Old Sep 16, 2011, 11:46 PM
Duncandiver is offline
Find More Posts by Duncandiver
R/C is a SICKNESS
Duncandiver's Avatar
Vancouver, BC, Canada
Joined Oct 2009
Originally Posted by Fliprob17 View Post
A30-14L = 1.5" from back of can (where X-mount attaches) to front plate (where prop. adapter attaches)
Hi Rob
Can you tell us the size of a Omega 130g from the back of the X mount to the front of the prop adapter PLEASE
Looks to me a Hacker A30- is 2.060 from the back of the X mount to the front of the prop adapter
Thanks Andy
Duncandiver is offline Find More Posts by Duncandiver
Old Sep 17, 2011, 03:52 PM
Jim Lee is offline
Find More Posts by Jim Lee
AMA # 75962
Jim Lee's Avatar
United States, WA, Port Orchard
Joined Apr 2007
Originally Posted by Carl Petersen View Post
How about measuring the length of the motor including the cross mount to the prop adapter (surface the spinner/prop mount to).
Is the Omega 130g shorter than the A30-14L?
The Omega 130g870 IS shorter than the A30-14L. I have both motors. I have the A30-14L in a 48" Vanquish and the Omega 130g870 in a 47" Osiris.
The Omega is a tad bit shorter then the Hacker and that's why I used it in the Osiris. I had no trouble getting the cowl to spinner space with the Omega. I just had to open up the front of the cowl with my Dremel to allow enough clearance for the prop Adapter.
If the motor box was any shorter, One might have a problem getting a proper C/G. Unless you could use a motor that weighed more then the Hacker or Omega.
J
Jim Lee is offline Find More Posts by Jim Lee
Old Sep 19, 2011, 09:46 AM
Fliprob17 is offline
Find More Posts by Fliprob17
ADC Vinyl
Fliprob17's Avatar
SoCal-Rancho Santa Marg.
Joined Mar 2007
Originally Posted by Duncandiver View Post
Hi Rob
Thanks Andy
out of stock, don't have one to measure
Fliprob17 is offline Find More Posts by Fliprob17
Old Sep 19, 2011, 09:50 AM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
....edit
Old Sep 19, 2011, 06:39 PM
Jim Lee is offline
AMA # 75962
Jim Lee's Avatar
Joined Apr 2007
Hi Rob
Thanks Andy
Since Fliprob17, Doesn't have one to measure, I'll give you the measurements off of my Omega 130g870kv. The distance from the back of the X Mount to the front of the prop Adapter is 45.2438mm or 1.78125 inches which equals 1-25/32 inches. Hope this helps.
J
Old Sep 19, 2011, 10:50 PM
R/C is a SICKNESS
Joined Oct 2009
Thanks Jim
So the Omega 130g is 0.280" or 9/32" shorter than the Hacker A30-. Looks like the Omega is a better fit. I'll the to do some mods this weekend to see how I can make the 2.060" motor fit.
Also thanks Rob for trying...when are you getting stock from 3DHS?
Old Sep 21, 2011, 09:20 AM
ADC Vinyl
Fliprob17's Avatar
Joined Mar 2007
potentially next week
Old Sep 21, 2011, 10:32 AM
bigmoebbq is online now
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
Anyone had any problems with Hitec 65mg's not fitting? i have a friend that is trying to get them to work but he says the mounting holes are too big. Servos don't fit. I have not seen it in person so I am just curious.
bigmoebbq is online now Find More Posts by bigmoebbq
Old Sep 21, 2011, 10:50 AM
kcaldwel is offline
Find More Posts by kcaldwel
"Where are they?"
kcaldwel's Avatar
Joined Jan 2007
The servo mounting holes on mine had to be lengthened slightly for HS65s to fit, they are a tad small for them.
He didn't by chance cut open the wrong hole on the bottom of the wing? There are two openings there that sort of look like servo pockets through the covering. The rear one is just an opening in the wing. The forward one is the servo pocket.
Kevin
kcaldwel is offline Find More Posts by kcaldwel
Old Sep 21, 2011, 12:14 PM
Carl Petersen is offline
Find More Posts by Carl Petersen
Carl Petersen's Avatar
United States, AZ, Maricopa
Joined Mar 2002
FWIW, be sure to check the formers in the back of the fuselage. Someone must have sat on mine as two of them are cracked. I didn't notice it until I was heat shrinking the covering in that area. Bit of a pain to repair. Anyway just a heads up.
Carl Petersen is offline Find More Posts by Carl Petersen
Old Sep 22, 2011, 07:33 PM
flipteg is offline
Find More Posts by flipteg
flipteg's Avatar
Joined Nov 2008
Chris, most likely he removed the covering from the wrong section of opening. i had to take off a little bit wood on all 4 servo openings to fit the HS-65MG's.
flipteg is offline Find More Posts by flipteg
Old Sep 27, 2011, 02:52 PM
osamma is offline
Find More Posts by osamma
Joined Mar 2011
Hi Jim I had a Osiris 47" from 3DHS I am very new to build a plane the problem is the
elevator half they were not level.would you please give me some idea how to fix it.
Vic
osamma is offline Find More Posts by osamma
Old Sep 29, 2011, 03:00 PM
R/C is a SICKNESS
Joined Oct 2009
Vic ..take a look at begining of the thread. Is this the same problem?
Old Oct 07, 2011, 05:41 PM
ian145 is offline
Find More Posts by ian145
ian145's Avatar
United States, CA, Santa Cruz
Joined Nov 2010
iv'e never owned a 3dhs plane before, but i was thinking about getting an osiris 47". what is the best power setup and servos? also are there any major problems with the plane or much needed modifications? And, how are the flying characteristics?
ian145 is offline Find More Posts by ian145
Old Oct 07, 2011, 07:06 PM
LanceMc is online now
Find More Posts by LanceMc
Certified Wingnut
LanceMc's Avatar
Delta BC
Joined Jul 2008
Hi Ian.
I got the 47 Osiris about 6 weeks ago. I strongly suggest using the 3DHS recommended power setup. I have the recommended Omega motors in both my 3DHS planes, and I love them. With this being a pattern plane I wanted servos with a really good reputation for centering, so I went with the recommended Hitec 65s (I didn't go with the MGs). Please forgive me for stating this but...this must be your first 3DHS plane if you are asking about major problems or modifications. 3DHS has a first rate reputation for producing great planes out of the box. They do extensive testing prior to releasing each new model. The only mod I've heard of of is adding thin CA to the major stress points (motor box etc). As for the flying characteristics, have a look at Joe Smith's video in post #125. That's what the plane is capable of in the hands of a true expert. I say get it and be prepared for a huge, silly grin on your face for a long long time!
Lance
LanceMc is online now Find More Posts by LanceMc
For Sale 3DHS OSIRIS RTF, Hacker, ICE 100, Servo's. funflyr Aircraft - Electric - Airplanes (FS/W) 6 Mar 27, 2012 10:07 PM
For Sale 3DHS 62" Osiris Blue BNF bjohnson80 Aircraft - Electric - Airplanes (FS/W) 5 Mar 14, 2012 11:56 PM
Discussion 3D Hobby Shop 47" Osiris flipteg 3D Flying 12 Jul 21, 2011 09:36 PM
Discussion 3dhs 47" extra cowl dimensions needed kaker123 3D Flying 3 Jun 28, 2011 04:03 PM
