Old Aug 08, 2012, 06:54 AM
cetorca is offline
Find More Posts by cetorca
Bogota Colombia
Joined Mar 2006
I will consider it, Its a hobby for me and don,t have the time for line production but maybe one or two could be possible.
R
Originally Posted by TheDreamFactory View Post
Cool Good to see you back at work on this 767 Can't wait to see it done! ... BTW there is an Airliner forum now!
Also would you consider milling me a set of gear as im doing a 767-300 some time soon
cetorca is offline Find More Posts by cetorca
Old Aug 08, 2012, 06:59 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
Thanks Rhich, I have to finish these ones, then the nose retract with ligths steering and scale details and then I could produce 2 more. Not to much spare time
Originally Posted by LuvEvolution7 View Post
those look awesome. how do we get you to make a set of those for us? LOL.
Rich
Old Aug 08, 2012, 07:11 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
I already started the building based om 70mm I Considered your suggestion but the weight is an issue with the scale details I have planed to put into.
Originally Posted by BillO View Post
On the exhaust issue, have you looked into using a smaller fan running at higher power? FSA will be less, so the scale exit may be possible (or at least something much closer).
The Minifan (70mm) FSA is 29.4 sq cm, while the Microfan (50mm) is 13.9 sq cm.
You would have to build light though!
Old Aug 08, 2012, 04:29 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Wow! nice work!
Keenan smith is offline Find More Posts by Keenan smith
Old Aug 08, 2012, 07:49 PM
IWC is offline
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
sub
IWC is offline Find More Posts by IWC
Old Aug 13, 2012, 08:32 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
How do I move this thread into the airliner forum?
Old Aug 13, 2012, 08:47 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
Wing airfoil
I've been working some time to find the best airfoil for the wing root in order to have space to acommodate the landing gear and I came up to a modified version of S8035 symmetric and transition to a Clark Y on the tips. Have to twist the wing a lot to compensate for the higher root stall AOA.
Old Aug 13, 2012, 09:11 AM
Joined Dec 2010
your getting quite the vortex of the tips thought of Winglets?
Old Aug 13, 2012, 04:16 PM
cetorca is offline
Bogota Colombia
Joined Mar 2006
It's due to the high angle of attack during the snapshot in the simulation. There are no winglets on the 767-200 cargo, or at least those which I fly.
Old Aug 13, 2012, 06:20 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Cool stuff, looking forward to seeing more of your build.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old Aug 17, 2012, 10:53 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
I just made the wheel axles and installed the 1.5" wheels. No custom wheels yet. The size of these wheels match great to the scale gear I made.
Old Aug 19, 2012, 04:49 PM
cetorca is offline
Bogota Colombia
Joined Mar 2006
Working on the Nose landing gear. It will rotate more than 110 degrees. The tail section is to be molded in fiberglass in one piece along with the vertical stab.
Old Aug 19, 2012, 10:41 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Landing gear looks fantastic!
BillO is offline Find More Posts by BillO
Old Aug 20, 2012, 06:50 PM
cetorca is offline
Bogota Colombia
Joined Mar 2006
Thanks BillO, This is what I did today on the nose gear design. I'm not home now so these parts will have to wait one week to be done. The gear doors are to be splited an no idea how will they be operated. The same for the main gear doors. I'll think about it later.
Old Aug 30, 2012, 09:22 PM
cetorca is offline
Bogota Colombia
Joined Mar 2006
I've been working mostly in the CAD wings and stabilizers design, so not to much building. I made the dummy brakes for each main wheel. I've seen them red hot after a high altitude landing and then tires being deflated.
