Old Jun 28, 2011, 07:41 AM
Joined Jul 2010
GWS EPO Zero, still need mods?
I found some old threads that said the GWS Zero needs mods, either reduce angle of attack of the wing or increase angle of attack of stab, in order to fly successfully.
Anyone know if that's still true of the current EPO GWS Zero?
I saw it for around $40 at Heads Up and have all the gear to put it together so I'm thinking about it for a next project. I don't want to build it only to find out it does one loop and noses in on its maiden flight.
-l2t
learn2turn is offline Find More Posts by learn2turn
Old Jun 28, 2011, 04:45 PM
Leesburg, VA
Joined Jul 2005
I don't know I would guess the wing saddle is the same so you probably need to increase the the angle of attack by dropping the leading edge of the wing about 1/8th inch. You only need to do this mod if you plan to make it a speedster. It will fly fine in stock trim with a low KV brushless motor.
TopSpin is offline Find More Posts by TopSpin
Reply With Quote  (Disabled)
Old Jun 28, 2011, 09:58 PM
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
I'm putting one together now. I have a one year old EPS that I fly a lot and am building the EPO as a back up. It's a great "chuck" fly anywhere sort of plane.
I raised the LE hor stab on the first one based solely on the build threads and have been happy the way it flys.
Even putting the two of them side by side I can't figure out the incidence. From what I can see it hasn't change, so I am doing the Hor stab mod on the EPO.
Hope to report back by the weekend...
bartricky is offline Find More Posts by bartricky
Alert New GWS EPO Zero!!! and other new Zeros.. bartricky Parkflyers 28 Sep 03, 2011 06:24 AM
Discussion GWS EPO Zero, still need mods? learn2turn Electric Warbirds 1 Jun 28, 2011 11:09 AM
Sold Hobby-Lobby EPO A6M5c Zero w/ Retracts $100 shipped! ohsnap Aircraft - Electric - Airplanes (FS/W) 11 Jun 16, 2011 10:51 PM
For Sale GWS EPO FOAM ARFs billbo1970 Aircraft - Electric - Airplanes (FS/W) 25 Jun 01, 2011 07:39 PM
Need some GWS Zero brushless advice (still kinda a noob) Electricman Parkflyers 3 Jul 14, 2004 02:19 PM
