Espritmodel.com Heli Air
Old Sep 06, 2011, 06:35 PM
Sky Pilot
four stroke pwr's Avatar
United States, FL, Orlando
Joined Feb 2004
The build instructions here are different than RC Factory
The build instructions from RC Factory emphasis this.. second page, Diagram C state: "IMPORTANT: if you glue the wing in normal (not inverted) position- the upper surface facing up-the stabilizer cutout in the backbone should also facing UP. On Diagram C the wing and the backbone are depicted in inverted position."
The build thread here shows the notch facing DOWN.
Comments??
four stroke pwr is offline Find More Posts by four stroke pwr
Old Sep 06, 2011, 07:12 PM
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Comments??
You are correct that it shows it that way in the manual. I don't remember if I had a manual or chose to disregard it.
I think you can go either way and it wont make a big difference but it is up to you.
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Sep 06, 2011, 10:29 PM
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
Actually, it does make a difference because the "backbone" is designed to build in a bit of right thrust on the motor mount. If you build it with the backbone upside down (the way Hercdriver unfortunately did), you will end up with left thrust on the motor instead of right thrust. A lot of folks who don't pay enough attention with the smaller RC Factory models make this mistake. But Herc is such a great pilot that he probably just compensates for the left thrust on his plane without thinking about it! Right?
Neil
Neil Morse is offline Find More Posts by Neil Morse
Old Sep 07, 2011, 10:42 AM
Columbia SC
Joined Feb 2005
That's a valid consideration also but I assure you that my plane does not have any left thrust. Checked, rechecked and checked again after I read your post.
However, I will change the build thread notes to reflect this point.
Old Sep 07, 2011, 11:03 AM
Registered Snoozer
Neil Morse's Avatar
Joined Jul 1999
The right thrust built into the backbone is very slight, but I assure you it is there. The front surface that the motor mount "wheel" is glued onto is slightly angled to the right as you look down from above. The other difference that you get by flipping the backbone upside down is that the horizontal stab will end up just slightly lower down than the correct position. Again, this is not a huge difference, but I figure it makes sense to build the plane the way the designer intended.
Neil
Old Sep 07, 2011, 11:12 AM
Columbia SC
Joined Feb 2005
Neil,
Not going to debate it. You have a valid concern. And I have updated the build log.
Old Sep 07, 2011, 11:16 AM
Registered Snoozer
Neil Morse's Avatar
Joined Jul 1999
No worries, Chris. I'm not looking for a debate, just stating my point of view.
Neil
Old Sep 07, 2011, 06:04 PM
Sky Pilot
Joined Feb 2004
I'm glad I asked.... before the build..
Old Sep 07, 2011, 06:33 PM
Twisted Realm's Avatar
New Jersey
Joined Aug 2008
Agree not debatable so yes build per manufactures specs Chris thank you for adding the notes to the build so others will be able to build per RcF specs. Neli, totally glad your enjoying your 1.2m loved the in flight photos you took I look forward in seeing some videos guys!
Heads up if you want one of these birds since we only have a few left and are unsure as to when they will be back in stock.
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Sep 12, 2011, 09:40 AM
Sky Pilot
Joined Feb 2004
Still struggling trying to select the correct motor, 70g or 100g. On my 39" RC Factory SU-29, I made a firewall and mounted the motor rearward, and I liked that. I'd like to find a 800-900 KV motor in that range so I can swing a little larger prop..
Old Sep 12, 2011, 10:08 AM
Registered Snoozer
Neil Morse's Avatar
Joined Jul 1999
How about a Torque 2818T/900 (or equivalent)?
Old Sep 12, 2011, 07:45 PM
Columbia SC
Joined Feb 2005
+1 Great motor for this plane!
Old Sep 22, 2011, 09:15 PM
Sky Pilot
Joined Feb 2004
I noticed that Twisted Hobby does not offer the 1.2M SU-29 anymore on their website..... Wonder why??
Old Sep 22, 2011, 09:30 PM
New Jersey
Joined Aug 2008
Awaiting a few revisions and updates. We will have them back soon.
Site Sponsor
Old Sep 23, 2011, 07:26 AM
Sky Pilot
Joined Feb 2004
Are those revisions to the web site or to the 1.2M SU-29?
Thanks..
Build Log Twisted Hobbys - Telink 43" SU 29 - Build, Fly, Vid hercdriver7777 3D Foamies 556 May 07, 2013 02:23 PM
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 990 Apr 19, 2013 10:38 AM
Discussion 1.2m versions of RC Factory models Mike Smart 3D Foamies 68 Nov 07, 2012 06:42 AM
Alert Telink - Now available in the USA at Twisted Hobbys!!! hercdriver7777 3D Foamies 200 Sep 20, 2011 04:48 PM
