Old Jan 23, 2013, 10:13 PM
Greg Gimlick is offline
Find More Posts by Greg Gimlick
Greg Gimlick's Avatar
Fuquay Varina, NC
Joined Dec 2000
Will do, I should see him Saturday unless we get the snow they're calling for Friday :-/
Sorry I don't remember specifics on the retracts.
Greg
Greg Gimlick is offline Find More Posts by Greg Gimlick
Old Jan 23, 2013, 10:18 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Have you ever taken the cowl off? What holds it on?
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Old Jan 23, 2013, 10:54 PM
CrashMaster39 is offline
Find More Posts by CrashMaster39
Add your country to profile:)
CrashMaster39's Avatar
United States, CA, Crestline
Joined Oct 2006
There are screws, one on each side, like wood screws that go in from the sides. They are hard to see, the holes are probably through the stickers, or maybe under the stickers if it came to you with the cowl already on. Once the two screws are out, the cowl just pulls off easily, forward. Then after the cowl is off, the foam radial engine piece just pulls out the front, tight fit.
CrashMaster39 is offline Find More Posts by CrashMaster39
Old Jan 23, 2013, 11:09 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Thank you....my engine is 'lose' and I checked the four motor mounts (with the cowl on) and they were tight so somewhere back there something is giving!
Old Jan 23, 2013, 11:15 PM
Joined Oct 2006
Greg, one of my landing gears seem weak....do you know of any replacements?
I'm using the HK 514 retracts, these two links below will give you info on what I did to retrofit. They are larger and stronger than stock, but not a drop in fit.
http://www.rcgroups.com/forums/showp...&postcount=417
http://www.rcgroups.com/forums/showp...&postcount=385
If I was doing it over again, I might get these even larger PZ-V2 (716) retracts because they move real slow and scale. They are $20 each though and even more work to retrofit. http://www.rcgroups.com/forums/showp...&postcount=420
Old Jan 23, 2013, 11:21 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Thanks for the head's up and the links.....
Old Jan 24, 2013, 03:48 AM
ham is offline
ham
Find More Posts by ham
ham
Denmark, Capital Region of Denmark, Dragør
Joined Mar 2007
That's exactly the same that happened to mine. I bought the 716s as Crashmaster mentioned and you can see them in these posts. They work very well and seem strong and slow.
http://www.rcgroups.com/forums/showp...&postcount=438
http://www.rcgroups.com/forums/showp...&postcount=455
http://www.rcgroups.com/forums/showp...&postcount=519
http://www.rcgroups.com/forums/showp...&postcount=534
ham is offline Find More Posts by ham
Old Jan 24, 2013, 07:58 AM
Beancounter is online now
Find More Posts by Beancounter
Beancounter's Avatar
United States, MA, Sterling
Joined Sep 2009
If anyone needs a replacement I have an extra ESC that I don't need after motor change
http://www.rcgroups.com/forums/showthread.php?t=1816013
Beancounter is online now Find More Posts by Beancounter
Old Jan 24, 2013, 08:39 AM
Fuquay Varina, NC
Joined Dec 2000
Cool, I went to bed and before I logged on this morning, everyone answered your questions :-)
Greg
Old Jan 24, 2013, 08:56 AM
Joined Oct 2006
Ham, maybe it is because I love AC-DC, but I think that video in post 519 is GREAT. Love the switching between two views of the same part of flight, too cool. Those fat rubber tires and slow retracts are neat. My soft 4" foam wheels work well, but don't look nearly as cool. Keep the videos comin!
Old Jan 24, 2013, 09:31 AM
ham is offline
ham
ham
Joined Mar 2007
Thanks again Crashmaster I hope to get more footage when temperature around here gets above freezing again
Old Jan 26, 2013, 03:15 PM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Does anyone have the same situation as I do: The motor seems to flex when I try to move it; removed the cowl; 4 screws are tight; firewall isn't broken; should I be concerned?
Old Jan 26, 2013, 07:12 PM
d3c0yz3d is offline
Find More Posts by d3c0yz3d
Foam air frame tester
d3c0yz3d's Avatar
Australia, QLD, Gold Coast
Joined Nov 2012
I guess it depends how much you are talking about. It is a long shaft attached to foam so while it doesnt droop, if you grab the end of the spinner there is a bit of "give" even after re-expoying my firewall.
When i was setting up the flaps i set up another switch to give me a "combat flap" setting with around 12* for flaps just for scale shits and giggles. Be interesting to see how it makes the plane fly and whether i end up ripping the flaps off trying to do turns with them down lol. I also tired to set up scale looking flap angles, so again it will be interesting to see how it flies with full landing flaps out. Unfortuantely there are massive wind and rain storms around at the moment, so i'm just finishing three models i have on the go atm.
I was just reading back and saw some comments on CG and i maidened mine at 105mm as per manual and it was not nice! Is the general concensus 95mm for the correct CG.
After reading Greg's posts i might try 4 x 4S 2200s too. 4S 2200 seems to be a good size to invest in.
d3c0yz3d is offline Find More Posts by d3c0yz3d
Old Jan 26, 2013, 10:15 PM
miketre is offline
Find More Posts by miketre
miketre's Avatar
Joined Dec 2010
I flew the P-47 yesterday and got an unpleasant surprise flying it in windy and gusty conditions - it was the hardest plane to control despite being the biggest. The wings were rocking back and forth like a pendulum.
I think it's because it also has the lowest wing loading, and could benefit from heavier batteries.
Here's the video. Seeing the hard landings made me cringe
takeoffs, landings and crashes - Durafly P-51, Starmax 70mm F-86, 1.6m P-47, 50mm SU-34 (7 min 14 sec)
miketre is offline Find More Posts by miketre
Old Jan 27, 2013, 12:30 AM
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
I don't know where these guys fly, but I won't ever complain about our club's field!
Help! Starmax P-51 Parts Kevin Greene Vendor Talk 0 Mar 11, 2011 10:56 PM
Discussion ParkZone P-47 Thunderbolt avengedkevinfold Electric Plane Talk 1 Mar 03, 2011 02:40 PM
