Old Jul 12, 2012, 10:17 AM
brokenenglish is offline
Find More Posts by brokenenglish
Sticks, Tissue & old Diesels
brokenenglish's Avatar
France, Centre, Amboise
Joined Nov 2011
George, that's exactly why I built my current Ajax, except that my first attempt was a Playboy, with a propeller shaped wing glued to the fuselage.
The Playboy is now another kit that I've picked up on eBay, "with a few bits missing", so it'll get built one day, like the Slicker!
brokenenglish is offline Find More Posts by brokenenglish
Froglube is offline
Find More Posts by Froglube
Froglube's Avatar
United Kingdom, England, Lancs
Joined Jul 2012
Ah, well, perhaps i better make another motor and braid it properly (or get a adult to help me as they say on kids shows). I'm still tempted to give the pigtail a go but on something more expendable than one I have just finished. Theres a Westwings Jade which has solid sheet sides thats mainly occupying space.
Thanks for the info Sundancer, I will try and get my head around it as I do so hate drooping rubber and the poor glides you then get. Construction for aeromodellers is a book I have been looking for for a while. The nearest I've got is the chap who runs the model shop in Oxford let me take his prized copy og the MAP Aeromodeller pocket data book to the newsageants on the same road and photocopy it all. I've a few modern books but I realy like the style of the earlier ones.
To get around the covering the handles in lube problem (using the top of the banister leading up into my shed was a bad idea...) I have drilled peg holes into the 1/2 inch square rim I put on the false top I made for my work bench. So everytime I have to make a different size loop I drill in another hole and write next to it what distance it is from the furthest peg hole. And after a lot of messing about trying to hold bits of wire as I solder or bend them for undercarts there now some leetle 20 and 18 gauge holes which match the distance bewteen the tubes on various models. You'd be horrified how long it took me to come up with that.
When I remake the Ajax as well as using the correct wood (praises unto those who sell it by weight/density/cut) I will be adding more spars as well. Out board wasn't as pretty for the dowels but I'm glad I did as it gave me a bit of wriggle room for moving the wing slightly back and forth for trimming. I realy need to get a lot more field time as I am quite poor at setting up the wings, thrust lines et al for getting the best flights.
Yup I'm in the UK, East Lancashire up in the Penines. We moved here without much thought for flying conditions (well none) and the same year they built a wind farm which we can just see if I go to the front gate. Not a good place for the small lightweight FF planes I like.
Thanks for all the input!
ATB
Tom
Froglube is offline Find More Posts by Froglube
Old Jul 12, 2012, 12:14 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Originally Posted by Sundancer View Post
Ah well Jim, the penalty of being a late starter. I made just as appalling a mess of my first kit - the ubiquitous Achilles -...... I really must build another Achilles one day if only to prove that I have learned something over the last 64 years!
My first rubber powered kit, aside from a lot of sleek streaks and chuck gliders, was also an Achilles. It flew reasonably well, although I had no clue about the rubber motor and can recall being very confused about how much rubber was supposed to be used to make the motor. Eventually the fuse finished up about 2" long after an over zealous windind.
sparks
sparks59 is offline Find More Posts by sparks59
Old Jul 12, 2012, 01:20 PM
Applehoney is online now
Find More Posts by Applehoney
Ajax, Ontario, Canada
I 'started' at about 9 years of age with crude attempts at solid gliders, one of which - from a prewar sort of tabloid with photos of biplane airliners, etc. - 'flew' about 100 yards down a hill steeper than its glide path. Left me open-mouthed and remember that flight to this day - hooked! V dhedral, twin fins .. have never traced that publication since.
As for that first doomed rubber model - I/ve always had a suspicion I drilled the prop side to side too.....
The replica....
Applehoney is online now Find More Posts by Applehoney
Old Aug 10, 2012, 02:26 AM
Froglube is offline
Froglube's Avatar
Joined Jul 2012
Finally got to test fly the Veronite no. 4., was out at 7.30 towing a camera armed and yawning 11 year old and got in 6 flights before hunger and the weight of dew sagging the thinly doped tissue drove us inside. No wind, overcast but not cool.
This is where my inexperiance really shows! The test glides showed it pulled hard to the left and this was cured with altering the fins position in relation to the planes axis. I left in some turn under no power. A tendancy to fly into the ground was helped by a shim on the nose block but I will have to alter the hook for the rubber band that keeps the tail on at the rear as the band came off a few times causing acrobatics.
I will sort that, see to any warps that form on drying it out and get some more flights in. Will also read up o flight trimming again
Will be happier when i am doing the No. 3 as I'm used to high wings!
ATB
Tom
PS Think I will put more wash out in when I steam the wings to cure the enevitable warps on drying out, I may have been too subtle first time around.
Originally Posted by Froglube View Post
Finished the Veronite No 4 just now, a Jack Leadbetter design for the Model Aircraft Stores (Bournemouth) about 1939, 21 3/4 inch span. Herself has braided me 3 x 16" loops of 1/8 rubber which I will fit when the weathers better and will then balence and trim it. I pretty much stuck to the plan except for the plastic wheels and prop and used bamboo pegs rather than wire hooks for main wing elastic band attachement points
Does anyone know if MAS had a logo I can make a decal of as the tail looks rather bare?
ATB
tom
Old Aug 10, 2012, 12:50 PM
sparks59 is offline
Sic itur ad Astra
sparks59's Avatar
Joined Aug 2009
Congrats on the successful maiden Tom!
sparks
Old Sep 15, 2012, 12:22 PM
ckimmey is offline
Find More Posts by ckimmey
Master of the 1 point landing
ckimmey's Avatar
United States, IN, New Palestine
Joined Aug 2011
Comet JN4 Jenny.
