Old Jun 30, 2011, 11:06 AM
igo is offline
igo
Find More Posts by igo
igo
Joined Apr 2004
Build Log
Guillow Typhoon #906 conversion
hello All, as a kid, i remembered thumbing through a book of planes and came across the hawker typhoon. i really digged that menacing square jaw up front. then i flipped the page and saw the tempest and liked it even more mainly because of the nicer tail. so here i am with the guillow typhoon kit # 906 and the tempest tail i'm bashing in. guts will be mcx brick, motor/gearbox/prop from mosquito. stock balsa will be used, glues will be gorilla throughout all balsa parts and CA for landing gear parts. other parts will be heat shrink tubing for guides, piano wire, bamboo stick to bridge the elevator halves, parts of a gws prop for control horns and foam block for nose.
igo is offline Find More Posts by igo
Old Jun 30, 2011, 11:21 AM
Yellow Baron is offline
Find More Posts by Yellow Baron
Back in the game.
Yellow Baron's Avatar
3" from insanity, 2' from the computer ,Richford, Tioga county, Southern Tier, New York, U.S., North American Continent, Northern hemisphere, Earth, The Sol System, Milkyway Galaxy, The Universe, The Current Dimension, Your Selected Realm of Reality.
Joined Dec 2006
The MCX's brick won't be able to handle the Mosquito motor and prop from what I've heard, you'll need an AR6400.
Yellow Baron is offline Find More Posts by Yellow Baron
Old Jun 30, 2011, 01:47 PM
igo is offline
igo
igo
Joined Apr 2004
yellow baron, that's interesting. can you or someone verify that? i've actually test run the set up and it seems to work fine.
Old Jul 02, 2011, 08:33 AM
Back in the game.
Joined Dec 2006
I'll have to dig around some after the holiday. if it seems to be working fine for you then by all means have at it!
Old Jul 05, 2011, 03:42 PM
igo is offline
igo
igo
Joined Apr 2004
tail elevator build
here's what i have for the elevator and rudder. this plane will be rudder elevator and throttle. the rudder is the biggest departure from original guillow design. the rudder is scratch built.
Old Jul 06, 2011, 11:30 PM
Truckerboy is offline
Find More Posts by Truckerboy
Joined Oct 2009
Nice!! What's the weight so far?
I think you should add one more stringer between the leading edge and the first stringer. This would make it look less like a "starved horse" when covered, if you know what I mean. And the stringers in the rear should go all the way to the end of the fuselage. Other than that it's a really nice build and I can't wait to see more pics!
Truckerboy is offline Find More Posts by Truckerboy
Old Jul 06, 2011, 11:41 PM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
igo,
I'm following along quietly. Good job so far! I agree with the few little details that Truckerboy mentioned, but you are moving right along!
-Kody
PiperCub49 is offline Find More Posts by PiperCub49
Old Jul 07, 2011, 01:01 PM
Barrett_G is offline
Find More Posts by Barrett_G
Barrett_G's Avatar
Joined Mar 2011
Looking really good!
I bought an Avenger kit to do the same thing.. Will be following as well!
Barrett_G is offline Find More Posts by Barrett_G
Old Jul 07, 2011, 05:09 PM
igo is offline
igo
igo
Joined Apr 2004
truckerboy, that's a good analogy about the starved horse. i've already bashed the rudder so i shouldn't stop there. but i did. why? most likely because as good as that advice is, i'm too lazy to do it. some tissue covered pics are on the way...
barrett g, i just finished building the avenger. mine weighs 1.5oz now due to repairs. here's the link.
http://www.rcgroups.com/forums/showt...uillow+avenger
Old Jul 07, 2011, 08:04 PM
igo is offline
igo
igo
Joined Apr 2004
more fit checking with some covered parts
they look like i glued the wings on but it's just fit checking. wt at this point is 1.1oz. using stock wood. somehow i lost a few pictures of the control wires to the mcx brick, close up pictures of the placement of the brick and close up pictures of the motor mounting. sorry.
Old Jul 08, 2011, 12:33 PM
igo is offline
igo
igo
Joined Apr 2004
one of the features i liked most about this plane is that the landing gear is space wide apart and the wheels are way ahead of the cg. it makes landing very easy. the landing gear wire design is long enough to act like cantilever beams. i'll get some pics of that soon.
Old Jul 09, 2011, 02:16 PM
igo is offline
igo
igo
Joined Apr 2004
all covered up
here's the plane all covered up. the green tissue is not stock. i wanted something bright and found green tissue. i'm sure it's heavy but i'm going for it anyway. the color reminds me of parakeet.
Old Jul 12, 2011, 09:55 AM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
igo,
Great job...
Pete
mtflyr is offline Find More Posts by mtflyr
Build Log guillow avenger mcx conversion- Video Update igo Scratchbuilt Indoor and Micro Models 31 Oct 03, 2011 07:42 PM
Discussion Guillow's fw-190 conversion barrowaj Scale Kit/Scratch Built 6 Aug 22, 2011 04:39 AM
Yippee! Guillow Cessna 150 Conversion with Video igo Scratchbuilt Indoor and Micro Models 2 May 25, 2011 11:32 AM
Help! FW-190 Guillow's Conversion (kit 502) QasimZ. Scale Kit/Scratch Built 2 Mar 07, 2011 08:25 AM
Build Log Guillows Typhoon Kit 906 Slow_Buzz Scale Kit/Scratch Built 34 Jun 21, 2010 12:42 PM
