Old Oct 21, 2012, 04:23 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
Here's a artical that was published in March of this year, Concerning aileron differential. Maybe it will clear up the mystery.
J
http://www.modelairplanenews.com/blo...-to-set-it-up/
Jim Lee is offline Find More Posts by Jim Lee
Old Oct 21, 2012, 04:53 PM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
Hmm. That article is the old down going makes more drag. That may be slightly true on the initial roll input, and would require differential opposite what Jim originally suggested I think?
There is a second effect once the roll rate is stable, which happens very quickly after the initial aileron deflection. The down going wing has it's lift vector rotated forward because of the local velocity it sees, and the up going wing has it's lift vector rotated backwards by it's local velocity. This results in a yaw away from the direction of roll also. Dr. Drela explains it better than I can:
http://www.rcgroups.com/forums/showp...0&postcount=31
It seems to me that increasing the down going aileron deflection is going to add to these two effects, and increase the yaw away from roll direction, if it does anything at all.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Oct 26, 2012, 10:29 PM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Hmmm what is wrong with this photo of the wing? Don't worry the other wing is the same...
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Oct 26, 2012, 11:28 PM
Carl Petersen is offline
Find More Posts by Carl Petersen
Carl Petersen's Avatar
United States, AZ, Maricopa
Joined Mar 2002
Robert
Wrong hole for the aileron serve. It's right above whats been already cut out.
Carl Petersen is offline Find More Posts by Carl Petersen
Old Oct 26, 2012, 11:34 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
That is what the AJ stickers are for, to cover those holes up
3drcparts is offline Find More Posts by 3drcparts
Old Oct 26, 2012, 11:45 PM
Mr_McGlue's Avatar
Joined Sep 2011
Hey good idea! Saves me from buying two rolls of ultra cote.
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I did the exact same thing
Old Oct 27, 2012, 08:28 AM
Mr_McGlue's Avatar
Joined Sep 2011
I should have known too. All the other openings were hard to find and see. Held the wing up to the light and wow piece of cake! Then I tried fitting my servo in and it wouldn't fit. Ruh Ro.
So it looks ok with it on? At least it's on the bottom.
Robert
Old Oct 27, 2012, 09:17 AM
Gadget99 is offline
Find More Posts by Gadget99
Missouri
Joined May 2010
Hi guys,
Great discussion of adverse yaw and aileron differential.
A couple of quick things that helped me. 1) In the 62" Osiris build video from Higher Plane Productions, AJ shows he uses 11degrees up and 11.5 degrees down deflection for aileron differential. I used this differential on my 47" and my 62" Osiris and was very happy with the results.
2) I am also including Peter Goldsmith's article and trim chart about trimming a plane. Goldsmith is an IMAC pilot but the principles have helped me trim my pattern planes.
Step 5 covers aileron differential. Goldsmith says to start at step 1. I recommend reading the attached article about his experience with trimming a planes for competition
By following Jesky's and Goldsmith's tips both of my Osiris' fly even better.
Gadget
Gadget99 is offline Find More Posts by Gadget99
Old Oct 27, 2012, 07:58 PM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
Gadget,
Thanks, those are interesting.
I wonder if the 45 degree up-line roll tests for differential are actually looking for a pitch effect, not classic adverse yaw? If the net camber of the wing increases with aileron deflection, you would get a pitch up of the nose. For the first 180 degrees of a right roll, this would move the airplane to the right.
For a right roll, they are saying if the airplane "walks" to the right, you have too much down aileron on the left side. If you decrease the down aileron travel on the left side, you are effectively reducing the average camber of the whole wing. This will reduce any pitch-up effect of the ailerons, which will reduce movement to the right. And the reverse.
Classic adverse yaw, where the nose moves to the left during right roll should cause the airplane to track left intially during a roll. The very small changes in differential they are suggesting would have no effect on the pure adverse yaw, but could have a fairly large effect on the pitch change from overall wing camber. I think adverse yaw still occurs even after the trimming suggested, but by changing the pitch motion of the airplane from aileron inputs, the airplane is trimmed to fly a straight path during at least an up-line roll.
It would be very interesting to have some video of a yaw string on a canopy during rolling manoeuvres, like would be used on a full size airplane to indicate adverse yaw.
I have an aeronautics background, and some of the trimming methods used don't seem to make a lot of sense aerodynamically at first glance. The level of trimming on pattern airplanes is compensating for some pretty esoteric effects that aren't always obvious. I like to try and understand the aerodynamics, but it doesn't seem to help my flying much!
To have something on-topic in this post, I am having good success with the addition of a T-flap to the trailing edge of the rudder of my Osiris. My stall turns with the Osiris have been a hit and miss affair. I'm sure that is my lack of skill and bad timing usually, but I was having better luck with another airplane. I added a 5mm high each side (about 2% chord) T-flap, and I now have much more rudder power at low speeds. It is just a strip of red polyethylene from a snow slider, CA'd to the TE of the fin. It has definitely helped my stall turns.
I have some good papers on Gurney flaps and T-flaps if anyone is interested.
Kevin
Old Oct 27, 2012, 10:15 PM
mazjag is offline
Find More Posts by mazjag
Marietta GA.
Joined Jan 2011
Thx Gadget, for the trim list...My problem is the guy looking at the plane to trim it, is me.. I`m not sure what I`m seeing all the time is correct..It has gotten windy in Atlanta and thats not helping. Anybody here? These things don`t need the CG set like a 3D plane correct? I keep trying to roll upside down and keep moving the battery back...I`m not so sure it flys better...How much down should it be inverted? a touch? I know enough too know I need help with that first...thx..J
mazjag is offline Find More Posts by mazjag
Old Oct 28, 2012, 01:05 AM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Mazjag,
I like to set my C/G to where I have to push a little down Elevator when inverted. If you fly with exponential, I like to set less exponential on down Elevator. I adjust it until I get the same feel, Both upright and inverted. I fly on low rates and only use high rates when doing snaps and knife edge loops.
Of course it's much easier to set trim when there's little to no wind. If you try to trim when it's windy, You usually just end up chasing your tail.
If you change anything on the plane after you get your C/G set, You should check your C/G again to make sure it's still where you want it.
My 47" Osiris didn't require very much trimming, Once I had the C/G set. I have so little pull either way in knife-edge flight that I didn't need to use any mix. It also tracks and rolls true. I did laterally balance it as I do all of my planes.
Don't give up on trimming the Osiris, Once you get it set-up. It will be a joy to fly.
J
Old Oct 28, 2012, 09:32 AM
mazjag is offline
Marietta GA.
Joined Jan 2011
Thx Jim, I need to just play around with it some more.. Jason
Old Oct 28, 2012, 09:36 AM
Gadget99 is offline
Missouri
Joined May 2010
edited
Old Oct 28, 2012, 09:38 AM
Gadget99 is offline
Missouri
Joined May 2010
Originally Posted by kcaldwel View Post
Gadget,
Kevin
Yes, I would love to read the articles. I have been considering adding to the trailing edge of the rudder on my 62" Osiris but don't know where to start.
I love this hobby because fellow hobbyists are willing to share their expertise.
Gadget
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 09:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 10:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 08:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 03:03 PM
