Old Jun 26, 2011, 03:17 PM
wora is offline
Find More Posts by wora
wora's Avatar
Croatia
Joined Jan 2011
Build Log
mirage 2000 C (2000-5)
Hi.. so here it is... after crashing foamy tiger mirage 2000B, i started with something new
I started with some design found on net, and redesigned it to my needs. I think that Philip Noel started this, but i do no know for sure.. since the design was incomplete, but I liked the wing design, so i take it as good start point.
Power setup.. hm.. haoye 5" EDF (initial, maybee will be replaced with 120" better one), Scorpion 4kW beast inital going for 12S, but maybe 10S depending on CG, Output 85% FSA...
wora is offline Find More Posts by wora
Old Jun 26, 2011, 03:22 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Winter Is Coming
Doushiyou12's Avatar
Joined Feb 2010
whoa
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Jun 26, 2011, 04:27 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Looks really great, nice build
frank40 is offline Find More Posts by frank40
Old Jun 26, 2011, 11:23 PM
czirh is offline
Find More Posts by czirh
Use your imagination....
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Beautiful building..
Cem
czirh is offline Find More Posts by czirh
Old Jun 27, 2011, 02:36 PM
wora is offline
wora's Avatar
Croatia
Joined Jan 2011
Thanks..
I decided to throw up the fiberglassed outlet, it was to hard for removing from plug.. so I ll ended by planking it with 1 mm balsa.
Old Jun 28, 2011, 03:15 PM
wora is offline
wora's Avatar
Croatia
Joined Jan 2011
Today I finished with planking the edf outlet, and started to work on front part of fuselage.
Old Jun 29, 2011, 01:59 AM
flyhawk is offline
Find More Posts by flyhawk
flyhawk's Avatar
Hlohovec, Slovakia
Joined Jan 2007
Nice work I realy liked
Frankie
flyhawk is offline Find More Posts by flyhawk
Old Jun 30, 2011, 03:55 PM
wora is offline
wora's Avatar
Croatia
Joined Jan 2011
Thanks.. this is my first balsa build
Today I started to work on vertical stabilizer, i decided to go with naca006 profile for it, and also finishing frame of front inlets.
Old Jul 03, 2011, 04:15 PM
wora is offline
wora's Avatar
Croatia
Joined Jan 2011
Ok, here is some update.. finished with inner planking of inlets, since here will be some sort of cheat holes on inlets like replica of original ones.. I started with outer planking of inlets.
Old Jul 28, 2011, 09:12 AM
wora is offline
wora's Avatar
Croatia
Joined Jan 2011
Since it is hard for me to keep this thing updated on 10 sites I decided to move build log to following static place: Mirage build log
Wanted Nib riccs mirage 2000 kydawg1 Aircraft - Electric - Jets (FS/W) 1 Jun 04, 2011 06:24 PM
Discussion mirage 2000 mrshea Scratchbuilt EDFs 17 Apr 18, 2011 12:22 PM
Discussion 92mm Mirage 2000 build log chrisras1 Foamy EDFs 3 Apr 14, 2011 05:46 PM
Discussion Wich Mirage 2000 Is better? Rc Lander or FlyFly mikes68charger Foamy EDFs 35 Mar 28, 2011 06:15 PM
MEGA 1615/5 and Mirage 2000-5 needs additonal spars/glassing? juantrinidad Foamies (Kits) 6 Jan 05, 2003 11:43 PM
