This thread is privately moderated by yomgui, who may elect to delete unwanted replies.
Old Jun 29, 2011, 10:03 AM
yomgui is offline
Find More Posts by yomgui
Joined Feb 2011
Torque test bench for electric motors
This homemade torque test bench gives very good results.
If the drive's resistance and no-load torque are known or well estimated, it allows to modelize a motor's performances with precision, based on amps, volts and rpm measurements.
Calculated values for power at the shaft are close to measured values, with an average error of 0,7% (max error = 3 %, but with the motor being run under bad conditions, with bad efficiency).
In fact, I think I can modelize a motor in a quite better way than only using amps, volts and rpm measurements (with kv thought as constant). BUT, it is very very close to any model taking into account inductance and to me it proves their reliability (thinking about drivecalc).
Well, I think...! I'm not at all a scientist...
yomgui is offline Find More Posts by yomgui
Reply With Quote  (Disabled)
Old Oct 09, 2012, 04:32 AM
stealthdragonb is offline
Find More Posts by stealthdragonb
Australia
Joined Sep 2012
Hi, I know this is slightly an old topic but I have been doing very similar tests using a wind tunnel. Could you explain to me how you measured the torque. Did u have a force balance because then you can find prop efficiency using eff=thrust x velocity/ power where power=torque x omega. How does motocalc calculate propeller efficiency as I haven't found torque of the motor anywhere. An eqn would be really helpful. I would really appreciate your help. Thanks!
stealthdragonb is offline Find More Posts by stealthdragonb
Data Motor Data - test bench data for several hundred brushless motors. Dr Kiwi Power Systems 850 Feb 08, 2016 08:02 PM
Discussion Bench Test of APC E-props (11x5 to 15x6), Watts, Torque, Thrust Wise_Man Power Systems 46 Apr 14, 2014 06:46 AM
Build Log Building a Plane...for Free. Bench Test Video & Pics The Hog Pen Electric Warbirds 72 Oct 10, 2011 10:53 PM
Discussion Looking for Fredrik Wergeland - Great Electric Motor Test Ken Myers Power Systems 6 Jul 01, 2011 06:48 AM
For Sale Electric motor bench- test stand nakman8 Aircraft - General - Miscellaneous (FS/W) 0 Jan 17, 2008 02:20 PM