23" span.
Rubber to electric 4-channel r/c conversion.
She is still naked, but will have a set of "clothes" soon.
You can see the build thread in the micro/indoor forum.
Next project: 25" Comet Piper Cub r/c conversion.
Thanks to all for the plans.
ckimmey is offline Find More Posts by ckimmey
Old Sep 15, 2012, 08:19 PM
jonquinn is online now
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
Did you have a tiny bellcrank in the Jenny for the ailerons? I can't quite make that out in the photo of it uncovered.
jonquinn is online now Find More Posts by jonquinn
Old Sep 15, 2012, 10:07 PM
ckimmey is offline
ckimmey's Avatar
Joined Aug 2011
I did make 2 tiny bellcranks for the ailerons. They are 1/32 plywood with a 3/32 tube slid onto a 1/16 tube for a hinge. 1:1 ratio on the throw at 90 degrees.
Old Sep 19, 2012, 04:21 PM
chroters is offline
Find More Posts by chroters
Lamaflieger
Germany, NRW, Nottuln
Joined Feb 2004
Topsy from Graupner
Remake of the Topsy from Graupner ( Germany).
I made an Cad Model and then milled all parts.
More pictures here:
Topsy
Walkaround:
Wingspan 32,3"
Motor: 0,5ccm Schlosser Diesel
chroters is offline Find More Posts by chroters
Old Sep 19, 2012, 09:15 PM
boingk is offline
Find More Posts by boingk
boingk's Avatar
NSW, Australia
Joined Feb 2011
Nice work mate, very sharp indeed.
Where did you get your diesel engine? I'm after one myself but can't seem to find any for the life of me.
Cheers - boingk
boingk is offline Find More Posts by boingk
Old Sep 19, 2012, 10:11 PM
algy2 is offline
Find More Posts by algy2
Joined Jun 2011
Hi Boingk,
Diesel engines are easily obtained in Australia. Just go here: http://www.pelaero.com.au/
That is the home page of PELAERO PRODUCTS. Great site for all your Free Flight supplies and a very experienced friendly aero modeller guy running it. Prices are good with no need to buy overseas.
At the bottom of that Home page there is a link to DAVID OWEN and his price list for some very nice PAW, LETM and MP JET diesel engines. I own a number of PAW’s and purchased one of the JET MP engines from David a few years back. It is a little gem with very easy starting and runs beautifully. Just what you need for free flight.
David also stocks spares and accessories for the engines he sells.
It is much cheaper to mix your own fuel. You should be able to find a source for the Either in Sydney, I did in Tasmania, and also buy your Caster Oil in bulk. Kerosene is easily available from hardware stores etc. Add approximately 2% of a diesel fuel improver sold for the “Big Rigs” from one the many Automotive outlets and your set to go.
Cheers
Algy
algy2 is offline Find More Posts by algy2
Old Sep 20, 2012, 01:17 AM
boingk is offline
boingk's Avatar
NSW, Australia
Joined Feb 2011
Thanks for that Algy, very much appreciated!
- boingk
Old Sep 20, 2012, 08:28 PM
Teals1 is offline
Find More Posts by Teals1
Teals1's Avatar
New Zealand, Auckland, Papakura
Joined Nov 2006
Diesel fuel
Hi Algy2
Interested to know more about the 'diesel fuel improver' you talk of in your post. The Iso-propylnitrate is near impossible to get here. What is the actual name of the improver you use? I did read somewhere that nitro will do the same job. Do you know anything about that?
Allen
Teals1 is offline Find More Posts by Teals1
Old Sep 20, 2012, 10:17 PM
algy2 is offline
Joined Jun 2011
Hi Allen,
I can give you the name of a Diesel fuel additive that works great for me but want to give a disclaimer that I am just a sport flyer and do not want to enter into any discussion on model diesel fuels and additives.
It is a subject that a lot of people have their own pet theories on and they can get very pedantic, tedious and boring. Ho hum!
First up I found that all model diesel engines benefit from an ignition improver with easier starting, smoother running and the use of less compression. In my particular experience PAW diesels seem to actually love it.
The one I use is WYNN’S DIESEL ANTI-KNOCK but not sure if that is still on the market because I bought quite a few bottles of it years ago and still have some left. It boosts your cetane rating 4-7 numbers
The other commercial diesel additive is AMSOIL CETANE BOOST an American product which is available around the world. About AU$20.00 for a 16 fluid oz (473ml) bottle here. Look up your local Amsoil dealer. Modellers have had good results with that.
Another good brand name is BARDEL but have not tried it. There may be other brands as well. What you are looking for is a boost in cetane rating and that information is usually on the label.
Add it at 1.5% to 2% to the volume of fuel you are mixing. Adding a higher percentage does no good and might do harm.
As you said IPN used to be the additive to use but seems to be unobtainable now. I have had no experience with the use of nitro.
Hope this helps.
Cheers
Algy
Discussion Vintage & Old-Timer Plans PRE 1960 PLANS ONLY orange&white Vintage & Old-Timer Designs 15256 Sep 21, 2016 06:12 AM
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 22 Sep 18, 2016 02:22 PM
Discussion Vintage & Old-Timer kit ideas for laser cutting zbrubaker Vintage & Old-Timer Designs 39 Aug 25, 2011 08:32 PM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 09:30 AM
