Old Feb 04, 2013, 10:05 AM
Olearsenewbie is online now
Find More Posts by Olearsenewbie
United States, GA, Douglasville
Joined Apr 2012
I'm really frustrated with the quality control of this model.
1) Not enough screws for the control horns
2) pushrod for the elevator too short!
Now I have to buy stuff for a new plane that should have everything. Choosing to mod is one thing; having to buy items that should be in a kit is very frustrating.
Just needed to vent.
Olearsenewbie is online now Find More Posts by Olearsenewbie
Old Feb 04, 2013, 12:49 PM
Mikey 68 is offline
Find More Posts by Mikey 68
Field of Dreams Flyer
Mikey 68's Avatar
United States, CA, LA
Joined Sep 2004
Originally Posted by ham View Post
That's not always a good idea with the big four plade prop. I broke one prop while belly landing on grass.
Well I rather chance the prop then ripping out a landing gear.
Mikey 68 is offline Find More Posts by Mikey 68
Old Feb 04, 2013, 12:55 PM
Mikey 68 is offline
Mikey 68's Avatar
Joined Sep 2004
Or you can get them from KMP
Towards the bottom of the page
http://www.kmp.ca/product_info.php?c...6e208cffc4ad52
Old Feb 04, 2013, 03:12 PM
marianmacek is offline
Find More Posts by marianmacek
Slovakia, Trnava Region, Piestany
Joined Feb 2013
Originally Posted by PeterVRC View Post
Did you paint the plane and THEN add some 'splashes' of silver for mimicking chipping?
It looks great... a lot of detail.
Oh, and I guess you painted the wheel hubs? (the silver)
And why did they actually ever put checker patterns onto aircraft noses? (the ones that did that). To defeat the camo so enemy COULD see them better!?? LOL
Good evening,
I wear glasses, so I need to be visible to aircraft in the air ............
Marian Macek
marianmacek is offline Find More Posts by marianmacek
Old Feb 04, 2013, 07:40 PM
mkharrell is offline
Find More Posts by mkharrell
mkharrell's Avatar
United States, FL, Navarre
Joined Nov 2012
Originally Posted by Olearsenewbie View Post
Get them from the HK China warehouse:
http://www.hobbyking.com/hobbyking/s...Propeller.html
Thanks brother,,,, bought 4 of them... Thank you...
mkharrell is offline Find More Posts by mkharrell
Old Feb 04, 2013, 07:46 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Let us know when they come in....I'm still waiting on struts from them.......
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Feb 04, 2013, 09:26 PM
Mikey 68 is offline
Mikey 68's Avatar
Joined Sep 2004
Good luck as the Chinese New Years starts soon , you may not get them for weeks
Old Feb 05, 2013, 06:29 AM
djberna is offline
Find More Posts by djberna
Uruguay, Flores, Trinidad
Joined Oct 2012
Spare Parts
Hi guys. I noticed yesterday that hobbyking has some spare parts for this planes but I would like to know where can I get a fuselage and a cowl. I need a place that ships worlwide. Any information would be appreciated!
djberna is offline Find More Posts by djberna
Old Feb 05, 2013, 07:26 AM
mkharrell's Avatar
Joined Nov 2012
That's why I'm praying I put my order in soon enough... but thanks for the heads up
Old Feb 05, 2013, 11:19 AM
Joined Apr 2012
you're welcome. hopefully you won't need'em...
Old Feb 08, 2013, 07:18 PM
mkharrell's Avatar
Joined Nov 2012
Intel. Needed
Ok,, I have 2 questions.
1) where can I get 3.75"or 4" wheels for this bird and are thin enough to fit flush with the wing after some cutting when retracted? I need to order them before my bird gets here..... which is very soon....
2) What kind of mix are you guys using for flap to elevator?
Thanks In Advance,
Mark
Old Feb 09, 2013, 04:47 AM
d3c0yz3d is offline
Find More Posts by d3c0yz3d
Foam air frame tester
d3c0yz3d's Avatar
Australia, QLD, Gold Coast
Joined Nov 2012
Just put my P-47 on the watt meter after making the cables to run 4 x 2200mAh 4S and scored 70A @ 1100W constant with the stock prop.
Definitely felt like it was pulling a lot harder than just running 2x 2200mAh packs I ran it on previously (but didn't run it with the Watt meter).
d3c0yz3d is offline Find More Posts by d3c0yz3d
Old Feb 09, 2013, 11:28 AM
mkharrell's Avatar
Joined Nov 2012
Thanks In Advance,
Mark
Can anyone help me??? I was thinking about these tires??? but are they too thickhttp://toysonics.com/dave-brown-wr40-treaded-big-wheel-4.html
and can you give me what kind of flap to elevator mix your useing?
Old Feb 09, 2013, 11:36 AM
Mikey 68 is offline
Mikey 68's Avatar
Joined Sep 2004
Thanks In Advance,
Mark
Heres what I did with my friends P-47
http://www.rcgroups.com/forums/showp...&postcount=208
And I think these where the wheels I used
http://www3.towerhobbies.com/cgi-bin...?&I=LXB929&P=7
Old Feb 09, 2013, 12:13 PM
CrashMaster39 is offline
Find More Posts by CrashMaster39
Add your country to profile:)
CrashMaster39's Avatar
United States, CA, Crestline
Joined Oct 2006
Hi MK, I am using 4 inch Dave Brown treaded foam wheels on this bird and I really like them. I wouldn't mind if they were 4.5" even. BUUUUT it was a hassle to get them to fit. If I was to do it over again, I might start with 3.5 inch. My 4" wheels do fit flush, but my HK aluminum oleo struts stick up some with my 514 retracts. In one small spot I had to grind the wing down to less than 1mm thick. I have pictures of everything in this thread, 6 or 8 months back. I love these big soft wheels and shock absorbing struts, you can clearly see them cushion landings.
FYI: you can find lots of info on other setups it you click THREAD TOOLS then SHOW ATTACHMENTS IN THIS THREAD, then click on a pic of landing gear, THE TRICKY PART which was not obvious to me is, when looking at the picture, to go to that specific post and read about it, you must click on the single lowercase word (post) underneath the picture. It is just one word in a whole line, same color as all other text, so not obvious, but VERY handy.
CrashMaster39 is offline Find More Posts by CrashMaster39
Help! Starmax P-51 Parts Kevin Greene Vendor Talk 0 Mar 11, 2011 10:56 PM
Discussion ParkZone P-47 Thunderbolt avengedkevinfold Electric Plane Talk 1 Mar 03, 2011 02:40 PM
