Old Jun 29, 2011, 09:58 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Park Zone Ultra Micro T-28 Battery Upgrade?
I have some 3.7V 150mAh 12C Lipos that I use with my PZ Champ. The UM T-28 comes with a 3.7V 1S 120mAh battery. Will the Champ batteries work ok in the T-28, will I have to adjust the CG, is the Champ battery really a higher capacity then the stock T-28 battery?
Thank you.
itsme2 is offline Find More Posts by itsme2
Old Jun 30, 2011, 01:33 AM
efflandt is offline
Find More Posts by efflandt
efflandt's Avatar
United States, IL, Elgin
Joined Mar 2011
Not sure how the battery slot is on the UM T-28, but flew a variety of batteries in my UM J-3 Cub, 120 and 150 E-Flite/PZ and Thunder Power 160 (actually shorter than the 150). And since I used some of them in an mSR and did not want to put Velcro on them, I just made a Velcro strap to hold them in the slot, which did not necessarily keep them from sliding unless tension from the connector in the end slot kept them there.
So just see where in the slot gives the best CG, and as long as not tail heavy, just go fly it. You could always use a click or so elev trim on your Tx if necessary. But the pitch of the Cub tended to vary with throttle anyway, so I would adjust the throttle for level flight, and if I needed to punch into the wind, I would give it full throttle and a little down elevator with the stick.
efflandt is offline Find More Posts by efflandt
Old Jun 30, 2011, 11:24 AM
milehighjc is offline
Find More Posts by milehighjc
Mile High Pilot
milehighjc's Avatar
USA, CO, Longmont
Joined Jun 2010
I use the Thunder Power 160maH 25c batteries in mine... they are awesome. More power, made a significant difference in the performance of my UM T-28.
Edit : cheap too...
Your champ batteries will probably work fine - I use a pretty wide variety of packs in my T-28, its not OVERLY CG sensitive to different batteries.
jc
milehighjc is offline Find More Posts by milehighjc
Old Jun 30, 2011, 12:10 PM
itsme2 is offline
Joined Mar 2011
Edit : cheap too...
jc
Thanks mhjc for the info! How do you determine if the various batteries have the correct connector?
Old Jun 30, 2011, 12:47 PM
Mile High Pilot
milehighjc's Avatar
USA, CO, Longmont
Joined Jun 2010
I think the 1S micro packs are pretty universal - at least I havent seen one that didnt fit.
jc
For Sale Park Zone T-28 Trojan - LPU San Diego scharck Aircraft - Electric - Airplanes (FS/W) 9 Aug 14, 2014 08:38 PM
Found any Park Zone micro guts kino-schmid Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Jun 30, 2011 12:18 PM
Sold B&F J-3 Ultra Micro Cub By: Park Zone Jolly Roger1 Aircraft - Electric - Airplanes (FS/W) 6 Jun 16, 2011 05:42 AM
For Sale PARK ZONE T-28 RED AND WHITE TRADE FOR ParkZone Extra 300 PNP donho1 Aircraft - Electric - Airplanes (FS/W) 6 Apr 09, 2011 12:57 PM
For Sale Park Zone micro T-28 BNF!!!! tc3wins Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 7 Dec 21, 2010 06:07 AM
