Old Jul 23, 2011, 10:48 PM
Richard Cox is offline
Find More Posts by Richard Cox
Richard Cox
Thousand Oaks, CA
Joined Dec 2003
I am a male and an engineer. We don't read manuals except as a last resort.
I only opened the plastic bag to get the number stickers out.
Anyway, my CG was a little aft, so I removed some more foam and moved the
battery forward about an inch to get the CG in the range from the manual
Richard Cox is offline Find More Posts by Richard Cox
Old Jul 23, 2011, 10:56 PM
speedy01 is online now
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by bobly who bragged View Post
... On these little um's I don't know if any of mine had one (a manual) or not.
however, you had previously said:
...but the manual has the factory suggested (CG)in it.
Unbelievable. You tell a guy who asks what the CG setting should be that's it's in the manual (neglecting to tell him what the setting is)....and then you suggest that reading UM manuals is not warranted because they contain nothing worth noting.
Yes, that's as unbelievable to me as someone asking what the "original" (factory suggested) CG is without so much as bothering to check the manual!!
Gene K
speedy01 is online now Find More Posts by speedy01
Old Jul 23, 2011, 11:00 PM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
Interesting, I usually prefer a bit nose heavy vs tail heavy, but so far my experimenting has resulted in being most satisfied with my 160ma batteries all the way to the back. I don't have the foggiest idea where the cg is in relation to where the manual says it should be though. Maybe I'll check it out just for grins. I just move mine around till I get what I like then pretty well stick with that. My rolls at lower speeds really straightened out when I got the battery to the back. With my batteries toward the front unless I really had the throttle on, rolls would result in quite a bit of altitude loss. If I was flying fast enough they weren't bad though with the front of the battery about where the gear fits.
bobly is offline Find More Posts by bobly
Old Jul 23, 2011, 11:20 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
I wouldn't even do that much.
BryanEW710 is offline Find More Posts by BryanEW710
Old Jul 23, 2011, 11:33 PM
bobly is offline
Joined Sep 2010
Gene K
I told him that because I remember seeing it in the online manual when I tried to check about the adjustment to the aileron control horn. I didn't tell him what it was because I didn't pay any attention to what it said and didn't have the foggiest notion what it was. I still haven't opened the manual (if I have one) from the box and see no reason to do so. Sorry if I disappoint. But I do know from checking the online manual that it did not even mention having an adjustment for aileron movement on the control horn as other um's do which a previous poster verified that it does. So the manual ain't much help if it doesn't have such basic information as to where the movement adjustment for the ailerons is.
Don't know what you think I'm bragging about. I have nothing to brag about in this hobby. Way too old to brag and way too new to this hobby to have anything to brag about.
Old Jul 24, 2011, 02:00 PM
WSEN is offline
Find More Posts by WSEN
McCarthy, Alaska
Joined Jun 2004
Sounds like a great plane that would make a good companion to my Champ and T-28. Forgive me if it has been already mentioned but is the landing gear easily removable? I pretty much have to fly off grass.
WSEN is offline Find More Posts by WSEN
Old Jul 24, 2011, 02:06 PM
microflitedude is offline
Find More Posts by microflitedude
RCG -Minus Member
microflitedude's Avatar
United States, SC, West Columbia
Joined Oct 2009
Yep!
microflitedude is offline Find More Posts by microflitedude
Old Jul 24, 2011, 02:46 PM
bobly is offline
Joined Sep 2010
As above, yep easy to take off. And over grass seems to be super durable - don't ask how I know. Let's just say I have tested its durability already and it passes with flying colors. Nary a mark. The only mark I have on mine was because of the wheels - made a great landing on a parking lot, but a bit closer to the the parking stops than I should have been and the brakes didn't work well enough. Nose cone is now a bit crumpled looking, but that's all. I did add two pieces of tape. Out of the box, the top part is taped on the sides and back - I added two small pieces of tape across the joint at the front of the plane where it slopes back to meet the sides. This made it really solid in the front end. Maybe not needed, but totally unobtrusive and can't hurt.
