Old Nov 04, 2012, 07:27 AM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Well going to maiden mine today. Wish me luck! Just going to fly it on the recommended low rates first to get a feel for it and get it trimmed out.
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Nov 04, 2012, 07:49 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Robert
Good luck!
What expo are you running?
hone1er is offline Find More Posts by hone1er
Old Nov 04, 2012, 02:13 PM
Mr_McGlue's Avatar
Joined Sep 2011
Well did the maiden today...Flew great!
Needed a few clicks of up elevator and one click right aileron and flew pretty good. Second flight I moved the battery back about an 1/8th of an inch and it flew a lot more level. Even had my hands off it a couple times. Did 4 flights. By the second flight I was doing rolls, loops, snap rolls etc. and I've never done snap rolls before in a real plane.
Probably my favorite plane now. Need to try the other prop (12 x 6) for comparison just for fun.
Oh I never used expo before but did on this. Used 40% all around except for the rudder which was 50%. Got that from that AJ video.
Will need to do some adjusting as I go but very happy with it today! If I can get the video from my son I will. Not sure on the quality yet
Robert
Old Nov 05, 2012, 08:53 AM
Mr_McGlue's Avatar
Joined Sep 2011
Well I took what I could from my sons phone and cut out a lot. It was a little chilly that morning and he was wearing shorts and shivering
So first flight was right about 6 minutes and I had 47% left on the battery but I wasn't doing too much on the first flight. By the fourth flight about the same time I had 27%.
I usually set the timer about 5 minutes. That gives me a little wiggle room.
Robert
3DHS Osiris 47 Maiden (2 min 32 sec)
Old Nov 07, 2012, 09:50 AM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Robert
http://www.youtube.com/watch?v=9KkxFkiBXQM
shivering in California?
jsmith285 is offline Find More Posts by jsmith285
Old Nov 07, 2012, 02:56 PM
Mr_McGlue's Avatar
Joined Sep 2011
Well it was 54 degrees you know You guys just don't know what REAL weather is like haha
I'll admit it my kids are wimps when it comes to weather!
Robert
Old Nov 08, 2012, 04:42 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
I think there is something wrong with the suggested CG range for the 47" Osiris. Even the most aft recommended (125mm) is a static margin of about 20%. I found it has requires too much down elevator inverted with the CG there, and drops the nose too quickly on an inverted 45 degree up-line.
I recently got a 62" Osiris, and the manual and the thread here both suggest a CG 7" back from the wing LE/fuse junction is best for pattern flying. I calculate a static margin of 6% with the CG there. So far I like the way the 62" one flies with the CG at 6% SM.
I calculate the 6% SM CG location on the 47" Osiris would be about 158mm back from wing LE/fuse junction. I like the way it flies better back in that area. I have flown with the CG back as far as 165mm so far. That is a long way out of the recommended range. It flies very nicely there, but of course the elevator throw must be reduced considerably, preferably mechanically. I'm have the pushrod on the inside hole on a Hitec HS65 servo arm.
I wonder why there is such a huge difference in the recommended CG positions, when the planforms are essentially identical, just scaled?
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Nov 08, 2012, 09:32 PM
DeuceTrinal is offline
Find More Posts by DeuceTrinal
Landings are not optional
DeuceTrinal's Avatar
Van Nuys, CA
Joined Sep 2003
Partly, because you can scale the plane but not the air molecules. You can't make a plane bigger/smaller and expect it to fly like it used to. Personally, AJ's (and Scott's) recommendations are quite a bit more forward than I prefer to fly.
DeuceTrinal is offline Find More Posts by DeuceTrinal
Old Nov 09, 2012, 12:09 PM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
I made a mistake in the sweep on the 62" Osiris. The 7" CG position is actually an 11% static margin. The equivalent point on the 47" Osiris would be about 146mm back from the wing LE/fuse junction.
Stability, unless there are severe low Re effects and poor airfoils with very non-linear lift curves, is not really affected by scaling. My calculated neutral point for the 47" Osiris seems to be very close from flight testing. With the CG back to 165mm it is still reasonably pitch stable.
I am a bit surprised that these airplanes are being flown with even an 11% static margin. That would be considered very pitch stable in the sailplane world. Re effects do start to come into play on the stability of sailplanes at the low speeds they can fly at, but even so the effects are usually quite small with decent airfoils.
I suppose there are certain compromises in the CG position to get the knife edge behaviour correct for pattern airplanes.
Kevin
Old Nov 09, 2012, 03:55 PM
Mr_McGlue's Avatar
Joined Sep 2011
My first flight was at 117mm and had to move the battery back about an 1/8th inch. Next time I will be experimenting a little more with the CG.
Had a little wind for both days so waiting for a day to trim it better.
Just bought a couple more batteries and another charger. Really love this plane got a lot of nice compliments on how well it flew and one guy wanted to trade me for it
Robert
Old Nov 23, 2012, 09:00 PM
mazjag is offline
Find More Posts by mazjag
Marietta GA.
Joined Jan 2011
Guys, mine was flying good until I got into a esc/motor funk.. Too make a long story short I sent a esc back to Castle for warranty, but I`m pretty sure its my Omega motor..It worked fine on a Hacker esc so that messed me up trying to figure out the problem.The magnets have comes loose on the omega..Does the torque and hacker just bolt up with the same cowl spacing? I`m kinda thinking 3DHS should warranty the omega , but I took it apart to try and fix it so shame on me.
mazjag is offline Find More Posts by mazjag
Old Nov 23, 2012, 09:04 PM
astropuppy is offline
Find More Posts by astropuppy
United States, ID, Boise
Joined Feb 2002
I'd call 3D they are good people. My Hacker sticks out in front of the cowl by ~3/8"
astropuppy is offline Find More Posts by astropuppy
Old Nov 24, 2012, 01:47 PM
mazjag is offline
Marietta GA.
Joined Jan 2011
After fooling with the Omega for a bit...I had a Turnigy 3536-1100 lying around..This thing bolts right up...It was a touch shorter so I used the X-mount off the Omega as a spacer..This 18.00 dollar motor works just as well as the Omega..I couldn`t tell any difference in speed or run time..For a guy looking for a cheap motor for one of these, its perfect..I`m still gonna get another Omega or maybe a Hacker...jason
Old Nov 25, 2012, 09:56 AM
mazjag is offline
Marietta GA.
Joined Jan 2011
Guys, after going through the forum it looks like the Omega is about 45mm from x-mount to prop adapter...It seems the Hacker is 51mm and thats why the cowl must be moved so far foward...Anybody have a dimension for the Torque motor? or is it the same as the Hacker?
Old Nov 25, 2012, 11:56 AM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
I have seen an installation where a hole the diameter of the motor was cut through the firewall, and the motor mount screwed to the back of the firewall, instead of the front. That moves the motor back most of the difference in length.
Kevin
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 09:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 10:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 08:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 03:03 PM
