Old Jan 29, 2013, 08:29 AM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Well it finally happened
Dumb thumbs. Taxing it back from the runway I gunned it a little and ran right into the net/pole that protects the pilots. I usually taxi to the end but nobody was out flying so figured what the heck.
Of course 3dhs is out of stock on the wing.
It broke between the ribs so should be an easy fix. Just going to have to buy a couple rolls of ultracote now.
I assume black but what blue color do they use?
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Jan 29, 2013, 08:39 AM
astropuppy is offline
Find More Posts by astropuppy
United States, ID, Boise
Joined Feb 2002
that is very fixable. Popsicle stick backer and a balsa patch.
astropuppy is offline Find More Posts by astropuppy
Old Jan 29, 2013, 09:04 AM
Mr_McGlue's Avatar
Joined Sep 2011
Yeah would rather fix it instead of buying a new wing. Here is a pic with some covering removed. The leading edge is sheeted so should be able to make a patch for that. Ultracote is going to cost more than a new wing wold But I can use that for other things I'm building.
Was going to enter a contest coming up but I was behind practicing anyway.
Robert
Old Jan 29, 2013, 10:51 AM
Joined Feb 2002
is the spar intact?
Old Jan 29, 2013, 02:34 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
[QUOTE=kingconsulting;23967523]Yeah would rather fix it instead of buying a new wing. Here is a pic with some covering removed. The leading edge is sheeted so should be able to make a patch for that. Ultracote is going to cost more than a new wing wold But I can use that for other things I'm building
After I damaged a wing on my 62" Osiris, Since the damage was all in the sheeted area of the leading edge. I used Monocoat trim sheets to recover it. A lot less expensive then buying rolls of covering. The colors weren't a exact match, But, Since 3dhs didn't have a replacement wing in stock, I got tired of waiting and just repaired the original wing. It flys just as good now as it did before the damage. (I did have to rebalance the plane laterally)
J
Jim Lee is offline Find More Posts by Jim Lee
Old Jan 31, 2013, 08:13 AM
Mr_McGlue's Avatar
Joined Sep 2011
Yes the spar is fine.
Originally Posted by astropuppy View Post
is the spar intact?
Old Jan 31, 2013, 08:20 AM
Mr_McGlue's Avatar
Joined Sep 2011
That's a good idea. I still might pick up the rolls though. This is my favorite plane right now so want it the same as it was (as best as I can).
Going to put a couple small square pieces from rib to rib, Wedge and sand a leading edge between the ribs and resheet that section.
I got real lucky it broke exactly between the ribs. I could still have flown it the way it was the wing was still solid. Of course I wouldn't want to test that
Will post some pics when I get it done this weekend.
J
Old Jan 31, 2013, 08:33 AM
Joined Feb 2002
Being the spar is intact; here's a wild idea. Glue several bamboo skewer sticks or dowels between the ribs spanwise. Then fill the void with expanding insulation foam. When dry shape an airfoil and cover with sticky back monokote or shelf paper.
Old Jan 31, 2013, 11:20 AM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
Hey Guys,
Does anyone have this and the 48" Super Vyper? Is there a big enough difference in precision flying that I should wait for the Osiris to come back in stock? Thanks!
FlyWW1 is offline Find More Posts by FlyWW1
Old Feb 04, 2013, 12:26 AM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
FlyWW1,
That would depend on which you like to do more. Precision flying or 3D flying. Both the 47" Osiris and the 48" Super Viper can be flown either way. For a combination of both, I'd give the Super Viper the edge. For Precision Flying I'd give the Osiris the edge.
Most modern Tx's have duel rates on all surfaces, So Crank up the throws on High Rates and do 3D, Flip the switch and go low rates for the precision bit.
My vote goes to the Osiris, As I like to fly precision (I fly precision a little better than 3D) more than I like to fly 3D
J
Old Feb 04, 2013, 06:24 AM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
Unfortunately the little Osiris has been discontinued. So now I'll never know unless I pick up a used one.
Old Feb 04, 2013, 01:23 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Well, I haven't tried one, But have you looked at the Oasis? It's a little bigger than the Osiris (50" wingspan) It looks like a nice flying plane. I've only seen one review on it and it was a favorable one. The price is right on it also. If I didn't already have way too many pattern planes of this size, I would give it a try.
http://www.valuehobby.com/review/pro.../category/185/
J
Old Feb 04, 2013, 01:26 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
I have been looking at the Oasis. However there are no videos that I could find. Plus the only review I could find was good but he hadn't flown it yet. Plus with the Super Vyper only being $20 more after shipping I figured I shouldn't take the chance.
Old Feb 04, 2013, 01:29 PM
whyrudy is offline
Find More Posts by whyrudy
¿Por Qué No?
United States, OR, Salem
Joined Aug 2011
last chance
The baby Osiris will be available in mid March from Esprit and ADC Hobby.
whyrudy is offline Find More Posts by whyrudy
Old Feb 04, 2013, 01:32 PM
FlyWW1 is offline
FlyWW1's Avatar
Joined Nov 2010
Not according to 3DHS. I asked them directly and they said it's been discontinued. I think they just haven't updated their websites yet.
The 47" Osiris is being discontinued from our lineup.
Regards,
3DHS
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 09:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 10:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 08:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 03:03 PM
