
Thanks, I'll wait till actualy in stock.
I've never used a voltmeter. Can you recommend a cheap one off EBAY that ships to Japan?
This is really cheap - bad idea?
http://cgi.ebay.com/New-LCD-Digital-...item4cf0f6ab33
Old Jul 07, 2011, 05:35 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Search for a VC97, it is excellent value for money.
kgfly is offline Find More Posts by kgfly
Old Jul 09, 2011, 11:17 AM
Expat
Japan
Joined Apr 2010
Is this the one you refer to?:
http://cgi.ebay.com/F01729-Auto-Rang...item3f0ae175b2
If so I'll buy it. I'll have to learn what all the buttons mean! Never used one before!
Old Jul 09, 2011, 03:22 PM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Hi there.
In the boating side of things we use this for checking packs before & after runs. they are very accurate & also give you the capacity percentage (in mah) remaining in the pack & individual cells. Also does receiver packs.
Does Li-lon, Lipo, & Li-Fe
http://www.offshoreelectrics.com/pro...Sentry&cat=123
I've had a few of those little battery monitors & each one of them had at least one of the cell readings way off when compared to a voltmeter.
I've been using this charger for the last two years without a problem if it's any help.
http://www.hobbyking.com/hobbycity/s...dProduct=15044
Cheers.
Paul.
785boats is online now Find More Posts by 785boats
Old Jul 09, 2011, 07:18 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
whilst i would not backorder everything on their site i would backorder this as they do come in all the time.
Old Jul 09, 2011, 07:19 PM
lipoflyer's Avatar
Australia
Joined Nov 2010
looks reasonable
Discussion Need Hitec X4 Charger Balance Board For Eflite 3S 11.1V 3200Ah Lipo? itsme2 Batteries and Chargers 2 Jul 22, 2011 10:38 AM
Sold Turnigy nano-Tech 2650 3S 25c lipos for SALE!!! joeyhatch11 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jun 28, 2011 06:53 AM
Discussion Best Lipo Charger for 3S-5S Lipos? fltekdiver Batteries and Chargers 24 Sep 19, 2010 08:57 PM
Discussion Best cheap lipo charger for ~3s lipos polar8 Batteries and Chargers 21 Dec 21, 2007 09:50 PM
BEST motor for Minifan and 3s Lipos in my A-4 EricBjorn Electric Ducted Fan Jet Talk 10 Dec 07, 2004 06:10 PM
