Old Sep 29, 2012, 10:18 PM
Let me be...Frank with you :-p
going4speed's Avatar
USA, TX, Spring
Yea still missing one dang servo screw. Spent, believe it or not, the whole day cleaning my hobby room. No screw is site.
going4speed is offline Find More Posts by going4speed
Latest blog entry: smacked the beeeeg slick
Old Oct 01, 2012, 11:31 AM
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
I'm having a hard time with this build for some reason
hone1er is online now Find More Posts by hone1er
Old Oct 01, 2012, 12:04 PM
kingconsulting's Avatar
United States, CA, Long Beach
Joined Sep 2011
What sort of problems are you having?
Robert
kingconsulting is offline Find More Posts by kingconsulting
Old Oct 01, 2012, 12:51 PM
USA, TX, Spring
What part? Just finished mine.
Old Oct 01, 2012, 01:58 PM
Team Twisted!
hone1er's Avatar
Joined Dec 2011
Elevator servo setup was getting a bit frustrating and i ended up with a hole on both sides of the fuse and elevator.. I just finished everything though, just waiting on the postman for my motor. You think i will be ok to maiden with a 11x5.5(i got a motrofly 2820-950)? I'm planning on running a larger pitch later but that's what i have on hand. Also what expo are you using?
Old Oct 01, 2012, 02:46 PM
Marietta GA.
Joined Jan 2011
A good bit..I flew my maiden on Saturday and I can handle a jumpy plane, but even with the low throws in the manual it was all over..I had to adjust the expo in the air in order to land it...40-50% is where I would start...
mazjag is offline Find More Posts by mazjag
Old Oct 01, 2012, 02:52 PM
Team Twisted!
hone1er's Avatar
Joined Dec 2011
40-50% on low rates? I have my high rates around 50% and low rates around 25%
Old Oct 01, 2012, 02:59 PM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I always run 30 - 35% on low rates, 55-70% on hi rates.
It depends on your transmitter. I run my Hi-Tec Aurora a little higher than my spektrum DX7.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 01, 2012, 03:19 PM
Inverted-I-Fly's Avatar
United States, CA, Petaluma
Joined Mar 2011
it is super responsive, I'm at 50/60/70 for low/mid/high, also, it needs some room to get off the ground, this will not take off in 5 feet like a 3d plane, 11x5.5 should be fine to start
Inverted-I-Fly is offline Find More Posts by Inverted-I-Fly
Old Oct 01, 2012, 04:38 PM
Marietta GA.
Joined Jan 2011
I`m sure you do, but the planes never flown...If its too dull you can always land it and take some expo out...If you have it too high like I did you`ll be putting expo in while flying the maiden..I was never gonna land it the way I went up on the first flight...Its pretty responsive as noted..
Old Oct 01, 2012, 07:26 PM
¿Por Qué No?
Joined Aug 2011
Re
I practice pattern flying with mine. A couple of the guys that fly in higher classes w/ 2m planes convinced me to lower my aileron and stabilizer throws. It really flies smooth and precise now doing aerobatic flying. Higher rates for the snaps, etc.
whyrudy is offline Find More Posts by whyrudy
Old Oct 01, 2012, 11:11 PM
United States, CA, Sunnyvale
Joined Mar 2011
Wow.. I must be on the low end for expo then. I'm running 30-40% on high and 10-20% on low. But I fly with longer than standard sticks so there is some expo in that but its more linear.
vhuang168 is offline Find More Posts by vhuang168
Old Oct 01, 2012, 11:26 PM
USA, TX, Spring
The hard part of the elevator servo install was the routing of the servo wire. I have mine in the bottom of each former and that was a challenge.
Old Oct 01, 2012, 11:34 PM
Team Twisted!
hone1er's Avatar
Joined Dec 2011
I got the maiden +2 more flights before i had to go to work this morning. It was great I love the way it tracks and snaps. The snap rolls stop where you stop them every time. I don't have mid rates but i might play with that. I only have 2 triple rate switches though. I was a little too nose heavy for my liking but i'll mess with that for future flights. I also adjusted my expo after you guys said it was pretty responsive and i'm glad i did. I went from ~50% to ~65% on high rates and from 25% to ~50% on low rates. It felt about perfect. Landings are super smooth and easy. Now i just need to order some more props but for now the 11x5.5 will have to fly the plane around.
Old Oct 02, 2012, 07:36 AM
Marietta GA.
Joined Jan 2011
Yeah, I like the way it flies...Mine scoots with the Omega and a 11x7 and 3000ma packs.....Probably high 80s.....I was shocked that it needed that much expo as well...I have some 2650 packs to try on it, but I like just flying it WOT..
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 09:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 10:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 08:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 03:03 PM
