Old Feb 17, 2013, 07:46 PM
d3c0yz3d is offline
Find More Posts by d3c0yz3d
Foam air frame tester
d3c0yz3d's Avatar
Australia, QLD, Gold Coast
Joined Nov 2012
Just bend the wire? Grab the collett on the end of the wheel with some pliers, support the main leg and twist.
d3c0yz3d is offline Find More Posts by d3c0yz3d
Old Feb 18, 2013, 01:30 PM
acekire is offline
Find More Posts by acekire
Norway, Ostfold, Skiptvet
Joined May 2009
Hi Guys.
I love this plane.
Takes time getting used too her size though. she is huge
I have 6 flights with her now and she looks great.
I use 2x4 cell 4000mah, but she still needs some additional nose weight.
I have ordered 2x 5000mah, and hope too get cg at 8-9 cm.
Have not tried stock prop yet, apc 18x12 works great.
Robart 3-3/4" scale tread wheels mounted.
Pz v2 (716) retracts and hk oleo struts shipping my way.
After some bad landings, Flap servo (red one) lost some teeth,
prop adapter Little off balance.
Do anyone know where too get spare adapter and reversed servo.
More great videos please.I will make videos when warmer.
greetings from Norway
Acekire
acekire is offline Find More Posts by acekire
Old Feb 18, 2013, 03:54 PM
mkharrell is offline
Find More Posts by mkharrell
mkharrell's Avatar
United States, FL, Navarre
Joined Nov 2012
Tow???
Sir, before I go and break something,,, can you exsplain in detail how to do this. Yes, this is only my second bird and first with retrax I just finished it today and took it on the road in front of my home to check the rear wheel set up. It did go to the left while rolling... and the tow on the left tire is towed out so that isn't helping. I was told that I should have both front tires towed slightly inward??? Is this true, and can you please tell me in detail how to fix my tow?
mkharrell is offline Find More Posts by mkharrell
Old Feb 18, 2013, 07:43 PM
mkharrell's Avatar
Joined Nov 2012
Me Again
Well eairlier today I went out and tested my tail wheel by going up and down the road,,, everything went fine just needed to reajust the tire.... Well 4 hrs. later I wanted to show my son the new P-47 and when I plug in the battery everything goes fine for the first 2 sec. then the motor starts beeping fast and have no motor controle????? What gives?
Old Feb 18, 2013, 08:03 PM
mkharrell's Avatar
Joined Nov 2012
Figured it out..... forgot I was messing with the thottle sub trim.......
Old Feb 18, 2013, 08:15 PM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
Going left could be from prop torque also.
Some like the wheels facing in to help slow it down, I like mine turned out a little to help slow down the plane on roll out.
Pull the retract out and on the sides is small hole (don't remmber size) then use one or two small screws as set screws. Maybe mark the position before pulling out so the wheels are lined up like you want when you re install.
Or pull it out and bend the wire strut to the proper angle, if you try it while installed you could pull it out of the plane by accident (I know from exp)
mcnowhere is offline Find More Posts by mcnowhere
Old Feb 19, 2013, 01:43 PM
Greg Gimlick is offline
Find More Posts by Greg Gimlick
Greg Gimlick's Avatar
Fuquay Varina, NC
Joined Dec 2000
Props in stock
Somebody asked a while back about getting a replacement scale prop...can't remember who, but here's a link to Hobby King with the prop:
http://www.hobbyking.com/hobbyking/s...dProduct=26969
They have them in stock right now for about $6
Greg
Greg Gimlick is offline Find More Posts by Greg Gimlick
Old Feb 19, 2013, 04:42 PM
d3c0yz3d is offline
d3c0yz3d's Avatar
Joined Nov 2012
I just ordered an APC 18x12x2 yesterday to try out on 4S 8800mAh 4P. I'll post up some results when I bolt it on.
Old Feb 19, 2013, 07:39 PM
Fuquay Varina, NC
Joined Dec 2000
That's what I'm flying on mine. APC-e 18x12 two bladed prop, stock motor on two 4S 4000mah packs in parallel.
Old Feb 19, 2013, 07:48 PM
mkharrell's Avatar
Joined Nov 2012
Time?
What kind of flying time can I expect from the battery pack system you are using
Old Feb 19, 2013, 07:49 PM
mkharrell's Avatar
Joined Nov 2012
Greg
That was me,,,,,,,,,,,,,,,,,,, thanks again Greg....
Old Feb 19, 2013, 08:10 PM
Fuquay Varina, NC
Joined Dec 2000
I have to admit I haven't timed one since I went to this prop. I fly til I'm ready to land and I've gotten two flights from the pack each time. I'll try to remember to set a timer the next time.
Greg
Old Feb 19, 2013, 08:13 PM
d3c0yz3d is offline
d3c0yz3d's Avatar
Joined Nov 2012
At a guess i think i got about 8min with the stock prop on 8800mAh.
Old Feb 19, 2013, 08:15 PM
Vieux Charles is offline
Find More Posts by Vieux Charles
Vieux Charles's Avatar
United States, PA, Macungie
Joined Dec 2012
In addition to the full cockpit interior, have other improvements been made to the V2 version that Hobby Lobby is selling?
Retracts.... Esc... Etc.........
Vieux Charles is offline Find More Posts by Vieux Charles
Old Feb 19, 2013, 09:42 PM
CrashMaster39 is offline
Find More Posts by CrashMaster39
Add your country to profile:)
CrashMaster39's Avatar
United States, CA, Crestline
Joined Oct 2006
Huh? I don't see any P-47 this big at Hobby Lobby. This Starmax Jug has a 1.6 meter wingspan. Please post link.
CrashMaster39 is offline Find More Posts by CrashMaster39
Help! Starmax P-51 Parts Kevin Greene Vendor Talk 0 Mar 11, 2011 10:56 PM
Discussion ParkZone P-47 Thunderbolt avengedkevinfold Electric Plane Talk 1 Mar 03, 2011 02:40 PM
