Jul 18, 2011, 10:41 AM
United States, CA, Temecula
Joined Sep 2009
Really great work!
Crash
Great build and the boat is looks magnificent. I think we have discussed this but if not it is worth sharing with you. I see you have used the line that comes with the boat for your rigging. Most of the guys I know that have done that, found that the line will sooner or later be cut by the holes in the spreaders. Even when you de-bur the holes.
I replaced all the "string" like lines with 1 x 7 SS nylon coated leader - it takes some effort to get the lines all taught and the spreaders level, but is worth the time and effort. The mast becomes a very strong assembly that will hold up in any kind of weather.
I guess you could find some small tubing to make sleeves or guides for the spreaders, but those typically don't stay in place.
Sorry you had the issue with the spline on the servo arm. I will continue to search for the Futaba S3801 sail servos and when I find another one, I'll call you.
The best servo I have ever used!!
Boomer
