Old Feb 09, 2013, 12:19 PM
mkharrell is offline
Find More Posts by mkharrell
mkharrell's Avatar
United States, FL, Navarre
Joined Nov 2012
Awesome,,, thanks guys,,, I went withe the 3.5". My plane arrives this tuesday and it's my first warbird. I plan on pushing the rake out about 8 to 10 degrees... I've never done this nor have I ever put in retracts,,, so this will be interesting... I will be going back to this forum for all the intel. I can gather..... one again thanks for you advice.... I'm running with it...
mkharrell is offline Find More Posts by mkharrell
Old Feb 10, 2013, 01:52 AM
d3c0yz3d is offline
Find More Posts by d3c0yz3d
Foam air frame tester
d3c0yz3d's Avatar
Australia, QLD, Gold Coast
Joined Nov 2012
I flew mine today for the second time (first time with the CG NOT where the manuial put it) and in longish turf and i don't think it needed more rake on the undercarriage unless it's for scale purposes? The bigger tyre size for sure though.
The plane looks great in the sky and scale rolls look awesome. I think i might be considering the swap to a two blade setup though as i know what everyone means by being floaty with a bit of wind around. Its a real shame though because i think the prop looks great in the photos. I ended up flying full throttle for most of the flight and on a 30*C day everything came back down hot electronics wise.
Doing low passes the plane does carry impressive speed with 4 batteries on board and i think the speed is a little deceptive at altitude because it is such a big plane. One thing that caught me out is doing the low passes as trying to fly smoothly and not to many Gs i ended up pulling a pass out about 2ft off the deck, which looked unreal but scarred the crap out of me. It would have made a big mess if it hadn't pulled up that's for sure.
I emailed hobby lobby about buying a V2 cockpit set up and they said they should have stock on them in a few weeks which will be awesome. I also just got an airbrush so now i know she flies nicely let the mods begin!
Sorry i didn't have more low pass photos, as i was just getting used to flying the big girl and still a bit nervous with it and I just set up my DSLR and gave it to my girlfriend and she did the best she could.
d3c0yz3d is offline Find More Posts by d3c0yz3d
Old Feb 10, 2013, 09:46 AM
mkharrell's Avatar
Joined Nov 2012
Futaba 9C set up
I will be flying this bird with my Futaba 9C is anyone using this TX and if so what are you setting your Flap to Elevator Mix to? Thanks again...
Old Feb 10, 2013, 12:12 PM
ham is offline
ham
Find More Posts by ham
ham
Denmark, Capital Region of Denmark, Dragør
Joined Mar 2007
Nice photos I'm looking forward to warm weather when I can get mine in the air again. By the way, the maximum flap setting on the real thing is 40deg.
ham is offline Find More Posts by ham
Old Feb 10, 2013, 01:41 PM
Mikey 68 is offline
Find More Posts by Mikey 68
Field of Dreams Flyer
Mikey 68's Avatar
United States, CA, LA
Joined Sep 2004
I dont think so, they drop down pretty far
Mikey 68 is offline Find More Posts by Mikey 68
Old Feb 10, 2013, 02:36 PM
ham is offline
ham
ham
Joined Mar 2007
I have a copy of the training manual for the real P-47, so I'm sure it is 40degree max flaps
Old Feb 10, 2013, 02:40 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
When I drop my flaps - for landings - I can only drop one notch because if I go all the way down (two notches) that blame plane doesn't want to move forward anymore and I have to add a lot of power to continue decending! So the majority of my landings I use only one notch.
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Feb 10, 2013, 04:30 PM
d3c0yz3d is offline
d3c0yz3d's Avatar
Joined Nov 2012
Maybe it is 40* as I jet set it up based on pictures of P-47 with the flaps down and just tried to make my model look the same.
FWIW I don't have any mix on elevator when putting the flaps down and from my limited experience it really doesn't need it.
Old Feb 11, 2013, 10:13 AM
Greg Gimlick is offline
Find More Posts by Greg Gimlick
Greg Gimlick's Avatar
Fuquay Varina, NC
Joined Dec 2000
Flap/elevator mix
A couple of guys have asked about elevator/flap mix and I haven't seen a reply so I'll tell you what I did - nothing. For whatever reason, this plane just doesn't feel like it needs any, it doesn't balloon at all whether I go half way or full flaps. I have a LOT of flap on the full setting and the plane stays pretty level and floats forever. I love using the flaps and it will allow you to come to a crawl.
So the answer is I didn't put any mix at all in mine.
YMMV
Greg Gimlick is offline Find More Posts by Greg Gimlick
Old Feb 11, 2013, 11:13 AM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
If you are flying at a pretty fast rate and drop the flaps, yes the plane will balloon but you really shouldn't use flaps at that speed. I slow the plane down, drop one notch and maybe (depending on how high I am), use some down elevator to start the decent. With full flaps and a little headwind, the plane doesn't want to come down.
Old Feb 11, 2013, 05:08 PM
d3c0yz3d is offline
d3c0yz3d's Avatar
Joined Nov 2012
Originally Posted by Greg Gimlick View Post
A couple of guys have asked about elevator/flap mix and I haven't seen a reply...
YMMV
Lol how about the one above your post?
Old Feb 11, 2013, 11:05 PM
CrashMaster39 is offline
Find More Posts by CrashMaster39
Add your country to profile:)
CrashMaster39's Avatar
United States, CA, Crestline
Joined Oct 2006
I will third or fourth that, I don't need to mix ANY elevator with flaps on this plane, on half or full setting. I love the flaps on this bird. I even had good luck with them in strong wind yesterday.
CrashMaster39 is offline Find More Posts by CrashMaster39
Old Feb 13, 2013, 06:53 AM
mkharrell's Avatar
Joined Nov 2012
Just wanted to thank you guys for answering someof my questions.... Just got the bird in the mail last night. I see that the instructions are not very detailed... Hope I can figure this out... (first time) I also see that there are some lines in the foam where the wires go through that I'd like to fill in and then paint... What brand and color paint is the silver on this plane? My retracts, oleo struts are caught up in the Hong Kong party they have going on over there.... I did order the 3.5" wheels, they will be in this Friday,,, but can't do anything until my other parts come. I ordered this from Hobby King and thought that the top came off for access to the inside of the plane... didn't look very much for it lastnight,, will double check today.... what do you use to secure the canopy to the plane. I am also waiting on my pilot to arrive,,, it's back ordered... so I don't want to perm. attach it to the plane....
Old Feb 13, 2013, 08:11 AM
Fuquay Varina, NC
Joined Dec 2000
Hmmmmmm, how about that :-) that's what I get for skimming over things too quickly.
Old Feb 13, 2013, 01:57 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
you are forgiven.......THIS TIME
Help! Starmax P-51 Parts Kevin Greene Vendor Talk 0 Mar 11, 2011 10:56 PM
Discussion ParkZone P-47 Thunderbolt avengedkevinfold Electric Plane Talk 1 Mar 03, 2011 02:40 PM
