Old Jul 05, 2011, 09:37 AM
cetorca is offline
Find More Posts by cetorca
Bogota Colombia
Joined Mar 2006
Some progress in the CAD design.
cetorca is offline Find More Posts by cetorca
Old Jul 05, 2011, 05:09 PM
cetorca is offline
Bogota Colombia
Joined Mar 2006
I had to change the airfoil on the root to a symetric one in order to host the landing gear strut. The airfoil at root transition to a clark
Y at the engine pylon. I have to check that the root stalls first than tip in this setup. Washout has been already included.
Old Jul 05, 2011, 08:45 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Originally Posted by cetorca View Post
This is how it looks. There is the outer area which is the difference between the FSA and the Inner cone oulet area.
Hi CEtorca,
I think you will find that splitting the flows between the annular outlet and the cone will result in large losses in thrust.
If the annular outlet is too large the flow out of it will be following a greatly expanding area with a converging cone in the center causing the airflow to slow more than you expect which will result in poor thrust. The fluid will flow thru the path of least resistance so the annular outlet will need to be restrictive to force the fluid thru the conical outlet. It would be better to use the cone to control airflow for enhanced thrust, having two outlets will double the losses. It might need to be a little larger than scale but the performance will not deteriorate like the annular design and it won't be noticeable in flight.
Eric B.
AirX is offline Find More Posts by AirX
Old Jul 05, 2011, 10:32 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
could you not just go for a "profile" cone instead? just a flat sheet from the side and the bottom in an vertical "X". this way, it'll look like the real thing from the side and from the bottom as it's flying over you. this way, you'll just have one opening instead of two and it'll be less restrictive.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jul 08, 2011, 07:58 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
Originally Posted by AirX View Post
Hi CEtorca,
Eric B.
Eric, it's a very wise advise and I've been thinking about it. What I came up yesterday, was to set up a test bench with the annular oulet and the center cone ,where the Red motor fairing shown in the graph is displaced horizontaly so you can control the amount of flow entering the converging cone. Measuring thrust and power you can determine where is the best position where the air is not slow to much due to the effect you explained. Then compare the results with the bench test without any of the cones, just the EDF itself and see if the losses are significant.
Old Jul 08, 2011, 08:02 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
You mean a cone a with flatenned sides?
Old Jul 08, 2011, 10:04 AM
Joined Jan 2009
like this
yes, it looks like complete crap, since I don't do CAD at all. and also, it looks like crap on the model too, but it's a compromise you may have to live with, unless you make a scale cone that is removable for flight. that's of course, if you find out that your thrust is too low with the setup as you have it drawn up. if it works, you'll be ok. just pointing out other options that might be used.
Old Jul 09, 2011, 10:01 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Never hurts to put it to the test. Please post your numbers it will be interesting.
Cheers,
Eric B.
Old Mar 05, 2012, 07:16 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Well what happened here then ??
Keenan smith is offline Find More Posts by Keenan smith
Old Aug 06, 2012, 09:12 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
Landing Gear
Hi;
I've been working on the landing gear. They are going to be pneumatic and as much as scale as my spare time will allow. Aluminum 6061, 2024 and 7075 is being used.
Old Aug 06, 2012, 09:45 AM
cetorca is offline
Bogota Colombia
Joined Mar 2006
Lnd gear CAD
This is the render of my landing gear CAD. I did a custom retract since the commercial ones protrude out the wing skin if placed for a scale retract position.
Old Aug 06, 2012, 09:56 AM
Joined Dec 2010
Cool Good to see you back at work on this 767 Can't wait to see it done! ... BTW there is an Airliner forum now!
Also would you consider milling me a set of gear as im doing a 767-300 some time soon
Old Aug 06, 2012, 11:56 AM
Joined Jan 2009
those look awesome. how do we get you to make a set of those for us? LOL.
Rich
Old Aug 07, 2012, 09:31 AM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
On the exhaust issue, have you looked into using a smaller fan running at higher power? FSA will be less, so the scale exit may be possible (or at least something much closer).
The Minifan (70mm) FSA is 29.4 sq cm, while the Microfan (50mm) is 13.9 sq cm.
You would have to build light though!
BillO is offline Find More Posts by BillO
Old Aug 07, 2012, 02:34 PM
Billybobjoepants is offline
Find More Posts by Billybobjoepants
No worries... it can be fixed.
Billybobjoepants's Avatar
Joined Jun 2012
Wow! Looks like a great project! Can't wait to see how it turns out.
Billybobjoepants is offline Find More Posts by Billybobjoepants
