Old Oct 18, 2011, 10:02 PM
vivcal is offline
Find More Posts by vivcal
United States, CA, Fremont
Joined Jul 2011
Originally Posted by Dittsboylogan View Post
I think I'm going to get the UM T-28 instead of the Polecat, since this will be my first 4 channel plane. People have said the T-28 is easier, But is it AS durable as the Polecat? I'm kinda scared of the thin wing, unless it is durable
The Polecat is definitely more durable, and the T-28's wing is quite flimsy.
I had a Champ, and now I'm flying a Polecat. I didn't use the T-28 like people recommended. I'm flying fine, and haven't broken anything major, but if you don't mind spending some extra money on a T-28 just as a step to make things easier, it's probably a good idea.
vivcal is offline Find More Posts by vivcal
Old Oct 18, 2011, 11:29 PM
perschek is offline
Find More Posts by perschek
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
Originally Posted by coreman View Post
My repaired/replaced plane is in the mail and should arrive friday. Can't wait to get it back in the air. I think i will look inside to see if they changed anything... Maybe they did separate the motor/brick to avoid the cut trace if that was the issue. Will let people know. We move indoors (120'x300') on the 28th for the winter so i look forward to lots of fun with this one.
Oh man hope you enjoy it as much as I do. Was 70 degrees and 0 wind today, had lotsa fun flights! Can't wait for the report, great plane especially for the price!
perschek is offline Find More Posts by perschek
Old Oct 19, 2011, 05:27 AM
coreman is online now
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
I did love it right up until the rudder servo failure put it in. I hope this one avoids that. I got it at my LHS so it was probably from the very first shipment and I hope things have improved which is why I want to see if anything has been modified internally
coreman is online now Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Oct 19, 2011, 08:00 AM
Brooklynstar23 is offline
Find More Posts by Brooklynstar23
NEVER GIVE UP!
Brooklynstar23's Avatar
Brooklyn, NY
Joined Nov 2010
Does anyone have a suggestion as to how to fabricate a battery compartment "door" for this bad boy? I plan on flying her in my local school yard during the cold winter/snowy months. I dont want the battery totally exposed so was thinking of making a little hatch to cover the battery as she flies...anyone have any ideas?
Or...would it be better to put the battery in like a makeshift "sock" instead of having a hatch?
Brooklynstar23 is offline Find More Posts by Brooklynstar23
Old Oct 19, 2011, 08:36 AM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
a sock would work but so would a piece of tape with one end folded over so you have a pull tab or similarly an address label
Old Oct 19, 2011, 01:28 PM
perschek is offline
GEEBEE Can't WAIT!
perschek's Avatar
USA, OR, Seaside
Joined Dec 2010
mcx / msr battery trays work well btw. Cut it off, and it has 2 pins that you can hot glue into place
Old Oct 19, 2011, 01:55 PM
NEVER GIVE UP!
Brooklyn, NY
Joined Nov 2010
What do you guys think about this.
I take one of these "book socks"
Cut it and measure to fit the batteries I am going to use (so they fit snugly). Then sew it shut so I am able to slide the battery in and out while keeping the UM connector visible. Do you think that would work?
http://www.amazon.com/Original-Book-.../dp/B00110JHDO
Old Oct 19, 2011, 05:18 PM
Dittsboylogan is offline
Find More Posts by Dittsboylogan
Joined Mar 2011
So, Is the Polecat overall better as a first 4 channel, for a guy with some simulator time ,than the T-28 because of the thicker wing? I'm going to get one soon and can't decide....
Dittsboylogan is offline Find More Posts by Dittsboylogan
Old Oct 19, 2011, 05:28 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
I would pick the T28 for a first 4 channel. Not as aerobatic, but easier to fly and just as tough if not tougher for taking some abuse.
bobly is offline Find More Posts by bobly
Old Oct 19, 2011, 05:31 PM
cardnation is offline
Find More Posts by cardnation
all crash, no burn
Joined Aug 2011
The polecat is a more advanced aircraft.
The T-28 is generally regarded as the best low wing trainer.
The T-28 wing may be "thinner" but it by no means fragile when speaking in terms of <2oz planes.
cardnation is offline Find More Posts by cardnation
Old Oct 19, 2011, 06:44 PM
MJF is offline
MJF
Find More Posts by MJF
MJF
Waiting Fer Da SEFF
MJF's Avatar
United States, GA, Perry
Joined Jul 2010
polecat is a great plane....Imo
MJF is offline Find More Posts by MJF
Latest blog entry: eflite ultimate 20-300
Old Oct 19, 2011, 09:54 PM
Joined Mar 2011
plus I'd like to put a 3-bladed F4u corsair prop. It looks sweet with that. Thanks for the info. I basically want a um 4ch. that after this one, i can get a Mosquito. Love that guys' looks.
Old Oct 19, 2011, 10:11 PM
bobly is offline
Joined Sep 2010
3 blade might look sweet, but doesn't have anywhere near the performance of the two blade. Probably would not fly well at all.
Old Oct 21, 2011, 05:35 PM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
next attempt
i got my replacement Polecat back today and the first thing I did was open it to see if there were any modifications. The only difference I noticed was that now there is a number on the foam in "sharpie" near the brick in the nose. I don't know if this is a "rework" number or if it is an "inspector" number or a serial number (it's just three digits - unlikely). Has anyone else opened a replacement and seen similar things? has anyone opened a NIB one and found numbers? I looked at the thread attachments and there aren't any shown in the couple of pictures.
Old Oct 21, 2011, 06:23 PM
vivcal is offline
Joined Jul 2011
my nib one has a #13 in the same place you are talking about
Discussion Ultra micro pole cat CaptDH Micro Ready-to-Fly 13 Jul 18, 2011 12:23 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 12:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Found Park zone/e-flite ultra micros kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 17, 2011 03:15 PM
Sold B&F J-3 Ultra Micro Cub By: Park Zone Jolly Roger1 Aircraft - Electric - Airplanes (FS/W) 6 Jun 16, 2011 05:42 AM