Old Jul 24, 2011, 04:40 PM
Woody_99 is offline
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
And you might want to move or remove the tail gear too. Being taped to the rudder, if it hangs on something, it's going to try to tear the rudder off too.
Some of these micros, I have moved the tail wheel to the fuse, bent it and taped on.
Others, like this one, I took it off all together.
Grass landing is going to be my method too.
Woody_99 is offline Find More Posts by Woody_99
Old Jul 24, 2011, 07:01 PM
WSEN is offline
McCarthy, Alaska
Joined Jun 2004
Thanks a lot. Sounds like a winner. Guess I had better go order one now! Keep these reports and videos coming please!
Old Jul 24, 2011, 08:46 PM
BryanEW710's Avatar
Joined Sep 2010
I was wondering when someone would mention this.
Old Jul 24, 2011, 10:19 PM
kenelder is online now
Find More Posts by kenelder
kenelder's Avatar
USA, FL, St Petersburg
Joined Dec 2003
Today was flying mine at the local club field in about 8 to 10 mph winds. Still very stable and smooth even with the wind. Had a LOT of groundspeed downwind....
Full range of rolling circles, 4 point rolls, inverted flight, inside and outside loops, knife edge (not enough rudder and/or too nose heavy), tried upright spins (again too nose heavy).
Guess I'll have to check the CG. I've been putting my battery forward over the landing gear because the velcro is so strong I can barely get the battery out and putting the battery forward makes it easier (big fingers!).
Oh, forgot to mention- great landings in the wind on our paved runway. Kind of hard to taxi back though- wind kept wanting to roll it backwards
I forgot the darn video camera, sorry.
kenelder is online now Find More Posts by kenelder
Old Jul 25, 2011, 07:31 AM
edge_pilot is online now
Find More Posts by edge_pilot
From a Different Planet!
edge_pilot's Avatar
Lagrange, Ohio
Joined Jun 2005
mine is "out for delivery". Can't wait to get it in the air with all these great reviews.
edge_pilot is online now Find More Posts by edge_pilot
Old Jul 25, 2011, 09:18 AM
Woody_99 is offline
Woody_99's Avatar
Joined Jan 2009
Flight Report
Yesterday finally had the chance to fly the Pole Cat.
Initially, the ailerons were very sensitive and flying was twitchy. I ended up with 75% dual rate and 20% expo, and now if flys very smoothly.
Rudder and elevator needed a little more throw. Moved the link in one hole from the outside end.
Now that I have the controls set up the way I like, the Pole Cat is a good flyer and seems predictable.
It doesn't feel as fast as the UM Mustang (had one), but looks a little faster than the UM Trojan (only flow with others that have one).
I really like the color scheme too. Much easier to see than the Mustang.
I also have removed the landing gear, and tail wheel. As noted above, the tail wheel is taped to the rudder and can do bad things if it's snagged.
You can bend the wire and tape it back to the fuse if you wish to use it, and be more secure.
I didn't much care for the steering on the tail. A little cross wind blew it around pretty good.
Overall, it flys well. Not a speed demon, but stable and predictable.
The foam on the tail is really thin. Seems even thinner than the other UM's. Probably won't be long before I ding that up.
No real negatives to report. Just the tail wheel mounting, which isn't unique to this model.
So far, so good after I set it up for my style.
Old Jul 25, 2011, 09:26 AM
BryanEW710's Avatar
Joined Sep 2010
The rudder/elevator authority is my biggest concern with this plane. I'm used to 3D type aircraft with huge surfaces (even my UMX Yak-55), so I was wondering about adjusting the throws.
How's the vertical?
Discussion Ultra micro pole cat CaptDH Micro Ready-to-Fly 13 Jul 18, 2011 01:23 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 01:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 01:18 PM
Found Park zone/e-flite ultra micros kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 17, 2011 04:15 PM
Sold B&F J-3 Ultra Micro Cub By: Park Zone Jolly Roger1 Aircraft - Electric - Airplanes (FS/W) 6 Jun 16, 2011 06:42 AM
