Good luck....your going to love this plane |
I also use 4S 2200 in my Aspera and land with 15V after 4.5 min. |
USA, NJ, Phillipsburg
Joined Jul 2010
Good luck with your maiden! Dana
Boulder, co
Joined Oct 2003
It depends a lot, of course. on how far off the stab is. I'm sure it will fly OK, but I remember a while back I epoxied the stab crookedly into an Ultrastick. Although its not a precision plane by any means, I could never get it to track straight in loops. Since I couldn't face major surgery, I finally just put floats on it and use it for putting around the lake.
If its just a little bit off, I agree that you may never notice the problem. |
Maiden
Just maidened my blue Osiris today,i love it,im running a Eflite 60 in it,
apc 11x8E,and a Omega motor in it, i hooked it up to the WattsupMeter ,fresh battery and i got,5 second burst 48.9 amps, 712 watts Does that sound about right? Also does anyone know what PWM Switching Frequency for the motor? I have it set at 8kHz Thanks, DB |
My 47" Osiris is set-up with a APC11x8e prop, 60A Cobra ESC, 130g Omega, and a 4s 14.8v 30c 2650mAh Lipo. It's pulling 45A and I'm getting about 630 Watts in or about 475 Watts to the prop. (It's a beast with this setup and weight) I have the airframe fine tuned and carry no coupling in knife edge in either directiion. I'd have to check my final C/G, But as I remember it's around 118mm. with that C/G I get just a slight push on inverted flight. I run more throw on down elevator on both high rate and low and also reduce the expo for a better feel inverted. The more you play with your Osiris, the more you will like it. Here's to many, many more enjoyable flights. ![]() J |
also give it a very slight push for inverted flight...very nice!! ![]() also just checked my radio im not running any expo at all,forgot to add it ,but it seems fine so far DB |
Boise, ID
Joined Dec 2008
Well guys, I'm through with this bird. Way beyond my abilities. Crashed my repaired Osiris on its "second maiden" after it's extensive repair. Even with low rates and exponential, its control surfaces were too much and into the ground it went after squirreling around in the sky. At least its CoG was good this time. But, another cartwheel into the sagebrush.
Funny thing is that, once again, the wings were hardly touched. Cowl is smashed. Fuselage is probably unrepairable--well, practically speaking. It goes into the trash, unless somebody wants me to scavenge some parts for you. I'd like to keep the electronics, but pm me if you want wings or what not. I can take digital pics and send, if anyone is interested. |
| Thread Tools | |
| For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. | funflyr | Aircraft - Electric - Airplanes (FS/W) | 6 | Mar 27, 2012 09:07 PM |
| For Sale 3DHS 62" Osiris Blue BNF | bjohnson80 | Aircraft - Electric - Airplanes (FS/W) | 5 | Mar 14, 2012 10:56 PM |
| Discussion 3D Hobby Shop 47" Osiris | flipteg | 3D Flying | 12 | Jul 21, 2011 08:36 PM |
| Discussion 3dhs 47" extra cowl dimensions needed | kaker123 | 3D Flying | 3 | Jun 28, 2011 03:03 PM |
