Old Nov 02, 2011, 09:22 PM
Duncandiver is offline
Find More Posts by Duncandiver
R/C is a SICKNESS
Duncandiver's Avatar
Vancouver, BC, Canada
Joined Oct 2009
Oops
Duncandiver is offline Find More Posts by Duncandiver
Old Nov 03, 2011, 01:49 AM
R/C is a SICKNESS
Joined Oct 2009
QUOTE: I revised the colour scheme on my Osiris to look more Canadian, and bit less red-white-and-blue stars-and-stripes. Easy to do, and I'm quite happy with it.
Looks great...not as busy.
1 star per wing and 1 on each side of the fuse is enough.
Old Nov 03, 2011, 09:26 PM
R/C is a SICKNESS
Joined Oct 2009
No Blue or Stars
OK I did it too...I think it looks Great, flys Great too.
One with the Aspera (also a Great plane)
Old Nov 04, 2011, 10:04 AM
LanceMc is offline
Find More Posts by LanceMc
Certified Wingnut
LanceMc's Avatar
Delta BC
Joined Jul 2008
Looks Great Andy! I have been thinking of doing the exact same thing. How did you remove the stars?
Lance
LanceMc is offline Find More Posts by LanceMc
Old Nov 04, 2011, 10:47 PM
R/C is a SICKNESS
Joined Oct 2009
Lance
Not to hard to do, just pick a corner up and peel it offlike taking off a sticker
Old Nov 04, 2011, 11:53 PM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
FYI....I've cut maple leafs out of white vinyl to replace the stars on a couple occasions
Fliprob17 is offline Find More Posts by Fliprob17
Old Nov 05, 2011, 11:37 AM
R/C is a SICKNESS
Joined Oct 2009
12x6 vs 11x7
Well I tried the Osiris with an 11x7 (have been flying a 12x6) there seems like quit a difference. It was colder today, may have made a bit of difference???
The plane was noticeably faster, seems like it had some torque roll at higher throttles .may have been my flying. Id like to try both a 11x7 and 12x6 on the same day.
Old Nov 05, 2011, 08:24 PM
732002 is offline
Find More Posts by 732002
732002's Avatar
United States, OR, Lake Oswego
Joined Dec 2003
How did the vertical performance compare? Climb, downline prop braking.
732002 is offline Find More Posts by 732002
Old Nov 05, 2011, 08:37 PM
R/C is a SICKNESS
Joined Oct 2009
12x6 vs 11x7
Faster in the vertical (both are unlimited), constant speed in the down line. Id have to try them back to back to compare down line speed.
Old Nov 26, 2011, 06:31 PM
Greg Beshouri is offline
Find More Posts by Greg Beshouri
Cant fly enough
Greg Beshouri's Avatar
USA, CA, Berkeley
Joined Dec 2003
Well my Aspera finally died (due to pilot error) after a gazillion flights. It was my favorite!
So I will replace it with an Osiris (I was kind of waiting for the opportunity)
However I have no 4s packs, doing the 3s, 6s, 9s..... thing. Is anyone flying it on 3s or 6s?
Greg
Greg Beshouri is offline Find More Posts by Greg Beshouri
Old Nov 27, 2011, 09:14 PM
DeuceTrinal is offline
Find More Posts by DeuceTrinal
Landings are not optional
DeuceTrinal's Avatar
Van Nuys, CA
Joined Sep 2003
You could definitely fly it on 3S, you just need the right weight packs and a higher KV motor than the 130g Omega, around 1150KV. You'll be pulling more amps on 3S to get the same wattage, so will need a bigger ESC. 6S would work too, if you had packs small enough. just compare the weight of the recommended packs to what you have, and go from there.
DeuceTrinal is offline Find More Posts by DeuceTrinal
Old Dec 21, 2011, 07:21 PM
vhuang168 is offline
Find More Posts by vhuang168
United States, CA, Sunnyvale
Joined Mar 2011
I'm starting my build and have a couple of questions.
This is my 1st pull-pull rudder, how tight do I need the cables to be? I know not so tight as to stress the servo/control horn mounting. But is there a way to know how tight?
Also, where do you guys put the rx? I see a ply piece marked RX but no obvious place for those 4 screws.
TIA
Vincent
vhuang168 is offline Find More Posts by vhuang168
Old Dec 21, 2011, 07:57 PM
Van Nuys, CA
Joined Sep 2003
Tight enough they are snug, but don't twang/sound when you pluck them. 8" behind the servo, mine move 1/2" sideways without much pressure at all.
Old Dec 21, 2011, 08:53 PM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
just taught, no slack/slop....we're not after guitar playing
make sure the rudder centers after going left and right separately
they are going to loosen up after a handful of flights and you'll make a slight adjustment, so don;t stress on it too much.
Old Dec 21, 2011, 09:38 PM
Jim Lee is online now
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
********__Also, where do you guys put the rx? I see a ply piece marked RX but no obvious place for those 4 screws.
TIA
Vincent
I Put mine over the Rudder servo. I glued some balsa block to the fuse sides using medium CA. Then I cut some popsickle sticks to the proper size, drilled some pilot holes for some servo mounting screws, Then the screws. I then removed the screws and put some thin CA in the threads, let it dry, then re-inserted the screws. I then glued the Rx Tray to the Popsickle sticks and mounted the Rx using velcro. If, When I need to work on the rudder servo or linkage, I just remove the 4 screws and I have access to the rudder servo, or linkage.
J
Jim Lee is online now Find More Posts by Jim Lee
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 10:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 11:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 09:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 04:03 PM
