Old Jul 18, 2011, 11:01 PM
KTMRacr is offline
Find More Posts by KTMRacr
When in doubt, gas it!
KTMRacr's Avatar
United States, KS, Spring Hill
Joined Dec 2010
Originally Posted by ZackJones View Post
Sorry guys I got mine and then had to go out of town. First impressions is that she's a beautiful plane and looks fast even when sitting still. I did screw up one aileron servo hole but I'm blaming my wife for that because she distracted me when I was trying to cut them out. Here's a couple of pictures to hold you over until others post some or I can post some more.
Thanks for the pics. That thing looks saweeeeeeet! Need to get a little more work done and then some invoicing done so I can get one headed to my doorstep!
KTMRacr is offline Find More Posts by KTMRacr
Old Jul 19, 2011, 08:37 AM
ZackJones is offline
Find More Posts by ZackJones
It's just a plane.
ZackJones's Avatar
USA, SC, Goose Creek
Joined Aug 2010
Perhaps that's why it's taking me so long to build it. I just keep admiring it . Will get her done this week and maiden this weekend.
Couple of built tips/hints: On the wing it looks like there's two places you can mount the aileron servo -- you want to use the hole closest to the front of the wing not the back one . I know there's a picture in the manual but I still screwed up. That's that I get for working on the plane while the wife was yapping at me.
Second the aileron and elevator pushrods are two different diameters. The elevator one is thicker than the aileron pushrods. I had a difficult time getting the ball ends to thread onto the elevator pushrod. What I ended up doing which seemed to help is first thread them onto the thinner aileron pushrod, remove, and then install on the elevator push rod.
ZackJones is offline Find More Posts by ZackJones
Old Jul 19, 2011, 09:10 AM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
International Customers
Please feel free to contact ADC Hobby Store via E-Mail or PM me for a shipping quote.
We've received a small number to this point and should see some more shortly.
Rob
Fliprob17 is offline Find More Posts by Fliprob17
Old Jul 19, 2011, 02:20 PM
flipteg is offline
Find More Posts by flipteg
flipteg's Avatar
Joined Nov 2008
does anyone know if this plane uses Ultracote or does it use the same covering as the 42" Slick?
flipteg is offline Find More Posts by flipteg
Old Jul 19, 2011, 03:02 PM
Neil Morse is offline
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
I am set to maiden mine tomorrow. The build went very fast and smoothly. Only problem I have had was fitting a spinner. I am using a Torque 2814T/820 motor, and the prop adaptor isn't long enough to fit both the spinner backplate and an APC 11X7 E prop. So it will be spinnerless for now, not a big deal by any means. I will post some photos tomorrow.
Neil
Neil Morse is offline Find More Posts by Neil Morse
Old Jul 19, 2011, 06:07 PM
flipteg is offline
flipteg's Avatar
Joined Nov 2008
I think that is when APC suddenly changed the thickness of their prop hubs making some of the older Torque motor adapters too short.
Old Jul 19, 2011, 08:57 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
Exactly right. I have been buying hacker adapters for use on my torque motors as the hacker adapters have a longer bolt.
going4speed is offline Find More Posts by going4speed
Old Jul 19, 2011, 10:41 PM
It's just a plane.
ZackJones's Avatar
Joined Aug 2010
Possible Warped Horizontal Stab
Guys,
I could use a little help. I was dry fitting the horizontal stab tonight and I'm thinking it's warped. Below are several pictures I took to illustrate the problem I'm seeing. I realize in a couple of them the ruler / calipers aren't perfectly straight but I think it's close enough for now. I'll put a description under each photo so you can tell what I'm trying to show in each one.
Assuming it is warped how do you fix it? I have zero experience with covering, etc. The cut out for the horizontal stab looks good to me. If you want to see a picture of it I can post that as well.
Old Jul 19, 2011, 11:03 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Guys,
First, install it in the fuselage, and then check it. If it really twisted, then you can twist it in the opposite direction and heat the wrinkles with a heat gun or covering iron.
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 19, 2011, 11:07 PM
TOFAST4U2C is offline
Find More Posts by TOFAST4U2C
"Failure is not an option"
TOFAST4U2C's Avatar
West Babylon NY
Joined Dec 2006
How does it look in the fues in relation to the wing tube? If its bowed you may be able to shim it. I had to add a shim to mine.
TOFAST4U2C is offline Find More Posts by TOFAST4U2C
Old Jul 20, 2011, 06:19 AM
It's just a plane.
ZackJones's Avatar
Joined Aug 2010
The first two pictures show how it is when it's installed in the fuselage. You can see how much difference there is from one side to the other. (there's quite a bit)
Old Jul 20, 2011, 06:20 AM
It's just a plane.
ZackJones's Avatar
Joined Aug 2010
That's the odd thing. When I look at it in relation to the wing tube it looks straight or at least it does to me. I fly with another 3DHS addict so I'll see if he can stop by tonight and take a look at it with me.
Old Jul 20, 2011, 08:21 AM
KTMRacr is offline
KTMRacr's Avatar
Joined Dec 2010
I'm a noob, but since you are so far off measuring from the end of the stab to the table surface, are you sure the gear is on straight and not crooked?
Old Jul 20, 2011, 08:31 AM
It's just a plane.
ZackJones's Avatar
Joined Aug 2010
I thought about that last night when I was measuring it. Perhaps I'll take the wheels off or the landing gear off and measure again.
Old Jul 20, 2011, 09:18 AM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
Zack, first make sure your table is flat. Now take the gear off and slide the wing tube in so it is centered. Now find four objects that are all the same height, I like to use soup cans (full). Now support the fuselage with the soup cans under the wing tube and under the stab. Make sure the soup cans are positioned at the same location in relation to the wing tube and stabs on each side. Now have a look at how the stab rests on the soup cans. Any warp or missalignment will be very easy to see. If you have a large cutting matt with markings, you can set this up over the cutting matt and use the markings to postion the stab square to the wing tube before gluing. I used this method on my Osiris.
This model is much smaller and the wings are on , but you get the idea!
172AMD is offline Find More Posts by 172AMD
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 10:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 11:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 09:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 04:03 PM
