Old Dec 11, 2012, 04:37 AM
Aivar is offline
Find More Posts by Aivar
Estonia, Harju maakond, Tallinn
Joined Mar 2012
Originally Posted by Aivar View Post
Hi !
My last settings is motor Turnigy L5055 400KV & 6s 5000mah lipo & APC 16X12 thin electric prop tested pest speed and vertical power .Test. telemetri system Guanum, max 72A for vertical & 65mph+flight speed +9min flight taim !. Plane veight is now 4030g & tis is perfeckt for my. Sorry bad video: http://youtu.be/OOr4crVVFvs?t=2m4s
Best regards
Aivar is offline Find More Posts by Aivar
Old Dec 11, 2012, 02:56 PM
ham is offline
ham
Find More Posts by ham
ham
Denmark, Capital Region of Denmark, Dragør
Joined Mar 2007
Had just as much trouble as you guys getting the cables to the tail wheel steering to be right. Found a training manual for the real P-47, and it doesn't have tail wheel steering. Only a lock for use during take off and landing
ham is offline Find More Posts by ham
Old Dec 11, 2012, 05:24 PM
Jackson Stone is offline
Find More Posts by Jackson Stone
Feeling the THRALL
Jackson Stone's Avatar
USA, CO, Parker
Joined Dec 2009
P-47 Startup, Ground Handling and Take off
Ham (and others),
Yes, I was interested to learn that the real P-47 does not have a steerable tail wheel. Instead it either swivels or is locked in line with the main wheels. The tail wheels is allowed to swivel while taxiing, with steering accomplished by rudder and brakes, then locked for take off or landing. Watch this video when you get a minute to see the whole start-up, ground handling and take off sequence.
Cheers,
Jackson
P-47 takeoff (2 min 45 sec)
Jackson Stone is offline Find More Posts by Jackson Stone
Old Dec 11, 2012, 05:35 PM
Feeling the THRALL
USA, CO, Parker
Joined Dec 2009
P-47s in action during 1945
Here's another video featuring real WWII footage of P-47s that has an almost identical cockpit check sequence to the previous video, followed by some really exciting aerial sequences. The closing credits suggest this activity may have all occurred on one day in the spring of 1945. You get to see what 8x50 cals can really do. Great stuff!
Jackson
http://www.youtube.com/watch?NR=1&v=...ture=endscreen
Old Dec 11, 2012, 06:55 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Yeah, let it pivot freely and fit brakes instead!! LOL
PeterVRC is offline Find More Posts by PeterVRC
Old Dec 11, 2012, 07:45 PM
CrashMaster39 is offline
Find More Posts by CrashMaster39
Add your country to profile:)
CrashMaster39's Avatar
United States, CA, Crestline
Joined Oct 2006
Hi !
My last settings is motor Turnigy L5055 400KV & 6s 5000mah lipo & APC 16X12 thin electric prop tested pest speed and vertical power .Test. telemetri system Guanum, max 72A for vertical & 65+flight speed +9min flight taim !. Plane veight is now 4030g & tis is perfeckt for my. Sorry bad video: http://youtu.be/OOr4crVVFvs?t=2m4s
Wow Aivar, your plane is FAST on 6s! I don't think I need quite that much speed, I'm happy with 5s on the 16x12 prop, but it is good to see than even more speed is possible with this airframe. If I had some 6s batteries on hand, I'd give it a try just to see.
Did you brace or strengthen the wing? That looked like some high g loading.
Where do you live?
Greg
CrashMaster39 is offline Find More Posts by CrashMaster39
Old Dec 11, 2012, 09:04 PM
Feeling the THRALL
USA, CO, Parker
Joined Dec 2009
Aivar,
Very impressive speed and power with your P-47. Sounds like you have achieved an optimal system for power and efficiency - witness the long flight times.
I hope that you can get us an improved quality of video to watch in the future.
Sincerely,
Jackson
Old Dec 11, 2012, 09:27 PM
Jose5x5 is offline
Find More Posts by Jose5x5
The ground is my Enemy!!!
Jose5x5's Avatar
Joined Aug 2008
I Have some 6S you can give a try
Jose5x5 is offline Find More Posts by Jose5x5
Old Dec 11, 2012, 09:35 PM
Feeling the THRALL
USA, CO, Parker
Joined Dec 2009
Source of Hardware - Retract Pins
I am just working on my landing gear to get ready for flight tomorrow and think I may want to have some replacement pins to go between the struts and servoless retract. This steel pin is 5mm in diameter by 30 mm in length. Does anybody have an idea on what is a good source for this piece of hardware?
Jackson
Old Dec 11, 2012, 10:46 PM
Feeling the THRALL
USA, CO, Parker
Joined Dec 2009
Prop Test Data
Testing results at full throttle for four props on my P-47 equipped with Heads Up RC Firepower 80 sized motor. Dimensions 50 x 65 mm. Kv of 410. All tested with freshly charged 5000 mAh, 4S battery.
APC 15.5 x 12 x 4 33.5 amps, 511 watts
APC 16 x 12 x 2 27.1 amps, 426 watts
APC 17 x 12 x 2 30.5 amps, 475 watts
Stock 16 x 8 x 4 50.8 amps, 785 watts
Regards,
Jackson
Old Dec 11, 2012, 11:35 PM
Joined Oct 2006
Jackson, I like the data of that 4 blade APC 15.5 x 12 x 4. Should be a fast with that. Are you going to be able to try that out in the air any time soon? How does it look? Are you going to paint it black and put yellow tips? Please post some pics when you get it all set.
Hey Jose, we may have to try the 6s, that guy's plane was super fast, it looked like some little jet to me. I forget, are you using Dean's connectors? I'll need to make and adapter to XT60.
Old Dec 11, 2012, 11:51 PM
PeterVRC is offline
Joined Nov 2006
I buy motor shafts and cut them for pins.... (eg 4mm, 5mm)
Old Dec 12, 2012, 06:19 AM
Joined Oct 2006
For the landing gear pins, I'm using hardened steel music wire that I cut to length with a hacksaw. For 5mm I bought the SAE equivalent size, which is super close, they had it at my local hobby store. But next time, I'll try motor shafts like Peter suggests.
Old Dec 12, 2012, 07:31 AM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
I've found that piano wire bends .... I don't have the equipment / care / ability to harden them correctly (despite trying).
I like the prop shaft idea (love RCG for new ideas)... I have resorted to using old screwdriver shafts of the right diameter... even cheap screwdrivers use correctly hardened shafts... Just take your micrometer to the hardware store !!
Toppers is offline Find More Posts by Toppers
Old Dec 12, 2012, 07:35 AM
Toppers is offline
Toppers's Avatar
Joined May 2008
Here are my figures for the stock motor with 4S freshly charged... the numbers are peak...
Stock 16x10x4 ... 995W
TGS 16x10x2 ..... 543W
JM ... 16x12x2 .... 562W
TGS 17x8x2 ....... 455W
I've been using the 16x12x2 and have been very happy with the performance and thrust.
Regards,
Jackson
Help! Starmax P-51 Parts Kevin Greene Vendor Talk 0 Mar 11, 2011 10:56 PM
Discussion ParkZone P-47 Thunderbolt avengedkevinfold Electric Plane Talk 1 Mar 03, 2011 02:40 PM
