Old Jun 30, 2011, 11:28 AM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
Turbo Cad
Anyone know how to make simple accurate incremental breaks in a straight line. Need it to set up a cut file for laser so the parts will stay attached to the sheet.
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Jun 30, 2011, 11:38 AM
ScorpionRacing is online now
Find More Posts by ScorpionRacing
NMPRA 86T
ScorpionRacing's Avatar
United States, FL, Winter Haven
I usually just draw a vertical (or horizontal) line and offset it by the gap distance your laser cutter requires. I then select the "trim" command, then the lines I just drew, and trim out the lines between them.
I also try to align most of the lines so that the tab you trim off will be with the grain so it is easier to trim. It is a little bit of a trial & error as the size varies from the type of material and the thickness of the parts. Sometimes they will give you different gap distances for different materials and sizes, so you may want to ask them about that.
Good Luck,
ScorpionRacing is online now Find More Posts by ScorpionRacing
Old Jun 30, 2011, 01:49 PM
Dylwad is offline
Find More Posts by Dylwad
Dylwad's Avatar
Phoenix,Arizona, United States
Joined Jun 2002
I use double lines set to the correct width, if you need 6 breaks in a straight line, place the outer 2 double lines where you want them along the line , and the middle 4 anywhere along the line, select all of the double lines and use the distribute even horizontal or verticle to make them equal distances from each other, I then make all of the double lines a group, hit the trim command, select the group of doubles and trim between all of them, and hit the cut button while they are all still selected with the trim command to delete all of the double lines at the same time.
Its easier and faster than it sounds
Dylwad is offline Find More Posts by Dylwad
Old Jun 30, 2011, 03:57 PM
Joined Nov 2009
Thanks guys, both of those sound like great workable ideas.
John
Old Jul 01, 2011, 02:36 PM
jregholdsworth is offline
Find More Posts by jregholdsworth
Joined Jul 2006
devcad cam?
jregholdsworth is offline Find More Posts by jregholdsworth
Discussion Turbo-cad problem coosbaylumber Vintage & Old-Timer Designs 1 Mar 19, 2011 03:10 PM
Turbo Cad LE and thanks for showing me the light. BillH The Builders Workshop 2 Dec 17, 2002 09:27 PM
Turbo CAD Question pgleesonuk Power Systems 2 Feb 23, 2002 06:13 AM
Turbo Cad printing Lutin Electric Plane Talk 7 Feb 07, 2002 10:48 AM
Turbo cad, the idiots guide. Oneson1 Electric Plane Talk 1 Oct 04, 2001 02:31 PM
