Old Jul 03, 2012, 05:49 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
I'll try the stock battery, got loads of Eflite cells laying around because I don't use them!
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jul 03, 2012, 01:12 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
the new stock batteries that are coming with the Spitfire AS3X are now 25C and should be better than the old stock ones that I think were only 15C
coreman is offline Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Jul 03, 2012, 01:14 PM
BryanEW710 is offline
Find More Posts by BryanEW710
BryanEW710's Avatar
United States, OH, Cincinnati
Joined Sep 2010
Are they still $10 apiece? What a waste.
BryanEW710 is offline Find More Posts by BryanEW710
Old Jul 03, 2012, 01:30 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
Most likely, but at least they won't be as bad as the previous batch and the "included" ones can be used
Old Jul 03, 2012, 01:40 PM
BryanEW710's Avatar
Joined Sep 2010
Myeh...the OEM 150mah works fine on the XP, but I refuse to pay $10 per batt at the LHS when even the Nanotech is a better pack at almost 10% of the price.
Old Jul 03, 2012, 04:38 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
yep, I agree. I bought a couple dozen of the nanotechs when they were in stock for under $2 each. I gave away the 15c that came with my planes but I will probably use the 25c that will come with the Spitfire. not buy more, just use the ones they give me
Old Jul 04, 2012, 03:31 AM
B.C.NEWFIE is offline
Find More Posts by B.C.NEWFIE
B.C.NEWFIE's Avatar
Canada, BC, Port Alberni
Joined Jun 2012
but that's just it with the UM planes. A couple of grams of battery or glue repairs can really change the performance. I noticed it most on the UM 4-Sites I had. They started ok at 36g and were dogs long before they got to 40g
trial and error for me and the use of clue and repairs,.. too much on Champ,now it flies heavy "but was first plane" and i forsee having to replace pretty much whole plane lol.under $20 for wings, $50 for body thats pretty cheap considering ur get a brick with it. with my polecat i will be using clue sparingly,.. like your saying,.. it does add-up.all i have to do is look at my glue bottle,... i should out of "curiosity" get new bottle and wiegh both to see how much is acualy in the plane,that'll give me at least a good idea.
B.C.NEWFIE is offline Find More Posts by B.C.NEWFIE
Old Jul 04, 2012, 05:11 AM
GBLynden is online now
Find More Posts by GBLynden
I am GBLynden
GBLynden's Avatar
United States, WA, Lynden
Joined Mar 2011
It might be misleading. A lot of that weight is in the form of moisture.
GBLynden is online now Find More Posts by GBLynden
Old Jul 04, 2012, 07:03 AM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
well, not with CA but if you have the ability to weigh the glue bottle, weigh the plane instead!
Old Jul 04, 2012, 12:50 PM
B.C.NEWFIE's Avatar
Joined Jun 2012
lol yea,. makes sence coreman,....
Old Jul 04, 2012, 12:55 PM
B.C.NEWFIE's Avatar
Joined Jun 2012
so curently have the nose of my polecat lopted-off even with the front of the brick =( whole front end has been glue too many times and foam was hard as a rock and broke apart tryin to fix again.so my question is,.....does anyone have any "ideas/tricks" on doing this? im starting it regardless but any "imput" would be very appreaciated =D
Old Jul 04, 2012, 01:37 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
That is one of the problems with using CA for these types of repairs. it makes a brittle joint which then breaks on the virgin foam right next to it and so forth. Soon you have a 1/2" wide glue region. I have used "Hold the Foam" in the past for doing these repairs but that requires an overnight dry which isn't always convenient when at a flying session. I have heard of people using Gorilla Glue (the white dries fastest) After a while you end up just replacing the airframe parts. And at that point you need to look at it as if it's really just more cost effective to buy a second plane and use the brick on some other scratch built plane
Old Jul 04, 2012, 05:09 PM
BMFA 190658
Joined Mar 2007
That's what I did with my UM Stryker. It glued back well with GG (honey colour), I also taped over the repair to hold it together then left it on.
Eventually I got another Stryker and used the first as spares
Old Jul 05, 2012, 06:36 AM
I am GBLynden
GBLynden's Avatar
Joined Mar 2011
Has anyone clocked the speed of a stock PC? I am curious what the actual speed capability is of this thing.
Old Jul 07, 2012, 08:04 AM
B.C.NEWFIE's Avatar
Joined Jun 2012
the front end repair that i had mentioned worked-out unbelievably well =) you can barely see the "join" definitly quality foam is the ticket "doesnt flake off" as easily.,......got a question thoe guys,while i did that i change the default setting for the elevator,so it would have more "throw" it seems like that when i yank the stick for a sharp loop,the plane wants to the turn/spiral to the right i believe? too much of adjustment,too aggresive?
Last edited by B.C.NEWFIE; Jul 07, 2012 at 08:05 AM. Reason: sharp loop or vertical
Discussion Ultra micro pole cat CaptDH Micro Ready-to-Fly 13 Jul 18, 2011 12:23 PM
Discussion Park Zone Ultra Micro T-28 Battery Upgrade? itsme2 Electric Plane Talk 4 Jun 30, 2011 12:47 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Found Park zone/e-flite ultra micros kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 17, 2011 03:15 PM
Sold B&F J-3 Ultra Micro Cub By: Park Zone Jolly Roger1 Aircraft - Electric - Airplanes (FS/W) 6 Jun 16, 2011 05:42 AM
