Old Jun 28, 2011, 06:48 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
You are correct of course. Damn, I hate it when I am right. From the 35mm thread, "Sorry to nit pick, but it's not entirely certain the Rx supplied with the RTF sets is "the new Orange Rx with the micro plugs".
Looks like there is at least two new low cost "1g" Rx floating around now.
Originally Posted by MegaTesla View Post
I don't think this is the same system as used in the 35mm Jets.
jj604 is online now Find More Posts by jj604
Old Jun 28, 2011, 04:34 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
The single servo is indeed around 1.1grams without wires. The double servo is app. 2.2grams without wires so no real weight saving over the single servo other than the wires. I'm not really sure about the merits of having a double servo. It cost more than two single servos and if you break one of the servos on the board it's just dead weight. Apart from perhaps making mounting a bit easier it does not make sense to me. But then, I have always preferred seperate components. My receiver is an early type with a RX module and a driver board soldered together. Consequently it is a bit heavier than the one offered by HK. Servos look to be a bit faster than Spektrum servos. I may be able to shoot a bit of video this weekend.
epilot is offline Find More Posts by epilot
Old Jun 28, 2011, 04:52 PM
axelen is offline
Find More Posts by axelen
OpenGL C/C++ programer
axelen's Avatar
Israel
Joined Dec 2006
Hey Epilot
Since the torque seems to be half of that of the spektrums,
do you think the motor can be replaced with a longer can one?
axelen is offline Find More Posts by axelen
Old Jun 28, 2011, 04:53 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
If these boards were DSM I'd be all over them
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jun 28, 2011, 05:04 PM
epilot is offline
Joined Nov 2000
Originally Posted by axelen View Post
Hey Epilot
Don't see why not provided the half bridge is up to it. What do you need all that torque for?
Old Jun 28, 2011, 05:09 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Hey Epilot
Half the torque but probably twice as fast, it's probably just a different gear ratio. A lower OHM motor (assuming there is one)with the same size shaft should work and you might not even notice much of a flight time difference.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Jun 28, 2011, 05:34 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
I have been using the spekturm ones on a DIY flybar CP.
The spektrum servos did a great job.
now i am building a FBL (flybarless) CP, based on the new
walkera system for the V100D03 (meaing the RX).
on a FBL system you will need more torque form the servos since
you are direcly affecting the pitch of the blades,
rather than just affecting the pitch of the paddles (on a hiller rotor head)
or mixing some affect on the blades and some on the paddeles (bell-hiller head).
so to summarise, I am a bit worried about torque for a FBL CP heli...
I know they will work. the heli will fly. but if they lack toque, the cyclic (manourvering (spelling?)) will be slower
than is supposed to be. this might also confuse the RX's FBL programing...
I am just anticipating problems... always expect the worst and then you wont get dissapointed...
I based my last air frame design for my CP (VP tail) on 4 HK micro rotary servros (stated 2.2gr actual 2.45gr).
Vp tail meant a lot of new parts.
eventually, these servos were such crap, i had to replace the tail with a WK tail servo, and add a voltage booster to ensure
5v for the cyclic servos (they freaked out when batt' was 70% drained and me giving some pitch to ask for good AMP's be the motor... )
the servo's gear break if you turn the horn by accident while screwing in the horn lock screw..... ext ..
Old Jun 28, 2011, 05:37 PM
epilot is offline
Joined Nov 2000
I have no idea what you just said but I'm sure it will make sense to someone
Old Jun 28, 2011, 05:49 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
TODD
.12ms compared to .14
not half, but faster
Old Jun 28, 2011, 05:57 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
I used to shop @ your store... was sure you were
familiar also with heli talk
generally speaking... a heli changes direction (and self sabilises) by
changing the pitch of the blades as they turn around.
this means, if you want to fly forward, when the bladews rotate around
the front of the heli their pitch will provide less lift. While when they
pass through the rear part of the heli they will provide more lift.
this is how a heli tilts. self sabilising systems can be divided into two
majour methods :
1) electronics stabilise the heli
2) mechanics = flybar used to self stabilise the heli.
method 1 requieres more torque from the servo's since they direcly affect
the blade's pitch, rather than method 2 which only changes the pitch of the paddles.
This is because a paddles surface area (and mass) is much less than a blade.
Old Jun 28, 2011, 05:59 PM
MegaTesla is offline
Find More Posts by MegaTesla
Team30 Micro EDF
MegaTesla's Avatar
Stellenbosch, South Africa
Joined Apr 2004
axelen, have you considered lightening these? They are the only normal servo style that uses a 4mm coreless motor. (AFAIK)
HK 2.2g servo $3.99
Spec.
Torque: 0.2kg
Weight: 2.2g (.08oz)
Speed: 0.08 / 60deg
Voltage: 3v~4.8v
Motor type: Coreless
MegaTesla is offline Find More Posts by MegaTesla
Old Jun 28, 2011, 06:00 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
It was clear as MUD to me also.
TODD
Old Jun 28, 2011, 06:08 PM
epilot is offline
Joined Nov 2000
Never did much with helis, just know the basics (I'm too uncoordinated to fly one).
BTW, I have an Israeli employer now - we should be having this discussion in Hebrew! I can already say yes and no
Old Jun 28, 2011, 06:16 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
HK 2.2g servo $3.99
Spec.
Torque: 0.2kg
Speed: 0.08 / 60deg
Voltage: 3v~4.8v
these are the ones ...
"I based my last air frame design for my CP (VP tail) on 4 HK micro rotary servros (stated 2.2gr actual 2.45gr).
the servo's gear break if you turn the horn by accident while screwing in the horn lock screw..... ext .. "
Old Jun 28, 2011, 06:17 PM
axelen is offline
axelen's Avatar
Israel
Joined Dec 2006
shalom shalom
New Product New: HobbyKing HK6DF 2.4Ghz FHSS 6Ch Tx j10fighter Radios 3 Feb 28, 2012 12:42 PM
Discussion hobbyking 2.4ghz hks3000 rudy999 Racing Boats - Electric 10 Mar 24, 2011 10:28 AM
Sold Hobbyking T6A 2.4ghz 6ch Radio System with extras whitty7628 Aircraft - General - Radio Equipment (FS/W) 1 Sep 29, 2009 08:16 PM
Mini-Review Big test, Hobbyking(flysky) 2,4ghz system. sebbe Radios 5 Sep 13, 2009 05:02 AM
Discussion First Impressions using the HobbyKing 2.4Ghz 6Ch System Desert Hawk Radios 5 Sep 10, 2009 10:32 AM
