Old Jun 27, 2011, 07:54 PM
EPF HOBBY is offline
Find More Posts by EPF HOBBY
Joined Oct 2007
New Product
The Next Generation of full metal EDF with PATENT design
EPF HOBBY took one year to redesign the mototurbine series EDF. Due to some customer didn't like the plastic nozzle.
Now brand new series that we call Mercury will replace previous mototurbine EDF. The first model 64mm EDF with 1.8kg thrust.
The other size will be released very soon.
Mercury series EDF were made by high precision CNC. fan included.
All of parts are high impact Alloy.
Turbo Innercooling system let EDF down to room temperature within 15~20 seconds half throtte.
More detail please visit :
www.epf.com.tw
EPF HOBBY is offline Find More Posts by EPF HOBBY
Old Jun 27, 2011, 08:52 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
so is it a pusher set up ..can you show a pic of the rotor ?
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jun 28, 2011, 01:37 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
yeah, I'de like to see more picture of that, including the seperate pieces and the rotor. that motor is deffinitely up front, like the WM fans.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jun 28, 2011, 05:19 AM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
I have been speaking to EPF about this EDF and it is done like the previous version. Pusher configuration. The motor was changed in order to give better thrust numbers, and as stated they reworked the outlet. As in the older design it has a 3 bearing support and dynamically balanced rotor. There is now a tighter tolerance between the rotor and housing as well. Since the housing and rotor act as a heat sink it allows for a bigger battery use, but is maxed out on 5S for the 64mm design.
I have been tempted to carry this series of EDF units and would like to know how many are interested before I place an order to be old through my partner Park Scale Models
CapMike is offline Find More Posts by CapMike
Old Jun 28, 2011, 08:21 PM
Joined Oct 2007
Some Photos, Detail will post later
Old Jun 28, 2011, 10:47 PM
Steve Haynes is offline
Find More Posts by Steve Haynes
There was a crease in the plan
Steve Haynes's Avatar
Joined Jun 2010
So, not wanting to state the obvious, but what bit of this fan has the patent registered on it? It looks like a pretty ordinary IGV to me??
Steve Haynes is offline Find More Posts by Steve Haynes
Old Jun 29, 2011, 03:05 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
I was wondering how one attach the intake to the fan? has this one been designed for open intake ducting given the large intake dia or would this be a replacement fam for 70mm foamies, Just press and fit?
I am curious about the noise level as well. The wm400 is loud vs the wemotec fans (still my favourite)
Looks cool tough!
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Jun 29, 2011, 06:06 AM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Steve the design is not an ordinary EDF unit. The outrunner motor rather than an in-runner motor is in a pusher configuration. The bell of the outrunner had the fan attached directly to it rather than to the shaft. The shaft is then supported by a third bearing in the tailcone. For this reason EF wanted to patent the design to keep others from using the same features. I will be getting a pair for testing purposes and will let people know here how they perform.
Old Jun 29, 2011, 06:21 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
Looks cool tough!
The EPF site has a short video of the fan running so you can get at least a general idea of the sound. Tastes vary but it sounds a bit like the 70mm metal efflux fan to me.
alexandermh is offline Find More Posts by alexandermh
Old Jun 29, 2011, 06:23 AM
Fairborn, OH
Joined Nov 2009
Thanks, looks interesting. I'm also interested in seeing the guts of this fan.
Old Jun 29, 2011, 06:56 AM
Joined Oct 2007
Thrust Curve as below:
Old Jun 29, 2011, 08:29 AM
indy2000 is offline
Find More Posts by indy2000
Joined Mar 2011
seems promising
indy2000 is offline Find More Posts by indy2000
Old Jun 29, 2011, 08:48 AM
DominicM is offline
Find More Posts by DominicM
DominicM
DominicM's Avatar
Fleet, Hampshire, UK.
Joined May 2003
It'll take a lot to convince me EPF Hobby product is useable after buying a set of their electric retracts a couple years ago. Truly terrible quality. Didn't even get them to cycle 6 times on the bench before they broke.
Mind you...the recent RC Lander all electric retracts were as bad.
Good luck though.
DominicM is offline Find More Posts by DominicM
Old Jun 29, 2011, 08:18 PM
Joined Oct 2007
Convertional EDF with one series issue ----Oscillation. Due to the weight of fan and motor are differnt. The fulcrum between them. This is bad design. Due to fan and motor will shake while high speed rotation. and even small sand or stone hit the balde. the factory dynamitic balance was missed.So the plane kiss the earth.....
Old Jun 29, 2011, 08:29 PM
CapMike is offline
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
Good luck though.
Did you try getting help for the broken retracts? As I see it that was before they re-designed the retracts and have made them better. I have a et of the origional retracts as well that are still working just fine.
Discussion RCLander new design large full metal electric retract announcement Tim Wan Foamy EDFs 24 Jan 07, 2013 04:22 PM
Discussion Trying something inspiring this summer or fall for the next generation sloper DWA Slope 2 Jun 17, 2011 01:27 AM
New Product New Generation is Coming---Digital Servoless Retract Landing Gear System(PATENT) EPF HOBBY Electric Ducted Fan Jet Talk 183 Mar 19, 2010 05:47 PM
Alert The Unicorn - a Next Generation EPP flying wing Newest Generation thread part III Don Sims Foamies (Kits) 507 Apr 22, 2004 01:25 AM
When does the next EDF design competition begin? bipeflyer Electric Ducted Fan Jet Talk 2 Sep 12, 2002 01:42 PM
