Old Oct 12, 2012, 01:57 PM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Ok I went with the Omega motor and a 12 x 6 prop. Castle ice lite 75 ESC. Looking for battery recommendations? I'm not looking for speed but to learn pattern. Don't care about 3d stuff.
Guess two options 4s 2200mah or 4s 2650mah both 30C. Skylipo and Gensace.
First few flights will be just getting used to it. Any thoughts?
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Oct 12, 2012, 02:10 PM
LanceMc is online now
Find More Posts by LanceMc
Certified Wingnut
LanceMc's Avatar
Delta BC
Joined Jul 2008
Robert
I use the Omega 130, APC 11x7 prop, and 4S 2650mAh bats. I set my timer to 6 min. I fly 3/4 throttle most of the flight. Never tried a 12x6.
Lance
LanceMc is online now Find More Posts by LanceMc
Old Oct 12, 2012, 02:33 PM
Mr_McGlue's Avatar
Joined Sep 2011
Thanks Lance. I'm planning on picking up an 11 x 7 also to see the difference. Will probably go with 2650mah I'm thinking.
Robert
Old Oct 12, 2012, 04:10 PM
mazjag is offline
Find More Posts by mazjag
Marietta GA.
Joined Jan 2011
I`m using your same setup, but with a 11x7..I like 3000s in mine..I ike to fly it wide open and it just burns through a 2650., but I have those as well...either one.
mazjag is offline Find More Posts by mazjag
Old Oct 12, 2012, 04:36 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I run 2200 and 12x6, gets me about 5min, will a 11x7 draw more power
3drcparts is offline Find More Posts by 3drcparts
Old Oct 12, 2012, 07:25 PM
Carl Petersen is offline
Find More Posts by Carl Petersen
Carl Petersen's Avatar
United States, AZ, Maricopa
Joined Mar 2002
Another: Omega 130, 11x7, 4S 3000mah. Get around 8 minutes the way I fly.
Carl Petersen is offline Find More Posts by Carl Petersen
Old Oct 18, 2012, 09:57 AM
cedwards72 is offline
Find More Posts by cedwards72
United States, NC, Greensboro
Joined Jun 2012
Would these motor specs work for an Osiris 47" with a 3s Battery? They are out of stock on the Omega motor till Mid November..
Motor Specs
Weight: 140g
Input Watts: 375W
Outside Diameter 35mm
Lenght 42mm
No. of cells (lipo) 4
Max Efficiency 93%
Max Efficiency current 51
No Load Current(A) 7.4V 2.7
Internal Resistance: .0.029 ohms
Shaft Diameter 5 mm
Shaft Length 13 mm
KV (RPM/Volt) 1100KV
Turns (for cars) Poles 5
Max Voltage 14.8
Wire Size 0.25
Bullet Connectors Yes
Bullet Connectors Size 3.5 mm
Thanks for any advice in Advance,
Chris
cedwards72 is offline Find More Posts by cedwards72
Old Oct 18, 2012, 04:56 PM
Greg Beshouri is offline
Find More Posts by Greg Beshouri
Cant fly enough
Greg Beshouri's Avatar
USA, CA, Berkeley
Joined Dec 2003
This is what I have been flying on 3s:
http://www.modelmotors.cz/index.php?...e=10&line=GOLD
Greg Beshouri is offline Find More Posts by Greg Beshouri
Old Oct 18, 2012, 05:39 PM
Joined Jun 2012
Thank you so much.. This gives me a better idea of what I am working with motor wise...
Much appreciated!!!
Chris
Old Oct 18, 2012, 06:16 PM
Cant fly enough
USA, CA, Berkeley
Joined Dec 2003
Much appreciated!!!
Chris
My pleasure. This set up is light and works real well with 3S 3000maH batteries.
Old Oct 19, 2012, 09:22 AM
mazjag is offline
Marietta GA.
Joined Jan 2011
Does anybody use aileron differential on the Osiris? I`m trying to get better at setting these kinda planes up and never messed with that much...thx..Jason
Old Oct 21, 2012, 01:48 AM
Jim Lee is online now
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
mazjag,
First, You have to determine if your Osiris needs any aileron differential. I usually do the test on a 45 degree upline, going straight away from me. Try for a calm day, so that wind isn't a factor. Start by rolling the plane, Either to the left or to the right, Make sure that your aren't feeding in elevator, you just want to use ailerons. If you are rolling to the right and the plane pulls (yaws) to the right , You need to reduce the down throw. (Not enough differential)
If the plane rolls (yaws) opposite of the direction of the roll, You need to increase the down throw. (too much differential) If the plane stays on the same heading and neither pulls (yaws) to the right or left, You don't need any differential.
I don't know what radio that you are using, But most of the computer radio's have a differential mix that you can use. Off hand, I can't remember what % of differential I have in my 47" Osiris. I think that its around 6%.
J
Jim Lee is online now Find More Posts by Jim Lee
Old Oct 21, 2012, 11:04 AM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
J
Isn't that exactly backwards? The down going wing is the one to have it's lift vector rotated forward by the roll, and the up going wing's vector is rotated backwards, resulting in yaw away from the direction of roll.
The amount of adverse yaw depends on the speed of the airplane (more adverse yaw at low speed) and the load factor (G) (more adverse yaw at high load).
When you add differential there can also be a pitch effect. Adding more up going aileron than down can produce a pitch down effect when you only want roll.
My Osiris rolls pretty axially with no differential, and until my perception and left thumb get smart enough to notice and correct any adverse yaw that does occur, I'm sticking with no differential.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Oct 21, 2012, 11:07 AM
DeuceTrinal is offline
Find More Posts by DeuceTrinal
Landings are not optional
DeuceTrinal's Avatar
Van Nuys, CA
Joined Sep 2003
Check this trimming chart out, it's been very useful for me: http://www.wtp.net/DBEST/trimchrt.html
DeuceTrinal is offline Find More Posts by DeuceTrinal
Old Oct 21, 2012, 01:01 PM
kcaldwel is offline
kcaldwel's Avatar
Joined Jan 2007
If I read that trimming chart correctly, it is saying the same thing as Jim. I've never seen that before, and I struggle to understand how it would work - maybe it does?
There are certainly sites that say the opposite:
"The way I do this is to establish the model in a true vertical climb, of course by now your model will hold that vertical line with no correction! Now perform a half roll. You will probably find that the model has yawed off line. Use the rudder to correct the yaw back to the vertical. Which way did you move the rudder? If you moved it in the same direction as you rolled, then more differential is required i.e. more travel on the up going aileron. If you moved it the opposite way then less is required. So if you roll to the right and correct with right rudder then increase differential, roll to the right and correct with left rudder, less differential. You will probably find that a few adjustments are necessary before you find the correct setting. Again please note that a computer radio makes this task a simple one. If you don't have that luxury, to do this by altering your control linkage geometry will be time consuming."
http://www.wimbornemac.org/articles/...for-aerobatics
Chasing aileron differential seems like a mugs game in any case. It will depend on the airplane speed, and load factor (different result on a 45 degree up line than vertical or level). And differential can effect pitch trim with aileron commands. "Triangulation Trimming" doesn't even mention it as far as I can see:
http://www.hebertcompetitiondesigns....ming.aspx?ID=6
Kevin
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 09:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 10:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 08:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 03:03 PM
