Old Jun 27, 2011, 08:32 PM
Little-Acorn is offline
Find More Posts by Little-Acorn
San Diego, CA
Joined Dec 2006
Is there a Kwik-link smaller than the usual 2-56 size?
I'd like to find a clevis that looks like a Kwik-link, but is smaller. Maybe a 1-72 or 1-80 size, or a metric one that is smaller than 2-56, if there is such a thing?
I've got the little plastic clevises that snap on to a right-angle-bend in the wire, but they cannot adjust. And I've seen some nylon ones that don't have an integral pin - their pin is a separate wire that must be held with a rubber band.
Anyone know if there is a simple clevis that's one piece like a Kwik-link, adjusts by rotating on its shaft like a Kwik-link, but is smaller, and fits on a smaller threaded shaft?
Little-Acorn is offline Find More Posts by Little-Acorn
Old Jun 27, 2011, 09:05 PM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I bought the smallest link that I could find at HobbyKing and I epoxy the rod in, usually carbonfiber. I set one already epoxied end on the control horn and then 5 min epoxy the other and adjust the control surface as it sets.
Butch777 is offline Find More Posts by Butch777
Old Jun 27, 2011, 09:09 PM
Stone1295 is online now
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
Down towards the bottom of this page. Are these what you are looking for?
http://shop.dubro.com/home/search/10...161.5168.0.0.0
-Mike
Stone1295 is online now Find More Posts by Stone1295
Old Jun 28, 2011, 11:14 AM
San Diego, CA
Joined Dec 2006
-Mike
Thanks, but no. That's the clevis wih the removeable (and lose-able) pin I mentioned. And they thread on to the same 2-56 stud the rest do. They just come with a 2-56 stud that has a teeny hole in the end and so can be put on a skinnier wire.
I presently use those studs-with-teeny-hole, with regular steel 2-56 Kwik Links, and solder the stud onto a skinnier wire. They're better than nothing.
But I wish I could find an actual SMALL Kwik-link.
Discussion Larger than Champ but smaller than Supercub? newflyer100 Parkflyers 9 Jul 01, 2011 09:40 AM
Discussion kwik link headshot001 Scale Kit/Scratch Built 1 Jun 05, 2011 04:37 AM
Help! Video cameras... bigger than a Gopro, smaller than a dslr... Efliernz Aerial Photography 9 May 15, 2011 12:16 PM
Discussion what size CF sleeve for 2-56 and 4-40 rod? hidaven Electric Plane Talk 8 Mar 29, 2011 10:16 AM
Discussion 2-56 rod die size and nut size hidaven Electric Plane Talk 9 Mar 26, 2011 01:42 PM
