Old Feb 10, 2012, 03:32 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
Originally Posted by earp View Post
I have been putting in the flights for practice. Its very demanding, but rewarding. The threshold (myself) for "competence" with the entire sequence is at least a hundred flights.
Any similar results?
My goal is to compete next season in a few events in district 3 with the Osirius 62".
I looked at the sequence sheets.....then decided I'm flying Basic for another year LOL
Fliprob17 is offline Find More Posts by Fliprob17
Old Feb 14, 2012, 02:08 PM
jonathan7x70 is offline
Find More Posts by jonathan7x70
Fly, fly, fly, fly , fly more!
jonathan7x70's Avatar
Lafayette, Louisiana
Joined Dec 2005
On the 47" Osiris.... its calling for a 40mm/1.5" spinner.
I have a really nice 45mm 1-3/4"... would that work or would it be to large? look funny. I like things to match but if i can use this spinner would be cool to..
Thanks!!!
jonathan7x70 is offline Find More Posts by jonathan7x70
Old Feb 14, 2012, 02:53 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
Thanks!!!
A 45mm spinner would overhang the cowling.
Here's the one that I used on my Osiris.
http://www.rcdude.com/servlet/the-61...r--dsh-/Detail
http://www.rcdude.com/servlet/the-62...er-40mm/Detail
J
Jim Lee is offline Find More Posts by Jim Lee
Old Feb 14, 2012, 07:17 PM
Joined Dec 2005
ok 40mm it is!
I ordered the Blue 47" Osiris just a little while ago! Sooooo excited !!
Old Feb 14, 2012, 08:11 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
ok 40mm it is!
Me Too, Because your're not gong to believe how well this little Osiris flys.
J
Old Feb 15, 2012, 04:59 PM
Joined Dec 2005
I just ordered a Second one... back up!
Old Mar 09, 2012, 04:52 PM
jhatton is offline
Find More Posts by jhatton
Joined Aug 2010
Mine Showed up today... got it unpacked and fitted together, everything looks good. My wife even started making graphics for it.
Quick question, the wing tube was an exceptionally tight fit, it took some work and time to allow it to slide freely into the socket, is this normal on this airplane?
Update: Well aparently I did not have it moving as freely as I thought, while it slid in and out smooth before assembly, the wing is now stuck. Any ideas on how to get the wing tube to slide in the socket without damaging anything?
jhatton is offline Find More Posts by jhatton
Old Mar 09, 2012, 11:40 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Hi jhatton,
This issue has been brought up also on other planes and it seems that the majority favored using 600 grit sandpaper to smooth out the wing tube so that it would fit.
I have both the 62" and the 47" Osiris and when the 62' was new, The wing tube was a rather tight fit. After numerous flights the tube loosened up slightly. So you would not want to get it too loose by sanding, You only want to get it to slide all the way into the wing. There should be some drag when you are assembling and dis-assembling the wing.
J
Old Mar 10, 2012, 06:27 AM
danamania is offline
Find More Posts by danamania
Advocating for RC Aviation
USA, NJ, Phillipsburg
Joined Jul 2010
Built a 47" that I picked-up at the WRAM show. Used a dry teflon lubricant inside the tubes on the wings. Works perfect every time and no sanding needed. If it gets tight again, I'll just add a little more powder. Have used this lube for 2 years now. Good stuff. Good Flying! Dana
danamania is offline Find More Posts by danamania
Old Mar 10, 2012, 09:11 AM
astropuppy is offline
Find More Posts by astropuppy
United States, ID, Boise
Joined Feb 2002
You might want to try waxing the tube with car wax. Be careful of splinters.
astropuppy is offline Find More Posts by astropuppy
Old Mar 10, 2012, 05:58 PM
Joined Jul 2010
Maidened the 47" today. Another excellent ARF from 3DHS! I flew it 4 times and it is in basic trim and terrific to fly. I almost forgot I wasn't flying the 62"! Seriously I don't know why I put up with flying some of the other crummy models I have hogging hangar space in the garage LOL!
Old Mar 11, 2012, 07:18 PM
Greg Beshouri is offline
Find More Posts by Greg Beshouri
Cant fly enough
Greg Beshouri's Avatar
USA, CA, Berkeley
Joined Dec 2003
Well mine has been together for a while. But between weather and travel I have not yet flown it. I recently downloaded this model of its big brother for the RealFlight simulator http://knifeedge.com/forums/download...=file&id=14724. I was wondering how well it matches the real thing. Has anyone tried it?
Greg Beshouri is offline Find More Posts by Greg Beshouri
Old Mar 11, 2012, 11:57 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
I've got it downloaded to my Realflight Sim and I like the way it flys. The real one flys better, But that is to be expected. I also have a couple of 2 meter planes downloaded, The Pinnacle and The Krill Spark. The 62" Osiris is derived from the Krill Spark.
The 2 Meter planes fly better than the 62" Osiris, But that is to be expected.
Download the 2 Meter planes that I mentioned and see if you like the way that they fly.
All 3 planes are capable of the full spectrum of Pattern maneuvers.
J
Old Mar 12, 2012, 10:23 AM
Cant fly enough
USA, CA, Berkeley
Joined Dec 2003
Thanks Jim.
I thought the 62" Osiris in the simulation flew great. In partiular I was impressed with the amount of rudder authority. Is that realistic?
If the 47" flies as good as the similaiton I will be real happy!
Old Mar 12, 2012, 11:23 AM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Thanks Jim.
Yes, The Osiris has a lot of rudder authority. The 47" also is a blast to fly. I take both of them to the field and when the other fliers see the 47" Osiris fly, they can't belive that it's not the 62" Osiris.
J
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 09:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 10:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 08:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 03:03 PM
